Dumb question regarding coil tips
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by R_W, Oct 13, 2024.
  1. R_W
    R_W Junior Member
    71
    24
    Actually, the question isn't dumb. I am...
    I have been getting a misfire on Cylinder #4, so I was trying to do the thing where you flip the coil and plug into other spots. I have done this a few times over this car's 300k, but this time I got something new.
    Maybe because I was doing it while the car was hot or maybe because the last time I used cheap coils, the rubber tip came off when I was pulling #4. It looks like there is a rubber tip that goes inside a longer rubber tip and those became separated. I tried pulling the one I was flipping it with apart (without putting a lot of force into it because even cheap coils aren't cheap) and it did not come apart easily, but I didn't try real hard. (My plan had been if it did, I would have flipped them anyway.)
    My "solution" was to put #4 back. It screwed-down fine. Before I did that, I tried fishing around with a pair of needlenose, but only for a few seconds. I guess my hope is that screwing it down should have forced the inner tip into the outer.
    Right now, I just put it back together the way it was and came inside to post this query.
    Has anyone had this happen before? Maybe if I let it idle a bit, it'll get suctioned back together. If it comes out in two pieces again, does anyone have a suggestion other than needlenose?
    Any thoughts, other than to buy better coils?
    Thanks
  2. Tombukt2
    12,010
    2,123
    The rubber ends can pop off of any of these things factory or aftermarket most of the aftermarket look just like the factory for the generation 3 they have that outer sleeve cladded with some kind of metal or aluminum and that runs down to the rubber tip which is actually attached to the inner plastic of the assembly I do believe so if it has come off you should not be able to get your spark plug socket onto the spark plug so then you're doing the right thing I use a long pair of hemostats or long pair of needle nose if they're narrow enough to fit and open enough to grab the piece usually I slide the tip of the needle nose that's open against the spark plug insulator which is the China part and try to lasso the plug that way or the rubber piece that way and then squeeze the needle nose together if that works and pull it up you'll want needle nose that have the rough surfaces on the insides of the tips not the smooth if it all possible That's why the hemostats that are real long seem to work pretty well to do this but I have done it with Erwin brand long needle nose. I don't think this will necessarily cause a misfire or any problems other than the rubber buddhisn't there It might make it more susceptible to do that if there were oil or something in the well or the spark plug hole area when the spark plug is in place or even water but then that's going to do that when it reaches a certain level regardless so if your coil is bad it should move to the next cylinder like it would whether the rubber tip was there or not.
  3. R_W
    R_W Junior Member
    71
    24
    I did not mean to ghost you for a month. Sorry.
    My try with the needlenose took a small bite out of the rubber, so I ordered some hemostats and tried them, but couldn't get a good grip. It felt like I was getting ahold of it, but then it would slip out out of the hemostats.
    I also got my wife to try and when that did not work, I took apart an old coil which I had marked as having not gone bad when I changed them before, popped it into the stuck rubber and put it all back together.
    (Before doing this, I tested the old coil that had been in a drawer with a multimeter and it tested better than the one in the car. Of course by this time I was frustrated and the old one was from a set that had gone bad and been replaced, so it could have been on its last legs. IDK.)
    Now I'm going to try again because the car is still (back to?) intermittently misfiring.
    Any other suggestions as to how to get the rubber out, if the two parts did not re-fuse driving it around town? I took the cowl and everything off yesterday, but the mosquitoes got bad, so I put the rest off until today.
    Thanks
  4. ASRDogman
    ASRDogman Senior Member
    7,115
    3,713
    Maybe a coat hanger, metal one, with a hook at the end to get all the way down and under it
    to lift it out. Do one side then slide it around and pull the other side, little by little until you can
    get it out.
    You still have mosquitoes? Are you in the boonies of Florida? :whistle:
  5. R_W
    R_W Junior Member
    71
    24
    Not really the boonies, but still Florida.
    I haven't gone out there yet. Was thinking about trying to get a thin screwdriver between the rubber and the wall, sliding it around and then using the long hemostats. My reluctance before was that I didn't want to scratch the well, but I've pretty much decided that if it were to happen, it wouldn't hurt anything.
  6. ASRDogman
    7,115
    3,713
    Depending on where you are, I have a few tools that would likely work..
  7. Tombukt2
    12,010
    2,123
    You can take a longer model of exacto knife push it down and put a slice in this boot now take your hemostat and go down and get one half of the hemostats in the slice and the other half not so much squeeze them together and let's see if we can pull this thing out if you get pieces of it just keep going back until you get enough pieces that you can slip the spark plug socket over the spark plug and pull out the rest of the mess then you can dig it off of the plug.
  8. R_W
    R_W Junior Member
    71
    24
    This afternoon, I tried running the screwdriver down and sliding it around. I even put the screwdriver in and twisted it sideways, then tried to slip the hemostats deeper into the slot it created, but they always slipped and popped off.
    Then, I fell into a rabbithole of trying to figure out how many of my old coils are still good and whether the one I had taken out was good. Confusing matters, today, when I first checked the one I popped-in previously, I got a different number than I got later when t was on the workbench. I also got different numbers on the one I had taken out last month. It looks like I need to take inventory of my old coils, starting with finding out what number I'm supposed to get from the multimeter. (16.2?)
    As part of this exercise, I pulled the one beside it out to see how it checked. This reminded me of how much force you need to pull them out which will probably serve me tomorrow, when I take some wire like @ASRDogman suggested. I thought I'd start by trying to simultaneously break the seal all the way around and if that (or the hook) doesn't work, I'm very open to @Tombukt2's exact knife thing.
