Bought Used Gen3 2010 Prius IV @ 155k miles. What should be done?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by swordsx48, Nov 21, 2024.
  1. swordsx48
    swordsx48 New Member
    Los Angeles
    Hi all hope all are well!
    I bought this prius, got a great deal on it in fact. $5300. It runs well, I've been getting 45-48mpg on eco mode, and I'm really happy with it. My first hybrid.
    It definitely does consume oil though, and I was thinking of doing the EGR + intake cleaning & a piston soak. Piston soak I see could be recommended not to do as B12 breaks down the rings, but it seems the soak is more likely to address the oil consumption, and the EGR more to help with heat.
    Now, some say it's easy, some say it's hard. I'd say I'm relatively decent with cars, done brakes, rotors, on my previous cars. Changed a valve cover gasket. I'm not great definitely, but I'm open to doing it myself. If I can get it done over a weekend that would be reasonable.
    What all should be done or looked at? Some also say the water pump. Any kind of checklist some expert has here?
    And so many different sources, would love some definitive full fledged videos -- "here, this to clean the EGR & intake. This for the piston soak"
    @Mendel Leisk if I may?
    Looking forward to feedback from the community! A very happy first time prius owner - getting double the mpg of my 05 camry.
  2. JC91006
    JC91006 Senior Member
    16,761
    8,562
    Do you have any repair history on this car? You can run a carfax to see if there are repairs/maintenance that has already been done, so you don't have to repeat them. 155k miles, many things should have been done already
  3. swordsx48
    Los Angeles
    I have the carfax, from what's there, basic maintenence, oil changes, cabin air filter, engine air filter, tire rotation and eventual replacement, etc. Also cat shield in place.
    Let's say none of the ones out of ordinary maintenence above was done. What would you recommend?
  4. Brian1954
    Brian1954 Senior Member
    2,138
    828
    South Central PA, USA
    Yes, for engine water pump replacement. Also, be prepared for the head gasket going bad in the next 10k to 45k miles.
  5. swordsx48
    Los Angeles
    Water pump, just grab another one on ebay? Or that could be susceptible to going bad too?
    On head gasket, the thought process & common sentiment was that cleaning the egr can help mitigate head gasket issues
  6. bisco
    51,840
    congrats and welcome!
    merv has your back:
    watch
    all the best!
  7. Mendel Leisk
    41,313
    The top two links in my signature are EGR related (on a phone turn it landscape to see signatures). Also recently added an EGR cleaning workflow, here.
    At your miles, I wouldn’t look at EGR cleaning as a “get out of jail for free” card; it’s late in the day to start with this. Unfortunately, it’s just about the time head gaskets start letting go, so tread cautiously, don’t make any major investments in it for the next few months; just deal with the EGR, then wait and see for a bit.
  8. rjparker
    10,078
    6,243
    B12 or other piston soaks won’t help a gen3 Prius burning oil because of their low tension piston ring design flaw. Save your money for a rainy day fund.
    Try to avoid dealer repairs. Sometimes their diagnostics are ok but their repair costs are often 150-200% higher. Do find and use an independent hybrid shop before you need it. 5k mile oil and 50k mile coolant changes are your best bet.
  9. JC91006
    16,761
    8,562
    At 155k miles, I would go for the full works. Try to get parts from the dealership or rockauto. Ebay has a lot of fake parts
    1. plugs
    2. pcv valve
    3. change coolant
    4. change transaxle oil
    5. change brake fluid and check brakes
    6. change water pump (you can get away with changing the rotor only or if you want to splurge change the pump using OEM pump)
    7. clean throttle body
    8. clean entire EGR circuit
    I wouldn't overly invest too much money on this car. Since it's burning a lot of oil and it's nearing it's head gasket replacement time (anytime over 150k miles). I would just do simple basic needed maintenance.
  10. swordsx48
    Los Angeles
    Wow did not get email notifications for these latter comments:
    @Mendel Leisk thanks for the info..thinking the EGR cleaning could delay the head gasket issues. I believe it also depends on driving habits and, I haven't seen any other issues with the car. What when head gasket goes, new engine, or the head gasket can be replaced? Tried landscape, couldn't see links, will try on a computer
    @rjparker it seems the b12 soak, if done myself, should be less than 50 bucks altogether. It seems to have fixed oil consumption issues for a lot of gen 2 and gen 3 folks. If anything, could help just take care of the car altogether.
    @JC91006 1, 3, and 5 done. 6, 7, and 8 are in the plans with how often I've heard them.
    How urgent would you say 2 & 4 are? And the water pump? Water pump first or EGR cleaning? Also is throttle body cleaning usually considered part of the EGR cleaning? That must be the intake manifold am I right? But throttle body cleaning I believe isn't too bad, think I did it on the camry before.
    Also going to clean MAF sensor. Is PCV a replace or clean?
    Thank you so much all. Hoping to delay those head gasket issues and get good use out of this car! By the way, what will be the signs when the head gasket goes? Or is it just all of a sudden and you know hahahah
  11. JC91006
    16,761
    8,562
    2. PCV valve is easy and it could be part of the reason why you're burning so much oil. You would normally do this along with the EGR circuit clean, the removing of the intake manifold would expose the location of the PCV valve.
    4. Transaxle fluid - this is not urgent since Toyota considers this to be a lifetime fluid. But we all know there is no such thing as a lifetime fluid.
