Prius heater not getting hot enough!
Discussion in 'Gen 3 Prius Main Forum' started by Chester92, Nov 30, 2024.
  1. Chester92
    Chester92 New Member
    27
    Los Angeles
    Thank you
    I dont want to work on the radiator lol but what else could cause the radiator hoses to be cold? We already tried another water pump, thermostat, and everything seems to be working well but the coolant will not flow into the radiator it seems. The degas bottle is under a ton of pressure after a few minutes of driving and coolant is leaking out of the tank overflow as its pressurized
  2. Bill Norton
    Bill Norton Senior Member
    2,126
    725
    MONW, Ks.
    First- just for reference: It's a Coolant Reservoir. There is no gas to 'degas' in the coolant.
    Second- if the radiator is clogged with 'leak-stop' , you can bet the heater core is also full of that crud.
    You might have some luck back flushing just the heater core hoses with the vinegar solution, but try to monitor the amount of pressure your using with your garden hose. 15psi is typical for cooling systems. You might be able to use 20psi on the heater loop.
    While you're tooled up to do this 'back flush work', you might as well get it set up to flush the radiator also. Could save you the work of replacing it, or not. You might find you have minimal flow through both units. ,,, Sorry.(n)
  3. ASRDogman
    ASRDogman Senior Member
    7,114
    3,713
    If it's not flowing INTO the radiator, you have a blockage.
    Take the upper hose off and see if the passage on the block is blocked.
    Did you look at the ports behind the coolant pump? Maybe they are blocked.
    And look into the radiator, you'll likely see it all clogged.
    Seems like you ruled out the thermostat and coolant pump. A clog is the only
    other option.
    Bill Norton likes this.
  4. Bill Norton
    2,126
    725
    MONW, Ks.
    Another job for a cheap borescope!
    If you had both hoses disconnected from the block you could try the ol' Lip Lock method of 'feeling' if it's clogged or flowing. :sick:
    Or try to get flow to go through it from a garden hose.
  5. Chester92
    27
    Los Angeles
    Thank you everyone.
    Could it be possible that there is air trapped in the system and the radiator and heater core is actually good and NOT clogged even though the coolant reservoir is over pressurized?
    Also when you refer to the upper radiator hose you mean the small upper corner hoses that are about 1" diameter or the 2" diameter hose thats near the bottom?
    I disconnected both large hoses and will try to get a garden hose to flush from the top smaller hoses through them
    Trying to see all possibilities before tackling this project as i see it is kind of a headache to swap radiators.
  6. Brian1954
    Brian1954 Senior Member
    1,703
    664
    South Central PA, USA
    If coolant is being released out of the overflow on the reservoir (degas tank), the engine is overheating. I say you still have a problem with the water pump working properly. Start by monitoring the coolant temperature. See post #23.
  7. ASRDogman
    7,114
    3,713
    :unsure::(:confused:
    With the larger hoses off the radiator, block the lower hose fitting.
    Then you could fill the radiator, then remove the lower hose fitting. The water should
    dump out pretty fast.
    Then try to use the hose to clear out every passage you can.
    When you fill it back up. Fill very, very slowly, a small account at a time. It will take a while,
    but by pouring slowly, the coolant will be able to push out the air. Fill to the B line on the tank.
  8. Chester92
    27
    Los Angeles
    The prius is currently without coolant as i was going to swap the radiators or try to clean mine out so i cant check the temp just yet.
    Id like to try your method with the radiator but im a bit confused as to what hose.
    There are 4 total hoses so did you want me to just fill the radiator and check that it leaks out without restriction? Seems like the small hose above the larger ones work together?
  9. douglasjre
    douglasjre Senior Member
    2,087
    698
    Null, NL
    Whats the story on The Late Model JDM engines?
  10. rjparker
    9,498
    5,815
    The story is Toyota made the Prius v/+/alpha for European and Asian markets through 2021. Since JDM engines are from Japan there is a chance some of them could be 3 years old. Of course they don't put them through the miles or loads we do so those gen3 engines are probably as good or bad as a 2016/17 US Prius v engine when they were three years old, generally excellent with no obvious problems or oil burning. By then Toyota had updated gen3 head gaskets, intakes, egr valves, brake boosters, inverters and ecm software.
    douglasjre likes this.
