Fitting mobility 12volt AGM battery.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Britprius, Mar 3, 2013.
  1. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    Has anyone tried the Mighty Max brand of battery sold on Amazon? I am considering this one. 55AH, 9.06"L x 5.43"W x 8.98"H(8.19"h not including vertical 'flag' posts) I need to measure the actuall width of my original OEM 45 AH battery to see if the 5.43" width is OK.
    Mighty Max Battery 12V 55Ah Power Boat Pontoon Electric Trolling Motor Deep Cycle Battery. (4.6 Stars 1603 reviews) $118.79
    This next Mighty Max battery looks identical. Both pictures show the same specs and Model ML55-12 is shown on the casing. It just does not mention Trolling Motor in the Amazon description.
    ML55-12 - 12 Volt 55 AH, Nut and Bolt (NB) Terminal, Rechargeable SLA AGM Battery. (4.4 Stars 291 reviews). $119.99
    Ah, I see the first battery is shipped from and sold by Mighty Max. The second battery is shipped from and sold by Amazon.
    I have no complaints with the OEM battery. It has lasted since we bought the Prius Plug-In new in 2013. But my wife does occasionally leave interior lights on, so, I'll take the extra AH's for a replacement battery and ≈ $60-$100 US $ cheaper than Walmart or a Toyota battery respectively. ;)
    EDIT: I pulled the original 45 AH GS Yuasa Corp OEM battery and measured it. 9.16" L x 4.75" W x 7 7/8" H (case not including posts). The Mighty Max above from Amazon's case is 3/8" taller (should not be an issue). It's case is just under 3/4" wider. To accommodate the extra width, I simply drilled 3 new mounting holes through the bottom of the black bracket 3/4" further to the inside, so the bracket is now 3/4" further away from the metal wall on the opposite (inner) side of the battery. I noticed that I will need to also drill another hole on the top of the bracket where the threaded rod ( rod has enough extra thread for the bracket to be higher) from the bottom bracket needs to poke through the 'over the top bracket' to accept the nut that holds it down. I will add a spacer and a longer bolt on the inner side of the bracket where it bolts into the sheet metal.
    I'm just ordered the first battery above. It is due to arrive between June 26 to 28.
    #581 davekro, Jun 20, 2024
  2. Tombukt2
    13,006
    2,330
    Yeah why not If it fits and you can get the terminal sorted out You're good to go people are running elevator batteries and all kinds of things for the 12 volt shouldn't really be an issue The more you leave it on and run it down the more often you'll replace it no matter what it is
  3. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    My installation details: Mobility/trolling motor battery to replace my OEM 45 Ah 2013 Prius Plug-In battery
    Myself, liking to know all the details before I decide to do a modification like this, I wanted to post the details of my installation here in case it is helpful or of interest to others considering this mod. Note, the data and mods are for this specific battery, which will be different for what ever battery that you should choose. But hopefully it's helpful in what details to account for.
    I used this battery:
    I took all of the actual dimension measurements of The Mighty Max 55 Ah mobility battery (and the OEM 45 Ah as well). It arrived yesterday and I installed it. Measuring the two batteries, the new 55 Ah battery was closer in size than I originally thought (see the yellow note in images for every dimension for both batteries).
    This new battery was:
    1) 5/16" shorter in length, so no modification needed for bottom bracket for front to back length.
    2) 7/16" wider at the base, but I only needed to elongate the brackets' three mtg. screw holes 1/4" to allow bracket to slide right 1/4" for the battery to fit w/o being too snug.
    3) The new battery's case height was 1/8" higher, but its 'Flag posts' were shorter than the OEM posts, so the over all ht. was ≈ 1/16" less.
    4) I used a 3/8" thick oversized nut glued over the left threaded mtg. hole on the left side as a spacer for the left side of the top clamp bracket.
    5) With battery in place, I pulled/ bent the right threaded top bracket mtg. post in ≈ 1/4" inward to align with the existing right side hole of the clamp plate bracket.
