Hybrid Warranty for 2017 Prius
Discussion in 'Gen 4 Prius Main Forum' started by davecook89t, Nov 6, 2024.
  1. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    So against my better judgement, I left my 2017 Four Touring parked in our Fort Myers, FL driveway undisturbed from just before Memorial Day of this year until today, November 6th. (I'm tired of driving back and forth between Florida and New York every fall and spring.) It was under a cover until the recent hurricane blew it off, but I've felt how warm it gets in the cabin even with the cover on, and I am quite aware that the cover doesn't help that much to reduce the temperature in there. Although I couldn't find it anywhere in the manual, I seem to recall that leaving the car without starting it over a 60 period voids the hybrid warranty. So it was with considerable trepidation that I went out to the car this morning after replacing the original 12V battery and tried to start it. Wonder of wonders, the hybrid battery started the ICE without a hiccup. Prior to putting my foot on the brake and pressing the start button, I tried to use my Carista app to check the voltages of the modules while in the Ignition On mode. I thought I had been able to do this before, but possibly, as I realized after actually starting the car, I had used Dr. Prius for that purpose on prior occasions.
    Anyway, after running the ICE for several minutes, I did switch over to Dr. Prius and took the screen shot attached. Perhaps, I need to run the app while driving around to get a more complete picture (I will do that tomorrow once the car is insured again), but for now I am just relieved that I was able to start the car. Screenshot_20241106-165545.png
    52,309
    i'm glad it started for you! you may want to rethink your strategy. as the battery gets older, it will be less and less happy with being left sitting that long. especially in the heat
    Tande likes this.
  3. BiomedO1
    4,040
    2,126
    SacTown, Ca
    Don't quote me on this but I believe I read somewhere that your suppose to place the car in ready mode every 60 days for at least an hour or two. That allows the car's ECU to maintain the traction battery. I think it was under the long term storage.
  4. davecook89t
    1,092
    826
    Four Touring
    Thanks for your comments. Before doing what I did, I tried to research the cost of replacing the hybrid battery, just in case. It's very hard to get good information on that, especially for the lithium version that I have. I would guess this is because relatively few have had to be replaced so far, which is actually a good thing. I suppose I really should trade the car for an ICE vehicle, given my snowbirding habit and my aversion to driving long distances at my age (70 in a couple of months), but I am really fond of hybrids in general, and this car in particular.
    For the data points that others might be able to use, I will try to give an annual update if I keep doing this until the battery dies.:whistle:
  5. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Sorry about that HV batt Dave. Some of our snowbird relatives do the AutoTrain ...my town is one town over from Lorton VA. .Welcome the septuagenarian Hybrid club, we went with RAV4HV next.
  6. Mendel Leisk
    41,839
    All I see is this, page 80 of North American Owner's Manual, fourth generation:
    davecook89t and bisco like this.
  7. davecook89t
    1,092
    826
    Four Touring
    Nothing to be sorry about yet. In the 6 years we owned our Gen 2, it sat around for weeks and sometimes a month or more at a time and the (original) hybrid battery never threw a code. We gave it to charity when it was 15 years old with 301k miles (and replaced it with a new Corolla hybrid), partially because we were afraid of the HV battery eventually dying, but more because we didn't want to deal with the intermittent combo meter issue.
    I did put the Gen 4 on the Autotrain to get it down here, but going back and forth that way all the time would get expensive, and it would mostly sit around in NY anyway, since my wife prefers the Corolla (whose trunk lid she can actually reach when it is open ;-)).
  8. Mendel Leisk
    41,839
    Our 3rd gen was purchased new, off the dealership lot, in November 2010. It had about 10kms on the odometer. A month or two later I notice the decal in the driver's door opening, said build-date was August 2009 (roughly 15 months previous). The 12 volt battery was dead as a doornail*, but the hybrd seemed fine, still does. To be fair, maybe a brand-new battery is more resiliant, in such a scenario.
    * Open Road Toyota Port Moody actually tried to hide the mask the dead 12 volt battery, had the car running when we showed up for a test-drive,to "warm it up" for us. We got charged full dealer-prep, and when I checked the temp spare it was at 40 PSI.
    davecook89t likes this.
