Toyota Door Sill Protectors (new)
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Hammersmith, Jul 16, 2024.
  1. Hammersmith
    Hammersmith Senior Member
    1,969
    1,975
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It appears like there's going to be a new door sill protector from Toyota soon. They are purely functional as they're only textured black plastic/rubber. They're not up on the autoparts.toyota.com websites yet, so I don't know the pricing. The part number is PT929-47250-02. I'll attach the installation instructions from TIS so you can sorta see what they will look like.
    Norma Butts, daisy555, Mksky and 2 others like this.
  2. Mendel Leisk
    40,498
    Good to see. Comparable hatch threshold protection would be welcomed as well I’d wager.
    Norma Butts and Cruzctrl1 like this.
  3. PhoS
    PhoS Active Member
    234
    194
    Nowhere
    2023 Prius
    Limited AWD-e
    Nice, I like these better than the superficial metal ones that barely cover anything.
  4. Cruzctrl1
    Cruzctrl1 Junior Member
    25
    Linn Valley, KS 66040
    2023 Prius
    XLE AWD-e
    I found these last year and have been happy with both the protection (fronts are longer, backs shorter), and the ease of installation.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    740
    Monument, Colorado USA
    Those are what I put in my white Prius, too....looks good.
    After i got my wife her 2017 Prius, I found some from Toyota that are lit and the car was already wired for them...made installation very easy and they are sharp but I think Toyota got rid of them...don't see them anywhere now.
    Cruzctrl1 likes this.
  6. Hammersmith
    1,969
    1,975
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Part number PT942-47160, which was superseded by PT942-47161. You can still get them for a gen4($250), but I'd be nervous trying to install them on a gen5. The door sill is likely shaped different, the wiring is different, and they wouldn't particularly look good with the completely different font for the Prius logo.
    I also don't care for those other protectors as the faux carbon fiber look is just not my thing. Heck, it's one of the little reasons I converted my blue LED and gray trim garnish over for the red LED and copper trim garnish; I just didn't like that pattern in the gray trim in the HEV.
    General FYI, the new protectors from my original post are still not in the ordering system.
  7. Cruzctrl1
    25
    2023 Prius
    XLE AWD-e
    I completely understand the faux CF thing. I wanted something thick and protective as opposed to the look and these punched both of those. It didn't hurt that the Toyota branding looked almost OEM. Unfortunately the ones I got are nowhere to be found on Amazon now.
  8. ColoradoBoo
    1,132
    740
    Interesting...I'll have to pull off the plastic guard and see if my 2021 is, also, pre-wired for those lighted doorsills. (If so, will search on Amayama for a discount price.)
  9. Hammersmith
    1,969
    1,975
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Here are the instructions if you want to get an idea of work needed.
  10. Hammersmith
    1,969
    1,975
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Update: They're still not easily available through the various autoparts.toyota.com stores, but they can be ordered through dealerships. MSRP is a little under $60.
  11. Mendel Leisk
    40,498
    Interesting: our 2010 Prius, Canadian Touring level, has cutouts for locator/locking tabs on the sill protectors that came with ours. In other words, they wouldn't look complete without the sills. I believe there were levels without the sill protectors, for that country/gen, so maybe two body styles? Not sure. I was washing the car the other day, noticed a little rust bubbling, should have got on it sooner. Dremelled it clean and applied touch-up paint. Anyway:
  12. UserError
    UserError Junior Member
    81
    Illinois
    Do they make illuminated door sill protectors for this generation Prius?
  13. Hammersmith
    1,969
    1,975
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No. At least not OEM. Maybe a 3rd party does, but I don't know about that.
  14. daisy555
    daisy555 Senior Member
    1,651
    692
    CT
    By chance, have you seen a photo of these yet?
  15. Mendel Leisk
    40,498
    Door sill protection should be standard, not an accessory. :cautious: And it doesn't need to light up, have flashy chrome or Prius badge, just simply/effectively protect.
    I'll go back under my bridge now...
    Norma Butts, Cruzctrl1 and daisy555 like this.
  16. Hammersmith
    1,969
    1,975
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The instructions in my first post have reasonably good pictures.
  17. daisy555
    1,651
    692
    CT
    Thanks. I somehow overlooked the photos. That’s exactly what I’m looking for.
  18. daisy555
    1,651
    692
    CT
    When I zoom in on these photos the surface looks really rough. Any thoughts on how difficult they will be to clean? Has anyone seen previous models of these? I really like the protectors on my 2009 but they look more substantial than these and are easy to wipe down. I would just go with the OEM sill protectors but they don’t look like they cover the areas that get the most wear.
    Looks like my car might be in build stage. Not holding my breath. 2024 still being built on 11/18? Maybe it will come in as a 2025?