    6) The small device (sensor of some sort? heat? fumes?) that clips into the top of the top clamp bracket still fits, height wise, but I can tell that the bin/tray that snaps in on top of the battery, is help up just ever so slightly (barely), but the top of that device. I just now thought that the area of the bracket where the device snaps into, could probably be hammered down ≈ 1/16" so as not to be in contact with the bottom of the bin/tray. The devices' slight contact does not feel like any issue at all, so I doubt I'll bother to do my 'hammer down' idea.
    Mounting OEM Pos. and Neg. clamps to the battery:
    7) The Flag Posts edges are rounded and tapered to accommodate a 3/4" round post clamp (the round OEM clamps are way too small to fit). The Pos. and Neg. flags are the same 3/4" width and .4" thickness.
    8) I wondered if there was a 3/4" round to smaller OEM (JIS?) adapters available, but decided not to wait days for parts, if even available, to finish the project. I went ahead and used hardware that I had on hand to through bolt the clamps to the Flag posts using longer bolts and modifying to nuts to use as spacers so that I did not need to squish/deform the OEM clamps and also proved the best electrical contact possible. I know there is not high amperage through these connections, and just bolting the OEM connectors angled with less contact would be a non-issue... But hey, I'm a perfectionist and feel good doing it this way. ;)
    a) I used two square 1/4-20 nuts, drilled threads out w/ 1/4" bit for OEM diameter metric bolts to fit through for between the clamps and the flag posts.
    b) For spacers between clamps I used a large flat washer ground on four sides for the + side and 1/4-20 jam nut (drilled out) for a spacer on the Neg. side.
    c) ≈ 1 1/2" bolt for + side and ≈1 1/4" bolt for Neg. side.
    I feel good about a clean install and less concern for when my wife leaves interior lights on overnight, or until she drives next. ;)
    R-P likes this.
  4. Tombukt2
    13,006
    2,330
    That's interesting I only pay like 169 for a Sears die hard blue AGM the latest I guess looking thing so I would be doing this to save 50 bucks I think I'll just stay with the car rated battery just because I already have it and it's not time to change and 50 bucks is well I guess 50 bucks
  5. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    The main reason I chose this 'non-car' battery was the larger capacity of 55Ah, vs 45Ah for the OEM battery. This is my wife's car. Several times over the life of the original (2013) battery, she has left interior lights on that caused it not to start. I figure maybe the ≈18% larger capacity will be more forgiving of these incidences. Maybe so, maybe not, but that was y thinking. To me, the lower price was just a nice bonus. YMMV
  6. Tombukt2
    13,006
    2,330
    Yeah maybe fit some LED bulbs in the overhead lights that goes a long way in not sucking down the battery also.
    davekro, PriusCamper and Brian1954 like this.
  7. PriusCamper
    PriusCamper Senior Member
    12,777
    5,177
    Pacific Northwest, USA
    Those are the lights that tell me my battery needs charging... They get real dim once you drop below 12volts... :)
  8. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    I never thought of that, great idea. I have changed the bulbs in my work truck and our camper trailer to LEDS. I will change her Prius's interior bulbs to LEDS. Thank you!
  9. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Are you speaking of the OEM incandescent bulbs? I think LEDs don't dim much, they just shut off when voltage drops to a certain point while incandescents just get dimmer.
  10. PriusCamper
    12,777
    5,177
    Yea... as @Tombukt2 points out those old incandescent lights suck alot of energy out of a 12v battery.
  11. Henryk
    Henryk Junior Member
    New Jersey
    Anyone have any thoughts on the follolwing LifePo4 to replace the 12v battery. The only downside I see is the no charfging below 32 degrees. But with 100ah I don't see that being an issue considering it's function. Also available in a group 24 size, and with a bluettorh app option to monitor it.
    Thanks for any feedback
  12. PriusCamper
    12,777
    5,177
    It really depends on what you're using your vehicle for... This is a great price and a great battery if you were, for example, using an inverter to power your house during a power outage. It would be essential to have some heat for it in sub-frezing temps. And you'd save on gas in your Prius because it would cycle way less often and re-charge faster when it does cycle compared to a regular 12v
    But not needed if you're just using your car as a regular drive around town kind of thing because the only thing the 12v battery does is turn the computers on and some relays and once the High voltage battery powers up the only thing the 12v does is sit there and take a super weak 14v charge from the high voltage system.