  9. davecook89t
    1,092
    826
    Four Touring
    It's now been a year since I started this thread and I'm back to report on the condition of my lithium battery after leaving the car untouched for more than 6 months in the Florida heat. It's been sitting in my Fort Myers driveway with no protection other than a canvas cover. I know what I'm doing is not recommended, but for reasons I gave earlier, I intend to continue this practice and will provide yearly data points to add to the knowledge base as long as I own the car. (I'm thinking the new Toyota BZ might be better suited for what I'm doing. I believe I could leave the car plugged in to a Level 1 outlet and periodically charge the battery remotely and discharge it by running the air conditioner, also remotely. If there is a reason this will not work, please let me know, otherwise I will probably move up to the BZ at some point.)
    In the meantime, I've attached sample screenshots of both a charging and discharging state that I took today while driving around, after starting the car for the first time since late April. I have many more screenshots, but they all show the same thing - Voltage Difference of 0.00 Volts and Delta State of Charge of 1.00%. I'm really wondering how reliable this testing is. I would expect the modules to at least be somewhat out of balance after sitting for that length of time. Comments?
    fluffy likes this.
  10. fluffy
    fluffy Junior Member
    As an owner of the BZ4X, I will note that the AC will not run remotely for more than twice (I believe at a max of 30 min each time) without requiring a physical door to be opened before the next time that feature can be triggered. But you can request the vehicle keep itself at a certain max state of charge (e.g. 50%, 60%, ..., 80%) when charging.
  11. davecook89t
    1,092
    826
    Four Touring
    Hmm, I wonder why they put on that restriction. That will throw a monkey wrench in my plans. Is Toyota trying to ensure that energy is not being wasted? That sounds like Nanny-state reasoning. Thanks for the info anyway.
  12. davecook89t
    1,092
    826
    Four Touring
    https://www.bzforums.com/threads/unlimited-remote-starts-2026-model.1589/
    It seems Toyota may have already addressed what would have been a problem with my strategy.:)
  13. davecook89t
    1,092
    826
    Four Touring
    I guess this will close out my ad hoc testing of the durability of the lithium battery in Toyota's 4th Gen Prius. I am now the proud owner of a 2026 Toyota Bz Limited FWD.
    To summarize, my 2017 Prius 4 Touring spent the past 2 Late Spring, Whole Summer, Early Fall time periods baking in the Florida sun, totally undisturbed, for a duration of more than 6 months each time, with only a canvas cover for protection. For a final time, the car was left sitting, also undisturbed, from early December until 2 days ago. I have not been able to discern any ill effects in the car's behavior, despite that practice being highly discouraged to the point that it would void the factory warranty. In fact for the 2 trips I took yesterday and the day before, the first about 15 miles, the second about 40 miles to the dealer, the guage was showing more than 70 MPG in the first instance and around 69 MPG in the second instance. I didn't advertise the fact that the car had been driven infrequently over the last couple of years when I traded it in, but the dealer gave me a credit that was close to the value at which Carvana had appraised it, so apparently they couldn't find anything wrong with it.
    The whole experience gives me some confidence that I made the right decision in going back to Toyota for an EV, despite their initial reluctance to go all in with BEVs.
  14. BiomedO1
    4,040
    2,126
    SacTown, Ca
    Well, since you traded it - it's a moot point now. The problem with leaving the the car idle for more than 6 months isn't a question of; if you can start it, but a question on long-term reliability of that traction pack. Your Dr Prius app already shows significant degradation in a several battery pairs, even though you probably have very low miles on that car.
    IMHO; if I kept that car; I would've 1. pulled the safety disconnect on the traction battery pack. 2. disconnected the 12V battery; before heading back north. The car should be ready to go by reversing the two procedures above.
    As a side note; you may want to do that on the bZ as a thief deterrent - the car will seem like it's dead. Just make sure your mechanical keys work FIRST; so you don't lock yourself out. This is the old fashion "kill switch" trick we used to use before alarms was affordable.
    Good Luck and thanks for the information.....
  15. davecook89t
    1,092
    826
    Four Touring
    Yeah, 42k miles on a 9 year old car would qualify as low. I'm wondering what you are seeing on the Dr. Prius screenshots though that gives you cause for concern. You can't do any better than a voltage difference of 0.00V between greatest and least charged modules under both charging and discharging conditions and the Delta SOC of 1% also seems to me to be insignificant. On the hand, I believe I have seen it suggested on this forum that Dr. Prius measurements are not to be relied upon for lithium batteries. Is that possible?