    Another thing I haven't tried is trying to grab it by the inner hole where the spring goes. I've avoided it thus far because it looks weak, but if I'm going to exacto knife it, whether the inner ring is intact wouldn't really matter, I guess.
    Again, thanks for your help and I'm open to any other suggestions.
    The car has been intermittently giving me a P0420 and a P0304 pretty regularly. Based on what I've read in this forum and elsewhere, I'm hoping that addressing the misfire might solve the P0420. Though I know it' is probably a longshot, but you have to start somewhere.
    Thanks
  9. ASRDogman
    7,115
    3,713
    Have you tried removing the spark plug?
  10. Tombukt2
    12,010
    2,123
    Usually I can pound my ug socket over the rubber then dig out of socket . A pain yes but usually I won't have to write about it or do anything like that It's done in seconds.
  11. R_W
    R_W Junior Member
    71
    24
    I haven't tried removing the spark plug because there is a 2.25" rubber boot (tip) on top of it. The one I have here that I popped-off the coil I put in there isn't really collapsable on my desk with my bare hand.
  12. R_W
    R_W Junior Member
    71
    24
    If either of you or anyone has an answer regarding checking the coils with a multimeter... I am reluctant to put the coil back whose end I am trying to dig out and I've popped the end off of the one from my drawer that was marked as having not produced a code. That leaves me with a bunch of coils that I don't know whether or not they are good.
    Several of them produce the same 16.2 number when I check using the method on YouTube, while my search to see if I can find the proper reading produces a thread from the Gen2 forum that says you can't use a multimeter to check a coil.
    I would not have a problem purchasing the spark tester tool the fellow uses in this video, but I'm not finding it in the online catalog for Harbor Freight or Advance, while the other stores have it or something similar ship-to-store or like 45 minutes away.
    Thanks
    Edit: I ordered the tester. It is supposed to be here tomorrow. Of course something prettier than testing these half-dozen coils in Maintenance Mode, such as with a multimeter would be better, but the tool looks like it works.
    #12 R_W, Nov 14, 2024
  13. R_W
    R_W Junior Member
    71
    24
    Update: I'm still messing with this. Argh!
    I tried a tool like the one @ASRDogman suggested via DM. I guess I am going to have to cut it up and pray I get all of the bits out. I assume it would not be good for any of the rubber to fall into the sparkplug hole.
    I've also wondered if it would do any good or be big pain, if I take the cover off.
    Argh!. Right now, the car is unusable because the rubber is now all ate-up from grabbing it with two sets of hemostats, so I can't just pop another coil into the spot and I'm cursing whomever decided they should have removable tips.
    Edit (FWIW): I have tried a Shop-Vac, two hemostats or two flatheads at the same time like tweezers and I haven't quite, but am coming close to having ripped-off everything that you can grab with pliers or hemostats.
    Another Edit: I'm thinking a high pressure water hose might hurt more than it would help.
    #13 R_W, Nov 19, 2024
  14. Mendel Leisk
    40,467
    High pressure air jet, with what-have-you, say shop vac, leaf blower, or air compressor air wand if you have?
  15. R_W
    R_W Junior Member
    71
    24
    I've seen that suggested on something I found via CoPilot. How would you get the air underneath?
    #15 R_W, Nov 19, 2024
  16. ASRDogman
    7,115
    3,713
    DO NO USE WATER!!!
    Pulling the cover might be the only way. But, I believe those tubes are part of the head.
    I "think" they are press fitted so removing them is likely going to ruin it and you'd have
    to install a new one.
    You could use a torch with a long flame to "cook" it and maybe break it apart then blow out
    the chips with compressed air. NOT WATER!
  17. R_W
    R_W Junior Member
    71
    24
    If I ever get the dang thing out... is there some kind of lubricant I apply to the next one?
    I've changed the coils twice on this car and have flipped them a couple of times to see if it was the coil or the plug, but I've never put anything on them. This is ridiculous and if I can avoid it, I'd rather not have to go through this again.
    Of course, it's still not out and my wife is saying that maybe I should have it towed to a garage, so that I can pay a mechanic by the hour to do the same thing I'm doing because if there was a tool, I'd buy it. Thus far, I've bought hemostats, the little grabber thing and now an air gun attachment for my compressor that isn't long enough to get past the thing.
    #17 R_W, Nov 19, 2024
  18. R_W
    R_W Junior Member
    71
    24
    I've thought about burning it, but I'm worried that could damage the plug and then I'd have that mess.
    And yeah, I haven't had the cover off, but I imagine the tubes wouldn't just pop out.
    Right now, I'm trying multiple coat hanger-like hooks. I've tried a screwdriver on each side, now maybe three "hooks".
    ETA: The rubber is now super pliable and I've torn so many chunks off, I'm at risk of not having anything to grab. I still haven't tried cutting it into thirds because I was worried some might remain in there and fall down the hole when I take the plug out, but I'm beginning to have no choice and a lot of it has already broke-off..
    #18 R_W, Nov 19, 2024
  19. ASRDogman
    7,115
    3,713
    Do you have a compresser? You can blow them out.
  20. rjparker
    9,505
    5,820
    I don’t think pulling the cylinder head cover will help anything.
    You will just spend a lot of time and accomplish almost nothing.
    I would finish cutting up the rubber, vacuum it out at a minimum and get the plug out.
    If you take it to a mechanic he will do the same thing, probably with a better selection of tools and picks and have it out in minutes. They will use compressed air to blow pieces out of there and might turn the engine over with the plug out.
    Not nearly as bad as stripping the threads and having to drill for an insert.
