What is the best source for body parts?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Nov 7, 2024.
  1. douglasjre
    douglasjre Senior Member
    2,164
    715
    Null, NL
    Where are you guys sourcing parts from these days? Any pitfalls or places to avoid?
  2. Tombukt2
    12,901
    2,316
    I've got two whole cars here with everything from the front bumper cover back is good on the cars defenders doors hoods complete interiors soft tech and real leather so if I can help you out in any way do let me know before these things wind up going to God knows where the salvage yard believe it or not I won't keep these around here forever they're posted on the Facebook marketplace as 2010 and 2013 Prius parts in the Raleigh-Durham Facebook marketplace I don't know how to link it
  3. Mendel Leisk
    41,326
    Just editorial: clarify if you want Prius body parts? ;)
    douglasjre likes this.
  4. rjparker
    10,082
    6,249
    I would have no problem with aftermarket body parts or salvage. However years ago I replaced the front bumper cover with a Toyota part and had it painted.
    Now there are aftermarket bumper covers prepainted and folded for shipping. I might go that route if needed.
    Tombukt2 likes this.
  5. Tombukt2
    12,901
    2,316
    Yeah I've seen those are like four or $500 a pop or something $3.99 plus the shipping I'm not sure that they fold the painted ones but maybe
  6. rjparker
    10,082
    6,249
    $360 painted folded shipped by fedex, $640 not folded. Much less primed only and folded.
  7. Tombukt2
    12,901
    2,316
    Well my body shop supply guy the bumper guy here in the south I think sells these bumper covers for about $99 129 course they're unpainted and cum black primer obviously painting is expensive I mean I can probably get a front bumper painted here locally by a friend of mine that has a body shop he's an older guy doesn't do a whole lot of work now maybe 120 150 bucks but the paint is $80 or something like that for the amount needed for the bumper and then if you're painting one of these Toyota colors that has to be mixed and ordered and purchased and all of that so very quickly you can see what can happen I ordered a hood from one of these places not painted the steel equivalent of the aluminum hood It was only $129 for the hood and $200 for the shipping because it can't fold up and when it got here it was damaged from carparts.com so usually nowadays I try to find the stuff off of another vehicle literally there's enough generation 3 sitting around shouldn't really be a problem I wouldn't think but a lot of people are keeping the cars together thinking someone's going to buy the car for $1,500 and spend $4,000 fixing it for however many year old generation 3 were talking about The logic just isn't there really My two generation 3 is fairly easily fixable or sitting here and no one will touch them and almost no one will touch the parts I guess people have wised up which is fine
  8. ChapmanF
    18,072
    Week after Hallowe'en, it should be a buyers' market.
    douglasjre and Mendel Leisk like this.
  9. douglasjre
    2,164
    715
    Null, NL
    Got to replace the plastics under the front bumper and radiators
  10. Tombukt2
    12,901
    2,316
    Yeah you can buy that new off eBay and Amazon from aftermarket places I've bought them a few times I don't have the money either of my two cars the women see theyre gone in 60 seconds
  11. SusanT
    SusanT Junior Member
    I need to replace all those black plastic parts that line the wheel wells and underside of the car. The clips that held them on dried up and the liners have fallen to where had to be removed. Also, I want to replace all the window gaskets. Living in FL with no garage...... any ideas where I can find these?
  12. Tombukt2
    12,901
    2,316
    Window gaskets on drip edge of door will be costly or possibly made for aftermarket try Amiyama.com is be interested to know costs of these too . I'm guessing 35 a strip x4 ?
  13. rjparker
    10,082
    6,249
    Best way is to find the Toyota part number for any item you need. This is easiest at a dealer parts dept but many won’t give them to you unless you buy.
    Next is one of several online Toyota dealers. I will list a couple below. You send them an email with your vin, model and year along with a GOOD description of the parts you want. Pics that are clear help. These guys will help but are not going to hold your hand and go out to the car and show you their screens like a dealer might. But prices are often 25% less AND you get a quote with part numbers for oem parts. Sometimes more than 25% off during sales.
    Finally the lowest cost solution is aftermarket parts you find by searching using the oem part numbers. The plus here is low cost but the aftermarket parts may be flimsy and often do not fit great. For example I bought the bigger aftermarket bottom engine plastic when my oem version had the swinging oil change door ripped off. I had to adjust too many of the bolt holes and ended up merging the new into the old.
    I also changed a wheel well plastic with aftermarket. It was flimsy and needed more clearance holes as well.
    The clips are relatively cheap on Amazon but you need the part numbers.
    So getting a good result with cheap aftermarket pieces takes work in most cases.
    Finally used oem parts can be found on eBay but getting the right part can be the trick. You are also hoping the seller knows the part number correctly. Be careful of eBay’s refund policy which often requires you to pay shipping back and not refund their shipping.
    McGeorge
    Genuine Toyota Online Parts| Toyota Parts| Toyota Parts Store | Toyota Parts|Toyota Online Parts
    Hoover Toyota
    Genuine Toyota Parts and Accessories: Official Online Store Hoover Toyota
    If you read this far, you can sometimes save shipping by buying online from your local dealers! Not all are online and not all have a pickup at the store option but it has worked several times for me. Each online dealer may have a different set of parts available and usually have different prices.
    #13 rjparker, Nov 11, 2024
  14. Mendel Leisk
    41,326
  15. douglasjre
    2,164
    715
    Null, NL
  16. douglasjre
    2,164
    715
    Null, NL
    I agree w Parker except don't buy used man. This is throw away stuff