    Henryk likes this.
  13. pasadena_commut
    pasadena_commut Senior Member
    2,651
    789
    Southern California
    With batteries like this one:
    https://www.ebay.com/itm/141206981871
    which have threaded holes for the electrical connections, what keeps the bolt that goes in that hole from working its way out from vibration? Most places one uses a bolt on a car that bolt is going into metal and it can be torqued to an appropriate spec and it will stay in there forever. However, these battery terminals are set into plastic and the torque which the bolt of that size would normally require to "stick forever" may be more than the plastic can take, or at least, more than it should be exposed to, even if the metal insert itself would be OK with that much force.
    Also, since that battery was recommended somewhere in this very long thread, where is its vent port? It should be visible in the first picture, but I don't see see it there or elsewhere. Odd for a VRLA to have no place for the "V" to go.
  14. Tombukt2
    13,006
    2,330
    Vent port sealed system like new HV versus old HV in our cars no vents . Ya no need it lockessher under socket head cap screws like a motorcycle or power sports . If it don't come loose on my motorcycle . You have no chance I have of what you speak zero.. like side terminal mounts GM been using 54 years it's just on top now .
  15. PriusCamper
    12,777
    5,177
    The vent port is covered in a thin film of plastic that is the first thing to fail if there's internal pressure inside the pack. It makes it difficult, but not impossible, to attach a vent tube. But truth is the location of the 12v inside of the car is right next to an exterior vent. And there's no documented proof of thermal runaway of a 12volt inside a vehicle poisoning the people inside. Though there's was one incident on the new jersey turnpike where they couldn't rule it out as the source of the fatality.
    As for the vibration and bolts coming loose, that's never been an issue on the ones I've installed as the depth of threads and thickness of plastic hold everything together quite well.
  16. pasadena_commut
    2,651
    789
    Southern California
    Lots of things come covered in a thin film of plastic - which the user is expected to remove before use. For instance, oil filters and cell phone screens. A piece of plastic on the outside of a battery can't possibly be the valve itself, it would be much too easy to damage accidentally. So I'm gonna go out on a limb here and guess that it is actually the second thing to fail, after the internal valve.
    Is the plastic glued down all the way around the hole? I ran into something like that once, although I cannot for the life of me remember what the device was. The solution was to use an appropriate sized drill bit by hand to remove the film and a tiny bit of the case so that the plug would fit in with no interference from the plastic film.
    #596 pasadena_commut, Sep 13, 2025
  17. PriusCamper
    12,777
    5,177
    Nope... Thermal runaway in 12volt AGMs are incredibly rare/non-existent, especially with the weak sauce amp charge Toyota sends to the 12v. So basically if the battery is about ready to explode that hole explodes before the rest of the structure.
    And yes, there was someone on here who once drilled it out to insert a hose and he damaged the casing on the top of the battery and all the annoying naysayers about ventless 12volts who instigated his behavior turned against him and made him feel like the damage he did to his battery was way too dangerous to continue to use.
    In other words if we were talking about a 12v or 24v system capable of handling up near hundred amp or of over loads on a recharge we could haven an intelligent conversation about venting and other safety features. But when Toyota's DC to DC converter is sending a truly miserable and pathetic tiny amp charge to the 12v the more serious problem is a lack of charge for a discharged battery, rather than so many amps that there's a risk of failure and venting.
  18. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Very emotive language you use. Is it backed by any imperical evidence? If so, what are the values use by the DC/DC converter?
  19. PriusCamper
    12,777
    5,177
    Here are several good articles & technical pieces about EV/hybrid 12-volt battery / 12V-subsystem charging problems, plus a summary of key issues and take-aways. If you like, I can pull full text (if open-access) or PDFs.
