Poor ev milage on 24 prime
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Jaxryde, Mar 25, 2024.
  1. Bill Norton
    Bill Norton Senior Member
    2,136
    730
    MONW, Ks.
    Going a set speed, an EV/PHEV will use X amount of power. How "powerful" the motor is doesn't matter. Electric motors are efficient like that.
    Your right foot controls the energy usage and speed.
    I find it curious that the Prime is up there in efficiency when it has to spin two motors to propel the car.
    MG2 rolls the car forward. MG1 must then spin in the opposite direction to keep the Gasser stationary, correct?
  2. Trollbait
    12,441
    The PHEV models have a clutch between the engine and MG1.
    Bill Norton likes this.
  3. Gokhan
    Gokhan Senior Member
    5,931
    2,339
    Paramount CA
    MG1 and MG2 both drive the car. This is made possible by the one-way clutch, which prevents reverse operation of the engine by locking the engine into the transaxle case if it tries to turn in reverse. So, the one-way clutch is not really between the engine and MG1 but between the engine and transaxle case, and its function is to lock the engine into the transaxle case when it tries to turn in reverse. The engine and MG1 couple as the planetary and sun gears, respectively, and there is no clutch in between.
    Advancement of Toyota Hybrid System II (THS-II) | Toyota Motor Corporation Official Global Website
    From the Gen 4 Prius Prime new-car features manual:
    By installing a one-way clutch between the engine and transaxle [case] to prevent reverse operation of the engine, torque from the generator (MG1), which conventionally only generates electricity, can be transmitted to the output shaft and adds the torque of the generator (MG1) to that of the motor (MG2) improving drivability and the feeling of acceleration when the vehicle is driven by motor.
    The one-way clutch prevents reverse operation of the engine when the generator (MG1) is used as a motor. The torque from the generator (MG1) in addition to that of the motor (MG2) is transmitted to the counter driven gear when the motors are operated at maximum output.
    #23 Gokhan, Nov 2, 2024
  4. KMO
    KMO Senior Member
    1,888
    645
    Finland
    2023 Prius Prime
    And on top of the correction about the 'clutch', that exists only in the G4 PHEV. The G5 reverted back to only MG2 pushing in EV operation.
    Trollbait likes this.
  5. Bill Norton
    2,136
    730
    MONW, Ks.
    Is MG1 spinning? Is the clutch just in a different location?
  6. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
    For my (US) Prime XSE Premium-In switching to the LE/SE Prime wheels and 205/60R17 Turanza 005 (so maintined the same overall rolling diameter as stock for XSE/XSE Premium) (with the LE/SE Prime wheel covers) I am now getting 55-61overall mpg in HV only mode versus 46-50 before the change (this is over 1700 miles since the wheel/tire change in varied driving conditions/mix freeway and city/stop-go traffic). One thing I did notice versus the Gen4 Prime is the slight hiccup (don't know what else to call it) or hitch you feel when pressing on accelerator pedal from a start rest position and that the gas engine appears to be more engaged versus Gen 4 which felt a lot smoother starting from rest (due to more reliance on the electric motor?)-Gen 5 appears to want to switch to gas at the slightest provocation (at least that is how it feels for me) If I do press the accelerator pedal ever so softly then it does feel like the Gen 4 ...until you reach higher speeds/slopes when the gas engine does come on. Essentially starting from rest, Gen 4 (in HV) felt like an EV up to a point, whereas Gen 5 (also in HV) does not feel that way (gas engine more involved)
  7. KMO
    KMO Senior Member
    1,888
    645
    Finland
    2023 Prius Prime
    MG1 is always spinning backwards if the car is moving forwards and the engine is stopped, in all Priuses.
    If you're driving in EV mode, MG2 is pushing forwards and MG1 is normally free-wheeling backwards. It's easier to push than the engine is, so the engine stays put and MG1 just spins along mirroring whatever MG2 and the wheels do. If MG1 pushes forwards (or resists the backwards spin), it starts the engine.
    The distinction of the G4 PHEV is the engine "anti-reverse" sprag clutch which means MG1 can push backwards rather than freewheel to contribute motive power.
    MG1 pushing backwards in other Priuses would start the engine spinning backwards - the transaxle being symmetrical, MG1 could spin the engine ether way - but in the G4 PHEV the sprag clutch makes the engine lock in position if pushed backwards, letting MG1 transmit all its torque to push the wheels forward.
    There's no replacement mechanism in the G5 PHEV - it just has a bigger more powerful MG2 so doesn't need an assist from MG1.
    #27 KMO, Nov 3, 2024
  8. Gokhan
    5,931
    2,339
    Paramount CA
    And the lack of the one-way clutch in Gen 5 PHEV is probably resulting in a lower fuel efficiency and BEV range, as MG1 is freewheeling and losing energy without providing torque to the wheels. It seems to be a cost-saving measure by Toyota. Gen 4 PHEV might have the best fuel economy in the BEV mode among all cars out there.
  9. Bill Norton
    2,136
    730
    MONW, Ks.
    So you are seeing Zero power at MG1, if you have instrumentation that displays this, (Torquepro, etc.)?
    Isn't there an RPM redline for this smaller motor and that's what limits top EV speed?
    That poor little MG and associated planetary gears are near Redline while the Prius is at what top EV speeds on the Gen4 and Gen5?
  10. Bill Norton
    2,136
    730
    MONW, Ks.
    That would be an interesting chart to see!
    'Fuel' economy on BEV and PHEV.
    Of course we have an EPA rating, but showing actual power usage at a few different speeds would be a great comparison chart!