    I would tackle the water pump, throttle body cleaning, and EGR circuit at the same time. The water pump is actually very important to change out as it could fail and you could end up with an overheat condition that ultimately leads to (contributes to) a head gasket failure. Since you've already changed your coolant, you would just drain and fill that coolant back into your system during the water pump change.
    The bad news hasn't really been shared with you yet. These cars tend to have 3 big failures. 1. Brake booster pump, 2 Head Gasket, 3 HV battery. Any of those 3 items will cause you some big problems and are big ticket items. So hopefully you can put away some money in anticipation for when those repairs are needed.
  12. swordsx48
    Los Angeles
    How common is the brake booster issue?
    From my understanding, there was nearly a recall on it, but instead a CSP.
    Seems there's water pump, head gasket, brake booster, & hybrid battery. If there's those or any that goes around 1000 bucks or more, it'll basically defeat any gas savings I achieved.
    So @JC91006 from your words and others, you've almost scared me into selling it
    For comparison, we had an 05 camry, purchased new, & it never gave us any issues except once the alternator needed to be changed, less than 300 bucks. And a MAF sensor check engine light which we cleaned ourself. All the way to 170k miles. Nothing major.
    Here if I save 100 / month on gas, but have a problem like this, it's not going to be worth it - not to mention some of those are well over a grand or over a year of savings.
    Showing no signs of brake issues but, I hear it just happens all of a sudden. It's running great now & getting 50mpg after the piston soak but, could sell it while it's good...
    Thoughts?
  13. ASRDogman
    ASRDogman Senior Member
    7,541
    3,893
    Don't let some people scare you. Because they had issues they want others to share in
    there misery... And it makes them feel better if they can scare others. EVERY car has issues.
    I'm at 360,xxx miles on my 2010 and no issues with the brakes. I know sooner or later I will
    need to replace those parts. It's 15 years old! With a LOT of miles. I replaced the head gasket
    at 301,000 miles. And the hybrid battery 6 months or so back. Even with all that it's a LOT less
    than a new car, or even a used car.
    If you can do the work yourself, no labor cost. That usually about 75% of the cost of repairs.
    If you listen to the brake pump, and how often it runs, that will usually give you a heads up on
    if it's starting to go. When I bought my Prius in 2017, it ran every 35 second or so. Some on here
    said it was going to fail anyday. 7 years later, it's cycling every 25 or so seconds....
    Yes, some have just failed, seemingly without warning.
    I drive 85% highway miles, as the previous owner did. Those who drive mostly in the city, seem
    to have more issues sooner, like the head gasket.
    So ENJOY your Prius. If/when an issue arises, repair it. There are more people NOT having
    issues then there are that are. Some people think that they should never have any problems.
  14. rjparker
    10,078
    6,243
    Since you already bought the car, the easy option to avoid it has past.
    B12 can't help a car with low tension rings as the block gets damaged quickly. Usually you hear "it went from a quart every 800 miles to a quart every 1300 miles." Many controlled tests have shown no improvement. Early on Toyota replaced pistons and rings for free. Low tension ring oil burning was widespread on many Toyota models through 2014. It also clogs catalytic converters, another big expense.
    Brake boosters are difficult and no aftermarket options exist. It requires a tricky flush and calibration with Techstream. Many diy replacements fail at this step.
    Head gasket fails on an oil burner means another engine. This has become expected on gen3s and the problem had revised parts and software thrown at it by Toyota. No help until the gen4 engine redesign that was successful and is essentially still used today.
    Inverters suddenly fail and strand you. A class action suit on this may cover you but that's small consolidation if you can't trust the car any distance from home.
    Water pumps are the least of the problems. Timing chain oil leaks are common.
    Almost anyone with experience with these would have warned you to avoid if you asked up front. As is you can install JDM or rebuilt engines, have a quality independent do the brake booster and stay close to home so the inverter does not strand you badly.
    It is possible to spend $10k to keep a used gen3 100%.
    #14 rjparker, Dec 7, 2024
  15. ASRDogman
    7,541
    3,893
  16. swordsx48
    Los Angeles
    the easy option yes, but I can still sell it and get what I put into it + a fair amount for the work I put in. Just heard about the inverters too.
    I think I will, and get a more typical gas Camry or something slightly heavier with less road noise, like an ES 330
  17. ASRDogman
    7,541
    3,893
    Another one bites the dust...... fear!
  18. swordsx48
    Los Angeles
    I particularly avoid that in my day to day life. I see it more as calculated risk. None of the things could go bad, or all of the things could go bad.
    Seems there's
    - Water Pump
    - Hybrid Battery (normal use)
    - Brake Booster
    - Head Gasket
    - Inverter
    A question for everyone: does changing the water pump and cleaning the EGR strongly prevent the head gasket from going bad? In that case, I could replace the water pump pre emptively, clean the EGR, and essentially knock off two things from the list. Then I would only have the brake booster and inverter really, that could go bad unpredictably.
    But if that doesn't strongly prevent the head gasket from going bad, and there's 4 big ticket things that could go bad anytime (excluding the hybrid battery) then yeah I'll sell it now while it's running excellently
  19. ASRDogman
    7,541
    3,893
    No, But it "might" slow it down.
    You didn't say what type of driving you mostly do, city or highway.
  20. Leadfoot J. McCoalroller
    8,069
    7,552
    Pennsylvania
    2018 Prius c
    Not enough data available. Not enough to bank on, anyway.