    Notable Articles & Sources
    Title Source Key focus / what they cover
    Why Is My Electric Vehicle Dead? Check the 12-Volt Battery LiveMint EVs (Hyundai, Rivian, Cadillac) failing due to 12V battery dying unexpectedly—even when main HV battery is fine. Includes discussion of software & hardware draining the 12V battery. mint
    Factors that Affect 12V Battery Life in EVs Midtronics How environmental factors (temperature), accessory load, driving pattern, type of 12V battery (lead-acid vs lithium etc.) affect lifespan. Midtronics
    Why do 12V batteries cause EV breakdowns? Ecobat Battery Statistical data on breakdowns; explanation of ECU/BMS role; parasitic draw, “always-on” systems; challenges of balancing vehicle range vs sufficiently charging/maintaining the 12V battery. Ecobat Battery
    Toyota Sued Over A Recurring 12V Battery Problem That Kills Its EV Carscoops / Batteries News Case study and legal/consumer consequences: bZ4X / Solterra models having repeated 12V battery failures; warning lights, complete shutdowns. Carscoops+1
    Vicor Proposes Architecture to Eliminate 12V Battery from Electric Vehicles IEEE / Vicor Proposals / technical architecture to remove the conventional 12V battery entirely—using DC-DC, or higher-voltage auxiliary, or virtual battery / power delivery networks. IEEE Power Electronics Society
    Warning over 12-volt battery on electric vans ‘suddenly’ draining Fleet News Particular to e-LCVs: frequent failure or drain of 12V batteries even while plugged in; fleet operational consequences. GB News+1
    Key Problems Identified
    From these, here's what commonly shows up as causes, failure modes, or risk factors:
    1. Parasitic Drains / “Always-On” accessories
      Systems that remain active (connectivity modules, sensors, remote wake-ups, alarm, etc.) can draw from the 12V battery even when “off”. EVs tend to have more electronics, more frequent remote wake events etc. Midtronics+2mint+2
    2. Reduced charging of 12V from the high-voltage system
      The 12V battery is typically charged via a DC-DC converter from the main HV battery. But this converter may shut off or reduce output when HV battery charge is low, or for safety/thermal/efficiency reasons. So if the HV battery frequently is run low, or parked for long periods, the 12V may be undercharged. Midtronics+2Electra+2
    3. Temperature & climate effects
      Extreme cold reduces battery capacity; heat accelerates degradation. The 12V battery is more vulnerable because it often sees shallow but repeated discharges. Midtronics+1
    4. Aging / battery chemistry issues
      Traditional lead-acid (or AGM) batteries degrade with age, charge/discharge cycles, partial state-of-charge, sulfation etc. Some manufacturers are moving to 12V lithium to reduce weight & improve longevity. Midtronics+2Vicorpower+2
    5. Software / hardware faults
      Firmware glitches, improper sleep states, modules not shutting down, high drain even when vehicle is idle. mint+2Ecobat Battery+2
    6. Operational patterns
      Vehicles parked for long periods; frequent use of “accessory mode” or remote services; fleet vehicles often being left idle or used in stop-start/delayed charging ways; vehicle sitting plugged in but 12V not being topped up because DC-DC is inactive. Ecobat Battery+2GB News+2
    Possible Solutions & Design / Policy Responses
    • Moving away from lead-acid / AGM toward lithium 12V batteries. Vicorpower+2Midtronics+2
    • Better DC-DC converter design / ensuring that 12V always gets sufficient trickle/top-up, especially when HV battery is near lower thresholds.
    • Improved software to reduce parasitic load, better sleep modes, limiting remote wake events.
    • Alternative architectures: eliminating the 12V battery altogether and using virtual or solid-state power delivery from HV system + DC-DC converters. IEEE Power Electronics Society
    • More frequent checks of 12V battery health; monitoring for voltage drops etc. Carnex Blog+1
    If you want, I can compile a list of technical papers (not just popular press) on this topic (battery-management, DC-DC behavior, etc.). Do you want that?
  20. dolj
    dolj Senior Member
    8,450
    4,291
    Looks like you used an AI generator. What was the query question you used? It has a lot of general information about EVs, but I don't see an answer to the specific question I asked about the values in regard to Gen 2 Prius.
