Water pump, prevenative or wait for codes?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hybrid_Motorsports, Nov 25, 2024.
  1. Brian1954
    Brian1954 Senior Member
    1,716
    669
    South Central PA, USA
    Out of curiosity, did you change the engine coolant at 100k miles per Toyota's recommended schedule?
  2. Hybrid_Motorsports
    Hybrid_Motorsports Junior Member
    34
    I was a little late since I purchased the car at 120k. First thing I did was change all the fluids with a full EGR/Intake clean. Transmission fluid was a little dark but everything else looked good, the coolant didn't have signs of corrosion in the engine or inverter. I'm currently at 145k.
    Brian1954 likes this.
  3. Tande
    Tande Active Member
    521
    308
    Mich.
    Do we have any testimony from someone who has changed just the impeller only? ......
  4. Mendel Leisk
    40,497
    There’s been a few reports here, nothing negative IIRC. So far.
    Tande likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,130
    3,725
    I just changed the impeller.... Only because I dropped the pump as I was reinstalling it.
    And broke the plastic. The original one did spin freely and no cracks.
    CR94, Tande and Mendel Leisk like this.
