button next to odb port
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by prince, Nov 24, 2017.
  1. prince
    prince Junior Member
    52
    17
    Atlanta, GA
    What is the purpose of the little button to the right of the ODB port?
    Thanks!
  2. xliderider
    xliderider Senior Member
    8,040
    3,212
    Honolulu, HI
    I believe you are referring to the TPMS reset button. It's either that, or your car is equipped with a passenger ejector seat. ;)
    Mendel Leisk and Raytheeagle like this.
  3. prince
    52
    17
    Atlanta, GA
    lol, pressed it a few times and no ejection, must be TPMS reset, thanks!
  4. xliderider
    8,040
    3,212
    Honolulu, HI
    TPMS reset is hold button down for 3 seconds, so your brief presses probably didn't do anything.
  5. Mendel Leisk
    40,498
    Yeah there's some description in the Owner's Manual. If you've started the reset there's something displayed on the dash? I forget. :)
  6. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    TPMS light will blink slowly while you hold the button in (3 times and then stop). The same vicinity is a common location for a KARR alarm indicator/disabled button as another possibility.
  7. prince
    52
    17
    Atlanta, GA
    Whew! Nothing happened since I didn't hold it down that long and nothing showed up on the dash. Thank you so much for the info! :)
  8. Mendel Leisk
    40,498
    All that would happen, if it "took", would be to reestablish the warning parameters per your current tire pressures. I think they have to drop something like 25% below that pressure, before you get a warning.
    MPGesus and jzchen like this.
  9. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Per the manual we are supposed to reset it every time we adjust the pressures. In the indirect system in the '04 Sienna not resetting for long periods makes it NOT sense a deflation event.
    Does this direct system deviate somehow that we should reset it every time? (I check pressures every two weeks but don't reset, partly because it's usually at night/very early morning when I check).
  10. Mendel Leisk
    40,498
    I think you could set it once and forget it, as long as your set pressures don't vary radically.
    jzchen likes this.
  11. bisco
    51,043
    i've never touched mine, and the light has never come on.
    jzchen and Raytheeagle like this.
  12. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    After any service where they may have touched the tires, I will try to check the next early am and reset, just in case they did reset it for me. (Almost always never get the pressures right. Now that I think about it, maybe they don’t touch them when I get a car back and it is correct when I check)!
  13. snick
    snick Junior Member
    29
    Riverside, CA
    PXL_20241113_195806796.jpg I finally found found my TPMS Reset button! Go right from the OBD connector to the screw, the follow around under to the square recess. To push the button it is STRAIGHT UP. But Wth is the button labeled "OFF" to its left for???
  14. ASRDogman
    ASRDogman Senior Member
    7,134
    3,729
    Right where it's always been. So easy to get too...:whistle:
    snick likes this.
  15. Mendel Leisk
    40,498
    Turning off key detection? I believe with gen 2 it never "goes to sleep", so if you weren't going to use the car for a few days, turning this off helped preservie 12 volt battery charge.
    snick likes this.
  16. snick
    snick Junior Member
    29
    Riverside, CA
    Hmmm, interesting.
  17. Mendel Leisk
    40,498
    You could push the button and test.
  18. Brian1954
    Brian1954 Senior Member
    1,717
    669
    South Central PA, USA
    Did you look in the owners manual?
  19. amarino
    amarino Active Member
    134
    102
    99
