Parking lines
Discussion in 'Gen 5 Prius Main Forum' started by Will B, Sep 1, 2023.
  1. Will B
    Will B Active Member
    432
    388
    Denver
    2023 Prius Prime
    XSE Premium
    This isn't specifically Gen5 Prius related, but this is my first car with a backup camera! My 2003 Gen1 didn't have it and this Gen5 replaced it a few weeks ago. This is something I've always wanted to do and it is working out as nicely as I hoped. I back into my garage. I put tape on the floor to line it up with the blue vertical stripe on reverse camera screen and stop when the red line gets to the marker at the end. I can line up very precisely each time. Cars have gotten fancier in the past 20 years!
    will
    Gwyd, Gokhan, TwoGeeks and 5 others like this.
  2. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    i've gotten pretty good using the camera too as long as there are some kind of lines or markers to follow.
    I'm still trying to get the driveway squared away though. First, backing in from the street I have a soft ramp that puts the camera image in the air. That's not even the tricky part though. I only have grass on the one side I use to ( guess? ) my angle backing down the rest of the drive and I still haven't got the howto get into the center every time, around what seems like a bend in the grass line. I was also thinking of painting a line down the driveway a week or two ago. Great idea for the garage, and the pics came out good too.
    The worst is when it's dark and raining or even worse snowing at night. Sometimes I just pull in front first and deal with backing out for the next drive.
  3. BiomedO1
    2,731
    1,459
    SacTown, Ca
    I find the backup camera, only useful when you get to within 36 inches of your target. I still back in the old fashion way, staring through the hatch glass. I find it pretty useless, because it doesn't have predictive directional guide-lines. I've installed a similar backup camera on my 2002 GMC into a cheap double DIN head unit. Even that unit had predictive directional guide-lines. Great for backing into camp sites, since I'm usually loaded up and can't see through the rear glass.
  4. Hammersmith
    Hammersmith Senior Member
    1,969
    1,975
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Oh, if only you had the Panoramic View Monitor option, then you'd be really impressed. It's f-ing sweet. :)
    Blackat likes this.
  5. AndersOne
    AndersOne Active Member
    334
    193
    Europe
    2023 Prius Prime
    Yeah its seems they used whatever cheap outdated cam they had left for the standard backup camera - the 360 is like a tickle down from an established (but not state of the art) Lexus system so it looks much better but still behind some other brands. Not that it matters much at this point.
  6. Will B
    432
    388
    Denver
    2023 Prius Prime
    XSE Premium
    vvillovv: I agree, there can be issues is there is a huge contrast difference. Sometimes with sun hitting the driveway and the shadow starting exactly at the garage entrance. The edge guides for me aren't too bad with my concrete driveway, but the precision of the center line helps a lot. I can (and do) back in with only 1-2 inches of clearance for the rear view mirror. I'm still stopping and checking the mirror each time until I get confidence in the camera/tape alignment. So far, so good.
    will
    vvillovv likes this.
  7. Chimera1978
    Chimera1978 Junior Member
    San Diego
    2023 Prius Prime
    XSE
    This may be a bit off topic, but does anybody know of a hack to get the backup cam on at times other than just backing up?
  8. Will B
    432
    388
    Denver
    2023 Prius Prime
    XSE Premium
    Biomed01: I agree that you need something closer for the precision. That is why I like the line. It gives me something to line up to well before the final parking stages. It is tempting to extend the tape to the driveway, but 99% sure it wouldn't last past the first snow shoveling. :) I didn't get the fancy (and higher rez) cameras with predictive lines. I was hoping, but alas no luck, so just have the cheaper camera. It works though, so for an experiment it seems to be a successful one.
    will
  9. Will B
    432
    388
    Denver
    2023 Prius Prime
    XSE Premium
    Hammersmith and AndersOnce: I was hoping for the fancier cameras, but the only reason I have a car at all is I managed to snatch a "leftover" from someone who chickened out of their pre-order. Other than it had to be the XSE Premium Prime, the only options I said were no-go's were the color black and the solar roof. The rest was negotiable. Not regretting it at all.
    will
    vvillovv and AndersOne like this.
  10. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    347
    269
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    I also added PAPI (Precision Approach Parking Indicator) to my garage - amazingly easy and consistent parking:
    AndersOne likes this.
  11. Zeromus
    Zeromus Active Member
    496
    261
    Ottawa Canada
    2024 Prius Prime
    SE
    Man, more and more, I wish we had just increased our house budget another 50k to get a double car garage. We probably need to keep a second car, and I would love if we could have both in a garage, vs one outside all the time. We need to extend our single laneway for the other car to sit there anyway, so that we can more easily get the prius in and out of the garage anyway. Oh well. Such are the decisions and compromises we make. Don't really want to move either. Too happy with where we are and the location. Only minor gripe is that the second car will be outside all the time lol. And we'll need to have a future charge post put outside too as one day we're probably looking at BEV being standard.
    tovli likes this.
  12. Will B
    432
    388
    Denver
    2023 Prius Prime
    XSE Premium
    @Zeromus: Yea, there are always things you would do differently with hindsight! :)
    Will
  13. Mendel Leisk
    40,498
    Tube frame and canvis carport in the driveway? Or too funky for the neighborhood?
  14. Zeromus
    496
    261
    Ottawa Canada
    2024 Prius Prime
    SE
    It doesnt change that its a single car laneway, and two car garage just makes it easier to work around given my wife does shift work. Swapping cars around is no fun on our somewhat busy at commute times street corner. It would be funky but I wouldn't care. But the ice and snow probably make a carport like that, less advisable. Unless we put it in front of the front door lmao. I don't think that would be looked well upon. I'll just end up putting a charging cord for the BEV future on a post out front im sure, for the car that parks on the interlock extended driveway.
