SPARE TIRE MOD FOR LE FWD model using factory foam
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Humble Bear, Oct 17, 2024.
  1. Humble Bear
    Humble Bear Member
    125
    44
    Arcadia, CA
    2024 Prius
    SPARE TIRE MOD FOR LE FWD model using factory foam (does not apply to other trims):
    1) The LE's trunk floor is lower than the others so are the thinner styrofoam platforms unlike other trims where you can just cut a round hole to fit the spare. You will need to add some height around 2.8-3" at various spots to make it level with the spare tire.[​IMG][​IMG]
    2) Purchase factory spare tire wheel & tightening bolt(carrier) + 145/90/16" spare tire. You will need to put a piece or 2 of 2x4 below the tire at the very end to make the tire level front& back so that the tightening bolt can make an even contact. This is very important; I repeat, it's very important to tie down the spare tire securely, because you don't want it to hit the electrical wires & connections behind the rear seats or have it thrown at the passengers/driver in a serious accident. I wish the bolt is shorter so I can mount the spare upside down which also make it more secure.
    3) I was able to find a used jack & tool kit from a used Lexus ES330 for $25 and tested it. upload_2024-10-17_17-6-7.jpeg
    3) Cut a big round hole to fit the spare tire. I used a filet knife which works great without making debris. Note that the spare tire will stick out about 2.9" above the styrofoam.
    4) Bought some 2.9"x2"x6" foam blocks from Walmart($2/ea) which is the perfect height without too much modification and glue them at various places using a hot glue gun. I also modified the jack tool kit to fit into my car by cutting a notch at the corners. upload_2024-10-17_17-7-12.jpeg
    I noticed 2 advantage of doing this mod vs getting the factory conversion kit: (a)Because I am using the original foams, those black plastic fastener pins can still pin the foams to the car tight vs if you order the conversion kit from the dealer, those plastic pins would not reach the holes so they are just loose. (b)the trunk floor is about 1.5" deeper than the factory conversion kit, judging from the pictures of the other member's post. Overall, It works well and for very little money.
    I want to thank everyone especially Hammersmith for his posting of the very useful thread, and here is my contribution & sharing and hope other people can benefit from it. I decided to create a separate thread specifically for the LE model because that thread is 18 pages long with 300+ replies and it included many different applications for different trims and it's very hard to sort things out and remember all. God Bless!
    #1 Humble Bear, Oct 17, 2024
  2. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    Nice howto and explanation about why you started the thread. The more you add to the forum the easier it gets to sort stuff. All the different model and Gen advice can get boring beyond words can describe much like trying to figure out which model the owners manual is describing and questioning if the model you own even has the feature it's describing.
    I just put one of my snows or OEM's in winter behind the drivers seat. I'd seriously dislike having to use the OEM jack in winter to change a flat or blowout. Might want to double check how tight your wheels are to the hubs after 10 or 15k miles. My OEMs stick to the hub like nobodies business. I'll eventually fix that but probably after I'll need extra tools to get the wheels off. I seriously hope yours don't get the galvanic build up like mine get after 2 or 3 k miles, adding to the distaste for the OEM jack even on solid pavement.
    #2 vvillovv, Oct 17, 2024
  3. bisco
    51,041
    well done! looks professional
    Pierre_Coop and Humble Bear like this.
  4. Atharv95
    Atharv95 New Member
    India
    2020 Prius PHV
    Active
    I totally agree with you—sorting through all the model and generation advice can get repetitive, especially when you’re trying to figure out specific features. Also, good tip on checking wheel tightness. That galvanic build-up issue is frustrating, and it’s definitely something to watch out for with OEM parts.
  5. Mendel Leisk
    40,497
    Put a few smears of anti-seize on the hub face and spread it uniformly with an old toothbrush. Very thin is all that’s needed.
  6. Humble Bear
    Humble Bear Member
    125
    44
    Arcadia, CA
    2024 Prius
    Actually, I can tighten it real good and the recess in the hub makes the hub sits pretty secure. But because the bolt attached to the plastic knob is long but skinny I just wish that it's thicker/bigger.
  7. Humble Bear
    Humble Bear Member
    125
    44
    Arcadia, CA
    2024 Prius
    3) I noticed the 3rd advantage: I believe the spare tire will also make your car quieter because the Prius has very few sound deadener but the spare tire when tightened to the bare metal trunk-well floor actually creates a sound deadening effect.
    I also applied the sound matt to the bare rear doors when I changed the speakers, I will do the front doors next.
    Gary Van Meter and bisco like this.
  8. PriusPilot84
    PriusPilot84 Junior Member
    Michigan
    2024 Prius
    I just did the same with my XLE. I didn’t want to spend the money on the factory foam so I modified the existing foam. Took a few hours and mistakes were made but I’m happy with it. All I purchased was the spare kit from EZ spare, and the center bolt that holds the spare down.
    zare34 likes this.
  9. Humble Bear
    Humble Bear Member
    125
    44
    Arcadia, CA
    2024 Prius
    Looks like the XLE's foam is a lot higher than the LE's and even higher than the spare tire. Did you install a jack? What size is the spare? I wonder if you can put in a stock tire size.
  10. Mendel Leisk
    40,497
    From page 524 of the Owner's Manual:
    Try it?
  11. Humble Bear
    Humble Bear Member
    125
    44
    Arcadia, CA
    2024 Prius
    That is factory spare and what I use, but his is aftermarket...
  12. Mendel Leisk
    40,497
    Tires are tires. There's very likely a Toyota spare tire rim, though.
  13. Perfectpacman
    Perfectpacman Junior Member
    74
    United Kingdom
    2024 Prius
    ----UK----
  14. PriusPilot84
    Michigan
    2024 Prius
    165/70/17 from ez spare wheel .com. Their jack and tool kit fit securely under the tire and don’t move.
  15. NJW
    NJW New Member
    Philadelphia
    2024 Prius Prime
    XSE Premium
    Thanks for all of this valuable info. I'll be looking into doing this in the near future.
  16. zare34
    zare34 New Member
    Southern California
    2024 Prius
    What’s with the green tape. Did the styrofoam break while you were cutting it or is it for reinforcement?
  17. RichFilmaker
    RichFilmaker Junior Member
    Waukesha
  18. RichFilmaker
    Waukesha
    What size bolt (and threading) is it that holds down the tire?
  19. Humble Bear
    Humble Bear Member
    125
    44
    Arcadia, CA
    2024 Prius
    It's a factory tie down bolt that I got it from the local dealership.