    Gokhan likes this.
  11. Trollbait
    12,441
    Yes, the MG1 rpm is what limits the EV speed, but it was increased along with the MG2 in the gen5.
    Even with MG1 not moving, the gears are in motion. Appears Toyota kept that in mind when designing them.
  12. KMO
    KMO Senior Member
    1,888
    645
    Finland
    2023 Prius Prime
    Haven't got anything wired up, but yes, it will be zero power flow to/from MG1. Just a bit of mechanical drag.
    Precise numbers on MG1 speeds haven't always been given in every verison, but the general outline from some notes I have. These figures will have had gaps filled in using gearing ratios which are known.
    G1 had a 6500rpm MG1 limit in either direction. That limited EV speed to 44mph / 70km/h or so.
    G2 boosted the forward MG1 speed to 10,000rpm, permitting faster engine revving at lower speeds, boosting system output. Backwards remained at 6,500rpm, or at least they didn't increase the EV speed limit beyond 44mph.
    G3 had other gearing changes, which seem to have lowered the backwards rate to 5,500rpm based on the 47mph / 76km/h EV limit.
    G4 took that up to 6,800rpm, with a 68mph / 110km/h limit.
    G4 PHEV seems to have a 9,500rpm backwards limit corresponding to 84mph / 136km/h in EV.
    G5 PHEV has basically the same EV speed limit, but that's now 10,000rpm backwards on MG1 due to minor gearing changes.
    MG1 doesn't really see anything significantly different between G4 and G5, except that it's not allowed to push in G5 any more.
    MG2 speed limit remains at 17,000rpm afaik, as it has been since G3, setting the overall top speed.
    tovli and Bill Norton like this.
  13. Zeromus
    Zeromus Active Member
    530
    293
    Ottawa Canada
    2024 Prius Prime
    SE
    Maybe that's it then. The extra power from MG1 probably gave a little boost to the efficiency of the Gen4 on a distance per kwh basis. The gen 5 is also heavier so the extra weight is likely also a contributing factor.
    Gokhan likes this.
  14. Gokhan
    5,931
    2,339
    Paramount CA
    Gen 5 SE PHEV is 96 lb heavier than Gen 4 Limited PHEV, and Gen 4 Limited PHEV could be a little more aerodynamic than Gen 5 SE PHEV as well.
    Edmunds got only 33.7 miles of BEV range on Gen 5 PHEV. Thye mention using the maximum regenerative braking. I hope they didn't use the B mode, which would have lowered the fuel efficiency. The other day, I was wondering why my fuel efficiency was bad, and I realized I had accidentally switched to the B mode when my hand had hit the shift lever. I then accidentally switched to the N mode, and I had to pull to the shoulder in panic, only to realize that it shows on the display how to switch back to the D mode (the same way when you start). That said, I do easily far exceed the 25-mi EPA BEV range on my Gen 4 Prius Prime.
    2023 Toyota Prius Prime doesn’t live up to its electric range | Edmunds
  15. Zeromus
    530
    293
    Ottawa Canada
    2024 Prius Prime
    SE
    The rated distance is around 75km, and I get 90 *with* AC
    Gokhan likes this.
  16. JimLudden
    JimLudden Member
    87
    32
    Taos, NM
    2024 Prius Prime
    I'm getting indicated 52 miles per full battery, measured 48-50 miles, depending on traffic conditions. I plug in the car every time I enter the garage.
  17. Gokhan
    5,931
    2,339
    Paramount CA
    My GOM in my 2021 Prius Prime Limited has consistently been at 40 miles.
    Don’t plug in unless you will drive the car immediately after charging—it's bad for the battery, as leaving the battery at more than about 50% SOC degrades it faster. Use the charge-schedule function instead.
    Also, it is bad for the battery to charge it when it’s hot (as in immediately after driving the car).
  18. chris johnson 2
    chris johnson 2 New Member
    29
    Netherlands
    2024 Prius Prime
    Interesting input. I will adapt my behaviour to program a scheduled charge to start when our low-cost tariff starts. In the seven months when my solar panels are blasting away I will likely drop the schedule and perhaps use a smart plug that I can switch on from my phone. What do you think?
    Gokhan likes this.
  19. chris johnson 2
    29
    Netherlands
    2024 Prius Prime
    Interesting thread you started. I have now done some 1250 miles. My feeling is that my range on pure EV is 43 miles The more I drive the more my driving becomes smoother and slower so I expect this range will increase when the days get longer again. Right now the weather is cold around freezing and we have long dark days with plenty of rain, and so the car comfort systems are working overtime.
    As I move forward I expect I will switch more systematically between AV and EV. As the manual recommends, use AV on the highways when you travel at high constant speeds, and use EV for sailing around town and villages. AV I am also starting to use when I start off on these cold winter mornings to get us off to a warm start.
    From my experience your 30 miles is far too low. I am getting what you expected and I expect to get more in the summer and as I learn how to drive Prius-style. My guess is that your driving style is the most likely cause. Perhaps it is very very cold in Oregon which would not help either. Otherwise you should talk with your dealer - the car costs too much to be dissatisfied!
  20. Bill Norton
    2,136
    730
    MONW, Ks.
    What were they talking about? (n)
    Is there a selectable Regen? I know it has Blended Brakes.
    Regen is the act of slowing down. You can do it fast or slow. The captured energy is what matters, and not using the Friction Brakes.
    And as most know, avoiding regen is best because it's not close to 100% efficient'. Coasting to a stop is. But that's not always possible.
