2013 Prius C Having Battery Issues
Discussion in 'Prius c Main Forum' started by Brad K, Dec 17, 2024.
Tags:
  1. Brad K
    Brad K Member
    173
    53
    Prius C owner. Bought the car new in December 2013. Since 2020, I only get about 5,000 miles per year on the car. It has about 130,000 miles on it.
    I have noticed for the past 3-6 months the hybrid battery slightly depletes faster than it used to and also charges slightly faster than it used to even sometimes in the city reaching max battery which had never happened in 10 years (only going down mountains). A couple weeks ago it would have trouble starting and show lots of warning lights on the display. Now it has sat for 1 week while I was on a trip and it will not turn the engine on, showed warning light and then only the check engine light. I had it jump started and it ran. I drove around the block. About 8 hours later same warning light issue and will not start. Wondering if this is the 12V battery or the hybrid battery? And where is the best place to get new batteries? How much do these batteries cost?
    thanks
  2. Leadfoot J. McCoalroller
    8,007
    7,479
    Pennsylvania
    2018 Prius c
    This is not an actual diagnosis, but it sure sounds like the hybrid battery is aged out, and that would be more or less on schedule for a 2013.
    You may also be having troubles with the 12v battery- the car probably ought to be on its 3rd by now.
    Toyota is by far the best supplier for the hybrid battery, though you may save some money by having someone other than Toyota install it for you.
    Last time I checked they were around $2k for the part.
    The 12v battery is much cheaper and more generic, though Toyota often has the best grade stock available.
  3. Brad K
    Brad K Member
    173
    53
    Thanks. This is the original 12 volt battery also.
  4. Brian1954
    Brian1954 Senior Member
    2,008
    781
    South Central PA, USA
    It's definitely time to replace the 12v battery. I am not familiar with the Prius c, but you should be able to find a replacement battery at an auto parts store, Toyota dealership, Walmart, Costco, etc.
  5. Brad K
    Brad K Member
    173
    53
    I am getting a free diagnostic test at Green Tec tomorrow
  6. Leadfoot J. McCoalroller
    8,007
    7,479
    Pennsylvania
    2018 Prius c
    The early version Prius c uses the S34B20R battery which you can get at many of the usual suspects.
    The late (2018-2019) model needs the newer H3 battery and that has been harder to find as of this writing.
  7. Brad K
    Brad K Member
    173
    53
    GreenTech batteries did a free diagnostic this morning and found nothing. But they said when the 12V dies the codes are erased. I did jump it this morning to drive 22 min to GreenTech. Then drove back to AutoZone, bought a 12V for about $250. Just need to install it. Anyone have a good video or instructions on this?
  8. Brian1954
    2,008
    781
    Did they check the hybrid battery, 12v battery, or both?
  9. Brad K
    Brad K Member
    173
    53
    Just the coes and the hybrid battery. They did not check the 12V and did not have one to sell me.
  10. Leadfoot J. McCoalroller
    8,007
    7,479
    Pennsylvania
    2018 Prius c
    So now you're back to having a healthy 12v battery, which should go a long way to contain the chaos.
    Now if you are also having problems with the hybrid battery it should be a lot easier to gauge severity.
  11. Brian1954
    2,008
    781
    Search for YouTube videos. You should be able to find something.
  12. EliPriusC
    EliPriusC New Member
    Lima PerĂº
    2016 Prius c
    I found this good video About instructions for changing the 12V battery in a Toyota Prius. I have the same problem but I can't find a compatible battery. Could you please tell me which batteries are compatible with Prius C 2019?
    htts://youtu.be/yWP_UQu0FtM?si=6oHtEAWr1yLXBiKV
  13. John in Vermont
    John in Vermont Junior Member
    44
    17
    Rochester, Vermont
    2018 Prius c
    I just bought the 12 volt battery from Toyota. It cost about the same as an aftermarket battery and it fit perfectly.
  14. pasta4breakfast
    102
    49
    Anaheim, CA
    2020 Prius Prime
    Any update on how the car is performing since replacing the 12v battery? It is kind of crazy that your 12v battery lasted 11 years. The 12v battery on the Prius C I purchased new in June of 2013 died right in July 2020. I thought 7 years was impressive, but I guess not. I think the car sitting frequently during the COVID lock down was the nail in the coffin. Hot weather probably didn't help either.