  11. Chester92
    27
    Los Angeles
    Update for everyone
    I ordered another water pump as i tried to flush out the cooling system but the water pump started squealing loudly. Took the pump off but it looks fine. This would have been the 3rd aisin water pump and this had less than 20 miles on it.
    The radiator didnt look clogged and the heat worked on and off when i tried removing the T hoses into the heater core area which makes me wonder if its really the water pump thats not working correctly?
    Coolant temp remained cold at the radiator and nice and hot up by the T valve hoses after only about 10 mins of idle
  12. rjparker
    9,498
    5,815
    Even the cheap water pump knockoffs last more than 20 miles. Probably closer to 20,000 miles.
    Hopefully the thermostat is working. If it was failed closed you would never get flow through the coolant reservoir.
    The T hose is on the output of the heater. It feeds the egr cooler and exhaust heat recirculating system.
    I imagine you get a lot of flow through the reservoir tank once the thermostat opens. Those two reservoir hoses and the coolant reservoir bypass the radiator.
    So you could have a blocked heater, blocked radiator and or continuous "air" being pushed into the coolant system by a bad head gasket leak.
    #52 rjparker, Dec 25, 2024
  13. Paul Gregory
    Paul Gregory Senior Member
    1,371
    356
    Alberta
    2024 Prius Prime
    XSE
    I had a 2012 Prius, and I lost interior heat when it got really cold. I paid a guy to put some cardboard ahead of the radiator, and that solved the problem completely. It was toasty-warm inside after that.
    It's an old trick up here, and normally you have to remove the cardboard in the spring, but that takes some disassembly on the gen 3, so I didn't bother. Turns out, that when you leave a gap of a few inches between the rad and the cardboard, you won't have any overheating problems in the summer. The fan takes care of that. That's why I did the same thing with my Gen 5. This is my second winter with it and it works great.
    I've heard about automatic radiator shutters on the gen 5, but I don't see them on mine.
    Wonder likes this.
  14. Chester92
    27
    Los Angeles
    How can i go about clearing the problems? I am waiting on a toyota water pump and will check if that fixes the problem otherwise i will try to rule out the radiator as the hoses do not get hot on the lower radiator
  15. Chester92
    27
    Los Angeles
    My problem is more about why the coolant isnt flowing properly now. The cabin heat came back as i opened the T hose connections but the car will overpressurize the coolant reservoir
  16. ChapmanF
    17,185
    I think those showed up in gen 4. ToyoDIY doesn't seem to have gen 5 data yet, though.
    Seems to exist in gen5 too.
  17. rjparker
    9,498
    5,815
    1. You know you have air in the system
    2. You know you have air in the system and it comes out when you open the heater output. Once the air is out you get flow and btus from the heater.
    3. Flow is not going through the radiator. Clogged radiator or poorly installed thermostat if water pump is functioning. The coolant reservoir hoses bypasses the radiator. No radiator flow guarantees an overheat.
    4. The engine had a blown head gasket which will pump combustion gasses ("air") into the coolant. If the repair was poorly done (warped head, block, bad head bolt torque) you can easily have a leaking head gasket pumping "air" into the coolant.
    Jump to step one and repeat.
    #57 rjparker, Dec 25, 2024
  18. Chester92
    27
    Los Angeles
    Thank you! Is the brass plunger on the thermostat supposed to be closed against the plastic or open leaving a gap between the plastic housing and plunger?
  19. rjparker
    9,498
    5,815
  20. Chester92
    27
    Los Angeles
    I replaced the water pump and everything seems like it cycles as it should!
    Can someone confirm what the hoses coming from radiator and coolant reservoir should be? Seems like the only hot hoses are the ones at the T by the heater hoses but the 4 other hoses on the radiator stay around 55-60 degrees F once normal temp is reached.
    Heater blows nice and hot so far
    Wonder, Brian1954 and ASRDogman like this.
