Hatch garnish loose only at driver's side edge
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Dec 24, 2024.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,612
    771
    Southern California
    That lubricant seems to be a New Zealand specific product.
    The hatch opens pretty well once it is lifted up a few inches, but there does not seem to be enough oomph when fully compressed to make the hatch start moving. Which is peculiar, since if anything that should be when these gas struts have the most force.
    #21 pasadena_commut, Dec 28, 2024
  2. dolj
    dolj Senior Member
    8,438
    4,288
    Wellington, New Zealand
    I'd be surprised if it was. We usually only get the world's leftovers.
    If it is a market-specific product, it is more likely made for the Australian market from which we benefit. In any case, I would hope there was an equivalent product available in the States probably called by a different name.
    If you can't get it in the States, it is a shame, because it is great for so many things on the car and around the home.
    That is one of the immediate improvements I noticed, the hatch popped open again after treatment.
    AVTrainz likes this.
  3. pasadena_commut
    2,612
    771
    Southern California
    Turns out "Shin Etsu" makes a lot of different products which might be the one Honda sells. Here is one of their summary documents:
    https://www.shinetsusilicone-global.com/catalog/pdf/grease_e.pdf
    Does the Honda product have a Shin Etsu product number on it?
    Their G-501 product seems like the perfect thing to put on little plastic gears in actuators.
  4. pasadena_commut
    2,612
    771
    Southern California
    Bought some Shin Etsu grease from the closest Honda dealer. Today cleaned the hatch rubber weatherstrip thoroughly with water, then treated it with the Shin Etsu grease. Cleaned the metal parts of the hatch that touch that rubber thoroughly as well. Put a tiny bit of the grease on the rod of the struts, worked the hatch up and down. I know, this grease is not the same thing as that gel, but it is a Silicone grease and if any sort of lubricant would help, pretty much any should for a short time. Moving the hatch up and down scraped what looked like 99% of the grease off and formed a little grease donut around the shaft at the extreme (closed) end of travel. Wiped that off, it was just going to collect dirt.
    End result - no improvement whatsoever. The point at which the hatch will start to lift is actually so high that I can look underneath and see that no part of the hatch is touching the weatherstrip. Guess the Stabilus lift supports just failed, or at least one did. Also it was quite warm today (80 F!), so that rules out "doesn't work because of the cold". Will contact RockAuto about replacing them.
    I took a very close look at the hatch hinges, with an eye towards lubricating them, and I don't think any product I have is going to do a thing. The gaps between the "barrel" (which rotates) and the supports on each side are very small. A lubricant would have to wick through that small space as thin liquid and then convert into some other state so that it wouldn't leak right back out again. These hinges don't squeak or scrape or make any "I need to be lubricated" sounds, and the hatch moves pretty easily, other than the weight. Seems pretty unlikely that after 17 years they would suddenly develop so much drag that it was a problem.
  5. pasadena_commut
    2,612
    771
    Southern California
    The only option under the Stabilus's manufacturer warranty was RockAuto shipping a second set of the same product, and I would have to pay for shipping the defective one(s) back. Since the product failed so quickly I don't trust it. Why would I want another? So I ordered a pair of strongarms instead. If one of the Stabilus lifts is still OK when it comes off it will be kept as a spare.
  6. ChapmanF
    18,146
    I don't think my (gen 3) hatch has ever lifted itself right from the unlatch point, nor any gen 2 hatch that I can remember opening. Granted, none of these cars were new.
    The hatch might be designed geometrically so that the point of maximum strut compression isn't the fully-closed point, but some inches upward of that. Unlatch the hatch and lift, and once you pass that point it opens itself. Close the hatch, and as soon as you've passed that point the strut force helps give it a nice solid thunk closed. That's the way mine has always seemed to work, so much so that I've always assumed it's what they intended.
    My tube of grease, for what it's worth, seems to say L100, G-3W-O-M, Honda part #08798-9013.
  7. pasadena_commut
    2,612
    771
    Southern California
    Same numbers on the tube I bought.
    I don't know what these hatches are actually supposed to be like, that is, as designed by Toyota. We bought our 2007 used, and the hatch would pop up several inches and then need a little nudge to open the rest of the way. It would go up pretty slowly and I didn't worry about it breaking the roof welds. When the lift supports started to go it needed more user supplied lift to open, especially near the top of travel. Right after the Stabilus replacements went in it would pop open and continue upward gaining enough speed that it was prudent to keep a hand on it so that it didn't break the roof welds at the end of its travel. Now it just sits there after the hatch is released, it has to be lifted the better part of a foot before it will rise, and it takes a couple of pounds of force (applied to the metal, not the garnish), then it goes up the rest of the way, but much more slowly than when these parts were first installed. Whatever pressure the Stabilus is set to, resulting in slow or fast rise, it should certainly stay the same for more than 6 months!
