Driver low beam not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by redprius10, Dec 16, 2024.
  1. redprius10
    redprius10 New Member
    Virginia
    Thanks, but your comments aren't helpful.
  2. redprius10
    Virginia
    Well, it's confirmed....I'm an idiot. I will be picking up an H11 bulb tomorrow for the driver's side. I apologize for wasting everyone's time, but I truly appreciate your replies. Consider this thread closed. Happy Holidays!
    BiomedO1 and Brian1954 like this.
  3. xliderider
    xliderider Senior Member
    8,032
    3,211
    Honolulu, HI
    You should buy them and replace them in pairs. You can keep the passenger bulb as an emergency spare bulb, but you might end up needing to replace it soon anyway, if you only replace the driver's side.
    FYI, the passenger side lowbeam bulb is a PITA to remove and replace. It's really tight in there. I always remove the bolt and clip holding the air intake hose and bend it out of the way for easier access to the passenger side headlight bulb. Even when you think you have it in properly, turn on the lights and verify that the beam is normal and not really dim, indicating that you probably installed the bulb off-angle and it can melt your headlight housing if not correctly installed straight on.
    Also, FYI, don't touch the bulbs with your fingers/hands as the oils left on the glass bulb can cause hotspots and cause premature failure of the bulb(s).
    SM-G781V ?
    redprius10 and Brian1954 like this.
  4. redprius10
    Virginia
    Good advice, thanks. I'm going to pull the bad one first before I head to the parts store so I can match what I had. And, yes, I've experienced the joy of changing the passenger side. Glad it's just the driver's side....this time.
  5. ASRDogman
    ASRDogman Senior Member
    7,114
    3,713
    It's easy to get confused. Everyone makes mistakes.
    You didn't waste anyone's time.
    There are certainly other people who have or are having a similar issue.
    Merkey and redprius10 like this.
  6. redprius10
    Virginia
    Thanks for the link to the battery upgrade. I know that day is coming.
    ASRDogman likes this.
  7. rjparker
    9,498
    5,815
    Parking lights are separate from daylight running lights
    redprius10 likes this.
  8. rjparker
    9,498
    5,815
  9. ASRDogman
    7,114
    3,713
    Application:
    HID and LED bulbs are street legal in the USA for Fog Light use only. Not compliant with DOT / FMVSS108 and not street legal in the USA for Headlights. Legal for off-road use in Snowmobile and ATV headlights and off-road racing use only auxiliary or forward lighting. International street legality varies by country. For detailed clarification on street use, CLICK HERE.
    Note: This usage regulation is not unique to Lasfit bulbs. All LED and HID bulbs from all other brands, regardless of marketing claims, are prohibited from street use in halogen headlights in the USA.
    DOT/SAE/FVMSS108: NO (NOT STREET LEGAL IN HEADLIGHTS IN USA)
    HOMOLOGATION ECE: NO
  10. ChapmanF
    17,185
    That's frustrating, and of course it's an example of "thing that's not legal yet all because the regulating agency just hasn't gotten around to adopting standards for it". On the bright side, SAE does continue to do work toward filling that gap:
    https://www.sae.org/publications/technical-papers/content/2024-01-2230/
    I posted more about that work a while back, only I haven't been able to find that post now. If I remember right, it seemed like updated standards might not be far off in 2019 or so, but then COVID happened. Maybe there's still hope for this silly state of affairs to get corrected before long.
  11. rjparker
    9,498
    5,815
    Which is the reason you go with quality in LED replacements used in a halogen reflector assembly.
    There are cheap versions that don't maintain the halogen beam spread which can blind oncoming traffic even when used as a low beam. There are cheap versions that overheat and don't last. There are cheap versions that produce rf interference that can disable tpms systems or disrupt communication busses. The better versions solve those concerns and normally specifically call out their solutions.
    Of course there are factory LED headlights for our gen3s but they require new harnesses and headlight housings. Virtually all recent cars have factory LED headlights which are the white versus the yellow lights.
    You are more likely to get a ticket for driving without lights or with the highs constantly on than for running retrofit LED low beams.
    To say better clarity for the driver and extended life for a hard to replace part are not worth the extra cost is questionable to say the least.
    #31 rjparker, Dec 18, 2024
  12. ASRDogman
    7,114
    3,713
    See post #29, copied and pasted from THEIR web page....
  13. ChapmanF
    17,185
    Yeah. it's frustrating ... obviously the only sticking point is whether the light distribution is ok, so what you want is to buy one that gives an ok light distribution, only SAE has not yet produced an official test for that, so to date you can't buy anything that's actually street legal under FMVSS, even though some products would probably qualify if an official test existed.
  14. Pennygarcia
    Pennygarcia New Member
    United States
    2013 Chevy Volt
    Three Touring
    I think it may caused by the new bulb.
    Tombukt2 likes this.
  15. Tombukt2
    12,003
    2,123
    Yes You're a gen 3 with h8 and h11 not age 4 The Gen 3 does have a wiring harness issue It's pretty well known and you can read the technical service bulletin on it pretty much anywhere You can Google for it probably and I'm sure it's here somewhere
  16. Tombukt2
    12,003
    2,123
    Would the new bulb work over on the other side of the car Is that what you're saying and you've pretty much ruled out everything except for the wiring or what's feeding the low beam left headlight or whatever side it is Don't you have separate right hand and left hand lighting fuses I can't remember for the Gen 3 at have to go out and look. I would try the new bulb on the other side and see if it lights properly If it doesn't probably the bulb
