“Quality Confirmation Activity”
Discussion in 'Gen 5 Prius Main Forum' started by daisy555, Dec 19, 2024.
  1. daisy555
    daisy555 Senior Member
    1,644
    691
    CT
    Do any of the experts know what this truly means?
    Apparently my allocated Prius that was estimated to arrive 12/17-1/20 has been “randomly” pulled for a quality control check and now won’t be arriving until the end of January possibly mid February? Just my luck.
    #1 daisy555, Dec 19, 2024
  2. PriusCamper
    PriusCamper Senior Member
    11,982
    4,872
    Pacific Northwest, USA
    That's Toyota Stealership doublespeak for: 1) we sold your car to someone who needed a favor, or 2) we were wrong about our expected next shipment or 3) Nobody is buying ICE Toyotas on our lot and we don't have room for the next shipment until we sell some of them.
    As in quality control checks happen on the assembly line, not after a vehicle has been shipped.
    Fortunately, in your part of the country people determined to get their new Prius asap have found them at a different stealership not too far away and were able to transfer that purchase.
  3. daisy555
    1,644
    691
    CT
    I remember back in 2023 someone else on PC had their allocated car stalled due to a quality control check. I don’t remember if they ended up with the same car or not. Time will tell!
  4. Mendel Leisk
    40,472
    Do you have the VIN?
    PriusCamper likes this.
  5. daisy555
    1,644
    691
    CT
    Yes I have the VIN number. They know I’m watching carefully. It’s a small dealership. My biggest concern is why was it pulled for a quality inspection. Toyota corporate and a very busy dealership in MA told me this status has been seen before. Could be a random check or something faulty. I guess my biggest concern would be the paint.
  6. sclevine
    sclevine Active Member
    142
    145
    NE Florida USA
    2024 Prius
    When I got mine, I got some last minute weird stories from the dealership about delays and my car was delayed a few weeks. While the car I received was the same as what was promised, I noticed after I got home that the VIN number was different. They definitely play games.
  7. bisco
    51,029
    they probably have a random check program to help maintain qc. just a guess though
    daisy555 and Merkey like this.
  8. daisy555
    1,644
    691
    CT
    Crazy that the person who already rejected a car due to QC issues has her next one being pulled off the line for a QC check. Initially I was thinking maybe the timing was perfectly aligned with them realizing there is a design flaw in the plastic piece on the hatch but I doubt that. They would be pulling all of them if that was the case.
  9. rjparker
    9,514
    5,823
    They probably know you are going to reject it because of the headrest
    daisy555 likes this.
  10. Trollbait
    12,313
    That was called a quality hold, IIRC. The guess was that it was to perform a minor recall on the car, but these holds can happen over the import paperwork. Then it can be as bisco says, a random QC check. To made sure nothing went wrong between leaving the factory and arriving, and make sure all the prep work at the port was done right.
  11. daisy555
    1,644
    691
    CT
    :p …and the detached fabric on the back of the seats and the 5 inch grooved scratch above the gas tank door.
    I’ll be throwing a blanket over that headrest so I don’t have to look at it in the rearview mirror.
  12. hill
    8,621
    That would be the very best scenario. What ... are they going to tell the customer, "that sucker has a ton of overspray so we had to rub it out & repaint it by hand" - or reveal some similar defect - like poorly stitched upholstery??
    Just be glad that they caught it & are going to take care of it. Only make sure you give it an extra thorough going over when it finally gets here. Sometimes rework is not quite up to snuff. Sometimes that kind of stuff happens to the best of cars.
  13. daisy555
    1,644
    691
    CT
    Oh well…my biggest concern is the seat material and the paint. Two things that are supposedly not covered under the warranty.
    #13 daisy555, Dec 20, 2024
  14. Prodigyplace
    12,395
    11,676
    Central Virginia
    One issue with Toyota US these days is, when a car is allocated to the dealer, ir is assigned a manufacturing ID that looks like a VIN and is placed in the VIN spot. Very shortly before the vehicle is manufactured, that is changed to the actual VIN.I saw that happen with my 2025 Camry XLE.In my case, the dealer Stock Number remained the same.
    I found it interesting that although the car was assembled in early November, the salesman said Toyota had actually allocated all the parts in August! That is a long lead time!
  15. daisy555
    1,644
    691
    CT
    That is a long lead time.
    Similar to back in 2023 I was given the VIN number at the time of allocation when it was supposedly in the build phase. This number matches what’s on Toyota’s website. I’ll have to wait and see.
  16. Prodigyplace
    12,395
    11,676
    Central Virginia
    I saw a delivery date estimate long before the car was assembled. I think I offered the deposit in early October with delivery estimate late November. The VIN got assigned early November, just before assembly.. The car was delivered around mid November.
  17. Gokhan
    Gokhan Senior Member
    5,637
    2,225
    Paramount CA
    This happened to several others on this forum as well. It looks like there are issues in your car that need to be fixed before it can be sold. I don’t remember if any such car failed the quality check and was sent back to the factory on the next Ro–Ro, but that’s probably a possibility.
  18. Mendel Leisk
    40,472
    Hopefully didn't sideswipe a bollard somewhere, getting a quicky paint job at some port. Just that happened to us once. The sales contracts up here typically come with a clause saying the "new" car can have have up to 20% of it's suggested retail price, before dealership has to disclose it. In our case apparently the dealership didn't know about the damage either: one full side of the car had been sanded down, filled, primed and repainted. That paint start coming off in a few months.
    The sales "contract" presented to you is not a contract till signed by both parties (you and the dealership), and while they'll never explain this, you are free to cross out or amend clauses you find unacceptable. Say revise "20%" to "$500 USD max". Both you and the dealership need to sign-off on any such revisions. If they won't, and that is somewhat telling, you're free to walk away.
    #18 Mendel Leisk, Dec 20, 2024
    daisy555 and Gokhan like this.
  19. Gokhan
    5,637
    2,225
    Paramount CA
    I’ve seen a video of how these cars are driven off the Ro–Ro, and how closely parked they are inside the Ro–Ro. I am surprised we don’t see damaged cars more frequently.
    Perhaps it is time for @daisy555 to cross this car out on sign up for a 2025. LOL
  20. Prodigyplace
    12,395
    11,676
    Central Virginia
    That is true in the US too?