    FYI, at least some of the Stabilus lift supports are user adjustable - if you have the right tool:
    This adjustment seems pretty dubious to me though. One can let out some of the gas, but it is not quantitative at all, and if one goes too far, it is time to buy another lift support. Seems to me that if there is a valve in there one should also be able to rig up a system to put in a defined amount of pressure, just like a tire. These things are filled with nitrogen, and I certainly don't have the equipment for that, but tire shops sometimes offer that service. I wonder if they could adjust lift support pressures? Guess it would depend on how high the pressure is in these things. Searching... Claim is 29 to 241 PSI
    How Do Gas Springs Work? | Our Blog | Lift Supports Depot
    Tire shops should be able to go up to maybe 100 PSI, although they wouldn't have the right fitting for this.
    #27 pasadena_commut, Jan 24, 2025
  8. dolj
    dolj Senior Member
    8,438
    4,288
    This is definitely not the right behavior. It should be more like what ChapmanF described here:
  9. ChapmanF
    18,146
    What's weird is I can't think of a way any replacement strut could change that behavior to rising fully from the unlatch point. Seems like the geometry'd be baked in by where Toyota put the body and hatch anchor points.
  10. pasadena_commut
    2,612
    771
    Southern California
    I can, just increase the force. At the initial stages the lift support is working at a very inefficient angle, almost perpendicular to the lift direction, so it takes a lot more force to move the hatch. But given enough force, it will move. More force is consistent with the hatch flying up quickly once it got moving.
    This Stabilus lift support's description says:
    • Rust-resistant piston rod extends product life
    • Smooth operation in all temperature extremes (between -20°F (-30°C) and 176°F (+80°C))
    • Consistent lifting force through 50,000 cycles
    • Linear spring characteristics for continuous application of force across the entire range of movement
    Unclear to me if that last one implies that it is supposed to act like a perfect spring (F=-kx), or if it is supposed to provide the same force at all extensions. I think more likely the latter. Who knows what force vs. extension relation was present in the stock lift supports, it could be linear with different slopes over several extension ranges.
    In any case, not all claims match the reality. We might have opened the hatch 100 times since they were installed, and the lifting force clearly changed. So the third one was optimistic by a factor of 500.
  11. ChapmanF
    18,146
    Depends on how Toyota laid out the geometry. It has always seemed to me that they laid it out with the strut compression maximum being a point a few inches above latched. Above that point, strut force pushes the hatch up. Below that point, strut force pushes the hatch down. More strut force in that region would push it down harder.
    Maybe I'm just wrong about the geometry being laid out that way, 'cause if it were, I don't think any amount of strut force would make it suddenly want to go up from the latch point.
  12. pasadena_commut
    2,612
    771
    Southern California
    I don't think so? Looking at the car from the side it appears to me that the line along the strut when the hatch is closed passes a couple of inches below the center of rotation of the hatch hinge. That results in the geometry of the attachment, which is supposed to be the hatch in its closed position (approximately, it isn't to scale). The smaller circle with its radius shows the strut from the part on the body to the part on the hatch. The larger circle and its radius shows the line from the center of the hinge to the point where the strut attaches to the hatch. It looks to me like the strut will be increasing in length continuously, at least near the closed position. The force in the closed position is mostly wasted since it is almost normal to the larger circle, only the smaller component tangent to that circle will exert a lifting force.
  13. ChapmanF
    18,146
    Thanks for analyzing that!
  14. pasadena_commut
    2,612
    771
    Southern California
    Consider the force needed to move the hatch. If the hatch was hanging straight down, or was balanced straight up, that force would be tiny. When the hatch moves to a position where its center of mass is at the same height as the hinge the force needed to lift it will reach its maximum. So let's start with the hatch latched. It releases and at that point the force from the strut is more than the force from the center of mass so the hatch starts moving up. However, before it goes too far up the center of mass has moved out enough that it balances the force available (it really is a terrible angle for the strut, pushing mostly sideways instead of up) and the hatch stops. A person then lifts the hatch a little bit more, and that moves the center of mass past its maximum (maybe) while simultaneously improving the angle on the strut (definitely). At some point the strut "wins" and then the hatch will open the rest of the way without any more help.
    Complication: no idea where the center of mass is. It doesn't have to be at the same position as attachment point for the strut.
    If a replacement strut has more oomph than the one just described, enough to overcome gravity on the hatch at all positions, it will never stop once unlatched and will just open all the way by itself. It will probably also hit the top of motion hard, which will be bad for the roof welds. That seems to have been the case for these Stabilus struts when they were first installed. Now that they are failing, they don't hit the top of motion with much speed. Although they do still get there.
