What is the baseline power draw in Ready, stationary?
Discussion in 'Prime Technical Discussion' started by frederw1701, Dec 18, 2024.
  1. frederw1701
    frederw1701 Junior Member
    49
    WA
    2018 Prius Prime
    Fan off, accessories off, display off, how would I measure it safely, or does anyone already know?
  2. vvillovv
    vvillovv Senior Member
    4,320
    1,508
    NY
    0.4 - 0.6 amps see DrPrius when in ready mode.
    frederw1701 likes this.
  3. frederw1701
    49
    WA
    2018 Prius Prime
    Thank you.
    vvillovv likes this.
  4. Brian1954
    Brian1954 Senior Member
    2,015
    786
    South Central PA, USA
    Are you asking about the power draw from the 12v battery or the HV battery?
    BiomedO1 likes this.
  5. RandyPete
    RandyPete Active Member
    398
    163
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    2017 Prius data ?
  6. BiomedO1
    3,160
    1,673
    SacTown, Ca
    Yea, don't know what the OP is trying to ask for or do - but I know 0.6A is way too low.
    In Ready mode, the DC-DC converter is active and supplying power to all the cars' systems. If you want to find the total current draw, you'll need to clamp an inductive amp meter onto the main trunk cable of the DC-DC converter. If you clamp onto a branch circuit, your only going to get whatever current is flowing across that particular branch circuit. ie. clamping onto the Aux. battery cable, there could easily be 10A+ or more there, if the battery is receiving a charge. If you clamp onto your cigarette lighter power cable and nothing is connected to it - current draw is zero. Does that mean that there's no current flow in the car in ready mode?
    Hope this helps..... @frederw1701 Please rephrase or be more specific about what your trying to ask or do.
  7. vvillovv
    4,320
    1,508
    NY
    The OP's profile says 2018 Prime. I don't get why no body gets what the OP asked for.
    Other posters - good luck measuring the 12 volt system draw while it's charging in ready mode.
    sheesh
    0.6 amps is to low? for what? :rolleyes:o_O:LOL::ROFLMAO::sick::sleep::(:giggle:
  8. ChapmanF
    17,779
    Some posters seem to be stuck on whether the current is measured in the HV or 12-volt system, while the OP only asked about baseline power draw and didn't specify which system.
    It's fine not to specify which system, because under the stated conditions (READY, stationary, accessories off), all of the power being drawn is coming from the HV battery anyway (assuming also the engine is stopped). and a Dr Prius reading of current from the battery is a perfectly adequate way to measure it.
    In those stated conditions, the power being drawn from the HV battery is pretty much all going to the DC/DC converter and coming out as 12 volts to power the car's various electronics. If the heat pump / air conditioner were in use, some would be going there too, but the OP stipulated accessories off.
    0.4 to 0.6 amps from the 352-volt Prime traction battery = 140 to 212 watts = 11 to 18 amps at 12 volts.
    As the OP asked for 'power' and not 'current', just answering in watts would have done the trick, without getting into the weeds of how many amps at how many volts.
  9. BiomedO1
    3,160
    1,673
    SacTown, Ca
    That answer is more in the realm of possibility; since power-off battery draw is around 50mA-250mA@12VDC - depending on manufacturers specifications.
    That can be measured by clamping the meter between the traction battery and DC-DC converter power cable. Again, Placing the meter clamp on a branch circuit will only yield the current going across that branch circuit.
    Hope this helps....
    #9 BiomedO1, Dec 19, 2024
  10. ChapmanF
    17,779
    There is a PID that Dr Prius can simply show you, which is the current in/out of the traction battery, measured by the Hall sensor that's inside the battery case.
    Under the OP's stated conditions, that's really all you need. It shows you the current coming out of the traction battery, and under the stated conditions, essentially all of it is going to the DC/DC converter.
  11. BiomedO1
    3,160
    1,673
    SacTown, Ca
    Yes, that's why I was very specific in my write-up. OP also asked how to safely measure it. Which I provided:cool::love:
  12. ChapmanF
    17,779
    I'm not sure there's any practical way to clamp a probe just at the DC/DC converter input. Unless something's different in the Prime, there's just one cable connecting the battery to the whole inverter/converter assembly. By taking the cover off, you may see a bent bus bar distributing the battery voltage to the boost converter, A/C power, and DC/DC converter, but I'd be surprised if there's enough clearance to clamp a probe ahead of just the DC/DC converter. And working under the inverter cover with power on isn't the safest.
    But as long as the car isn't using any propulsion power or A/C / heat pump, then the current into the DC/DC converter just is the current out of the traction battery, which you can read from the car without opening any covers.
  13. frederw1701
    49
    WA
    2018 Prius Prime
    Well, I could have been clearer. I was thinking of the HV battery, for the reasons ChapmanF mentioned.
    So then, ~200 watts from an 8.8 kWh battery, does that mean I could stay in Ready for about two days?
    Back in my day, inductive ammeters were for AC. Do they have magnetometers now that can measure current in a DC line? Not that I would do that when I can just ask the computer. Sheer curiosity.
  14. BiomedO1
    3,160
    1,673
    SacTown, Ca
    Doesn't matter as long as you have gas in your tank. The ECU will fire the ICE if it gets too low.
  15. Prodigyplace
    12,463
    11,708
    Central Virginia
    The WeberAuto vidro on the Prime demonstrates how to measure the current draws and shows the draws in different states at a couple of different points.
  16. ChapmanF
    17,779
    A simple inductive clamp will work for AC only. To work with DC you need a clamp that uses a Hall effect sensor. But those aren't anything hard to find these days; it's been a long time since they were exotic. And they work fine for AC also, or any combination.
    Hall chips are such everyday items now you've got like a dozen built into the car: things like the shift lever and accelerator pedal don't use anything with mechanical contact, just move some magnets around near some Hall chips.
    frederw1701 and Prodigyplace like this.
  17. frederw1701
    49
    WA
    2018 Prius Prime
    Much appreciated. I am glad to learn things.
