Death rattle
Discussion in 'Gen 3 Prius Technical Discussion' started by Ethan Guzman, Sep 9, 2022.
  1. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I presume toyota won’t cover HG’s?
  2. Grit
    Grit Senior Member
    6,415
    4,182
    Wilkes Land
    If they do, we’d have pigs flying all over
  3. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I sold it to my grandson. It will never sit long enough to collect what ever gaseous evil is causing this. Plus his dad and and I have the skills to R&R an engine or fix the HG should that ever happen. it is not leaking coolant at all and the death rattle only happens after sitting idle in cold weather in my garage.
    I have found “push button, floor accelerator to start” seems to avoid it.
    Personally, I suspect the vacuum at start liquifies gasses that temporarily foul the plugs much like a “dew point” with water, except caused by the pressure drop under vacuum. I’ll leave the rest to the physics majors!
    Grit and ASRDogman like this.
  4. Mendel Leisk
    40,498
    Need a bit more back story. What the miles, symptoms?
    chuckiechan likes this.
  5. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    It's blow-by condensed in the intake. An oil catch can will fix this.
  6. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Illegal in California. But there is a long interval between smog tests like four years or something. I’ll bet a splice so you could remove it would cause you to flunk.
    #26 chuckiechan, Feb 6, 2023
  7. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Less than 90,000. I did a EGR cleaning out per instructions here @ PC. It only happens during a two or three day cold soak. But “forced start” is helpful. (Start button, floor gas pedal when dash icons appear). Not losing water.
    #27 chuckiechan, Feb 6, 2023
  8. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    In formation!
    Grit likes this.
  9. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Ask them for a three year 50,000 mile warranty.
    if your head gasket isn’t leaking why burn the money.
    I hear talk of getting used engines, but really. How good are they? Good enough for a 50k and 3 year?
    Toyota built a bad engine and they know it, yet AFAIK it has been one patch on top of another.
    Oh well. I must be grouchy today..
    #29 chuckiechan, Feb 6, 2023
    Grit and Mendel Leisk like this.
  10. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    Uh... a (partial) vacuum would tend to encourage evaporation of liquids, not condensation of gasses into liquid.
  11. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    If the gas was saturated, wouldn’t liquids precipitate like dew?
    Which makes me wonder if anyone has tested removing the air intake to the manifold for test purposes. Thus introducing air into the throttle body known to be “clean” air.
    Lastly, starting by immediate 100% gas pedal seems to help.
    Standardized testing would help.
  12. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    Liquid would precipitate if you cool your saturated gas (example: dew forming), or compress it (example: condensate collecting in a compressed-air system). Water can certainly be condensed by cooling exhaust gas or cooling the PCV mixture of gases, both of which inevitably include a healthy dose of water vapor.
    The last time I got an alarmingly rough start (which wasn't recently), I tried depressing the accelerator, and couldn't tell it helped at all.
  13. douglasjre
    douglasjre Senior Member
    2,092
    698
    Null, NL
    Never seen somebody put putty in an EGR valve before
  14. xliderider
    xliderider Senior Member
    8,040
    3,212
    Honolulu, HI
    It's been cleared up, a putty knife to block the EGR path, no putty involved.
  15. Adamcasey2011
    Adamcasey2011 New Member
    Beaumont
    Hi mendel I have a 2013 prius 172,000 miles on it I have a rattle on cold start up and coolant loss no white smoke or cross contaminated oil. I can step on the acceleration when start to make the rattle go away. I'm not sure what the problem is. It just recently started doing this about 2 months ago. I just started working so I haven't been able to test much with what could be wrong. I've tried removing the o.ring to the radiator cap and it helped but with the o ring on the cap it was doing the rattle when I would come to stop signs and red lights after I took the o ring off it only does it upon cold start up. It's my only vehicle and until I get money rolling in there isn't much I can do. My hv battery has also went out where my car just constantly runs without going into ice mode. I have misfire in cylinder 1 and changed all spark plugs and cylinder 1 ignition coil. Still have misfire. I'm starting to believe it's a small head gasket leak. I just don't understand what else it could be.. any ideas?
  16. Brian1954
    Brian1954 Senior Member
    1,717
    669
    South Central PA, USA
    Do you have a 2013 Prius OR a 2013 Prius c? Your profile says that you have a 2013 Prius c. These two cars have completely different engines.
    I see that you created a new thread in the Prius c forum, and you say that you have a 2013 Prius c. https://priuschat.com/index.php?posts/3491624
    Mendel Leisk and ASRDogman like this.
  17. Adamcasey2011
    Beaumont
  18. Mendel Leisk
    40,498
    I’m seeing “2014 Prius II”, just changed? If so, considering miles and symptoms, very likely the usual, head gasket leaking coolant into cylinder one. Moving coils around, versus replacing, to see if misfire code changes, is more prudent course. If the one you replaced is some sort of aftermarket, and you still have original, I’d put the original back in.
    top two links in my signature relate to EGR cleaning. Bottom link is full engine section of Repair Manual. On a phone turn it landscape to see signatures.
    more head gasket info here:
    New head gasket replacement video from Gasket Masters | PriusChat
    do a full EGR clean as well.
  19. Brian1954
    1,717
    669
    Adamcasey2011 created a new thread in the Gen 3 forum:https://priuschat.com/index.php?posts/3491761
    Please continue any discussions in that thread.
    The thread in the Prius c forum that I linked to in post #36 was deleted.