    The prediction is that if a set of struts pops open all the way like that, attaching a small weight to the hatch, for instance, tied to the base of the wiper arm or attached to the license plate, would bring the motion back into the "stops part way up" realm. Just as an experiment, not suggesting leaving the weight there permanently.)
  15. pasadena_commut
    2,612
    771
    Southern California
    The StrongArm struts came yesterday - in a very squished box. Roughly square in cross section at one end and a very shallow parallelogram at the other end. No packing material inside at all. Took them out and placed them in groove while rotating them and the center rods turned but didn't move, so apparently still straight. Will put them on this weekend.
    They came with both fittings facing the same direction, and they need to face in opposite directions. The fitting on the gas cylinder just screws out, as in, you can actually see the screw backing out leaving a gap. That would be mechanically weak and it would change the length. Tried to rotate by hand the rod end while holding the gas cylinder and it wouldn't budge. Maybe compress the support a bit so that nothing is pressing on the seal and then turn, but again, that wasn't something I could do by hand. Sent a query to the manufacturer but nothing back. (Maybe it has to be translated to Turkish, as it turns out, that is where these are made.) Anybody ever done this?
    The Stabilus struts can't make up their minds this past week. Some days it takes a lot of force to lift the hatch upwards after release, and other days it is like it was months ago, which was "normal". Force does not seem to track with temperature. Strange.
  16. pasadena_commut
    2,612
    771
    Southern California
    I was curious about the extent of the "dead zone" in hatch positions, so I made a couple of measurements. Method was:
    1. Unlatch the hatch but do not lift it.
    2. Extend the tape on a tape measure with a metal tab at the end about a foot and lock it.
    3. Turn the tape measure upside down and hook the metal tab into the small space between the high point on the taillight and the bodywork just above it. It doesn't really hook there, but that is where the end should be. Hold the tape vertically maintaining that end in position. The measurement is from that fixed end to the top edge of the side of the hatch spoiler.
    4. Lift the hatch very slowly and watch the spoiler edge moving up the tape. When it starts to move up by itself, which will be very very slow right at the limit, call that distance A.
    5. Let the hatch move all the way to the top of its range.
    6. Lower the hatch until it will hold position by itself, then lower it slowly watching the spoiler top edge moving down on the tape. When it starts to move down by itself, which will be very very slow right at the limit, call that distance B.
    This was done both with the car in the driveway (nose slightly higher than tail, sides of the car level with each other) and on the street (nose and tail same height, passenger slide slightly lower than driver's side). Distance A was the same either way and fell between 7.25 and 7.375 inches. Distance B in the driveway was 5.75 inches and in the street 5.5 inches.
    This was with the Stabilus struts, as I didn't get around to changing them out this weekend. These struts are strange, some days they work "normally", other days they seem weak, and originally they were very strong.
  17. pasadena_commut
    2,612
    771
    Southern California
    Had my wife hold the base of the strut while I turned the fitting at the rod end. Clockwise looking down the axis. Once it broke free it turned relatively easily. But you have to sneak up on the final position because it cannot be rotated back in the other direction - do that and the fittings unscrew.
    I think what happened was that the rod sort of glued itself to some bushing it goes through, but once that adhesion was overcome, resistance to turning was low. Not just immediately, but several minutes later too.
  18. Davor
    Davor Junior Member
    Toronto
    Tips & traps for garnish replacement
    Late to the party I know, but for future reference...
    My 2008's tailgate garnish broke last summer. Why? Partly because the lift struts were old and weak (and so, I suppose, was the garnish itself); partly because I'd recently inherited the car, and its previous owner, being deceased, wasn't around to warn me not to lift the tailgate by that obvious handle. I've replaced the struts, which solved that problem, but that's a different post.
    There's a lot here on PriusChat about replacing the garnish, so I won't repeat it all, but here are some things I had to discover the hard way.
    1) I found a replacement garnish on Amazon. Can't remember which of several sellers I went with. I chose it partly because it came with the mounting hardware (bolts and push pins); if you're confident of having all that stuff on hand, you'll have more options. I couldn't find one to match my dark-grey car, so went with glossy black. It's not perfect, but doesn't look too bad...
    1b) As mentioned, my new garnish came with bolts -- but it didn't provide nuts. I needed to reuse the ones from my car. In case you need to replace any of those, they're M5's.
    2) Cover the tailgate latch. I used one of my car's floor mats. (Click on the thumbnail for a larger image.)
    Why do this? You'll need to swap over the latch release switch and the wiring harness it's attached to. If you close the tailgate while that's disconnected, the only way to open it again will be to climb into the car and use the mechanical emergency release, which is a PITA to get to. By covering the latch, you keep it from latching even if you close the tailgate (which I needed to do while I went in the house to faff about with the wiring harness (see #4 below.))
    3) Don't over-tighten the garnish's mounting nuts. It would be easy to break the new garnish before you even get it installed. (I didn't actually break mine, but a cracking noise made me afraid I had.)
    4) I had no problem removing the tailgate release switch from the old garnish. The lock-the-doors button, on the other hand... That button's mounting nuts (or bolts? I forget) were so rusted that I couldn't budge them, even with penetrating oil. (I also didn't have a suitable drill bit to drill the things out -- and with the car taken apart, I couldn't go get one. I'm sure an experienced mechanic would know how to deal with that, but it stumped me.)
    Fortunately my new garnish came with a removable plastic cover for that switch's mounting hole. So I (a) freed the switch from the old garnish by cutting through the plastic bits that those rusted bolts attached to, (b) left the new garnish's hole cover in place, and (c) stuffed the switch into a convenient cavity inside the new garnish, buried away out of sight and taped in place so it won't rattle around. So I have one button fewer to lock the doors with, but that's only a minor annoyance.
    5) There's a rubber seal permanently mounted to the tailgate. You have to tuck the top edge of the garnish up underneath it -- but when you do that, the rubber tends to get caught on the garnish and curl up underneath, which means it won't make a good seal.
    I bought a package of guitar picks to use as temporary shims. I tried to avoid using them to forcibly uncurl the rubber; that would have risked damaging it, and so buying myself a world of trouble -- the rubber would be a lot harder to replace than the garnish.
    Instead, I tucked one end of the garnish up under the rubber (the first end is easy), then slowly raised the other end, inserting enough guitar picks as I went to keep the rubber from curling in the first place.
    The picks are only needed until the garnish is installed and fully tightened down; then they're easy to remove.
    (I don't even play guitar, btw; I've added the picks to my tool collection for future similar uses, e.g. as spudgers for repairing electronics.)
    #38 Davor, Jul 17, 2025
  19. Davor
    Davor Junior Member
    Toronto
    Tailgate Struts
    TL;DR Last summer I replaced my 2008 Prius's tailgate struts with a pair of Stabilus 4B-015513 struts, and almost a year later, I'm completely happy with them.
    As mentioned in my previous post, about a year ago I replaced the tailgate struts on my 2008 Prius.
    I got them from liftsupportsdepot (no affiliation; just a satisfied customer). Their web site offered several choices for my car -- Stabilus 4B-015513, Strongarm 4094, Strongarm 6244, and their house brand.
    I didn't have any idea how to decide among those options, so I phoned them to ask for advice. The person I talked to recommended the "OEM" parts, i.e the Stabilus. She said they'd work better, but I no longer recall why. Those weren't the cheapest, but they weren't the most expensive either. (To be clear, my car did indeed have Stabilus struts already, which I'm almost sure were the ones it came with, but they were a different part number. I searched pretty hard for that specific part, but couldn't find it anywhere.)
    Replacing the struts was easy enough, though I didn't understand how the retaining clips worked, and managed to bend one permanently out of shape by prying it the wrong way. I replaced it with a clip from one of the old struts.
    The new struts do what they need to do: opening my car's tailgate is something I don't have to think about anymore -- I don't have to use two hands to avoid over-stressing the plastic garnish. Also, they damp the tailgate's travel at the top, so (unlike some people's experience with new struts) I don't have to worry about the tailgate flying up so hard it risks damaging the hinge.
    So I'm a happy camper, and those Stabilus parts are the ones I'd recommend.
    #39 Davor, Jul 17, 2025
  20. pasadena_commut
    2,612
    771
    Southern California
    These days I press the release button with my left then stick a finger from my right hand under the hatch at its lowest edge when it pops up, and then lift from there. No force on the garnish other than the button push. The finger trick probably wouldn't work if I didn't have skinny fingers or was wearing gloves. I have considered fashioning some sort of small handle for lifting from the hatch edge. In cross section there would be a J part which hooks under and around that edge and a tab of some sort that sticks out from the long part of the J to which one would apply force. Not a lot of force, just enough to get the hatch past the point where the struts will lift it the rest of the way by themselves. The J part might be able to clamp on tightly enough that it would need no extra fasteners. Otherwise, given the age of the car, maybe just glue it on. I think there is enough clearance for a strong dense plastic to fit in there even when the hatch is closed. I don't have a 3D printer though, so would have to pay somebody to make it.
