OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. Hammersmith
    Hammersmith Senior Member
    1,968
    1,973
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If you haven't already purchased from ModernSpare, you could just buy the Toyota wheel for about $70 and then a tire for about $140. You'd save about $170 that way. Being in Hawai'i, you won't be able to take advantage of the free shipping option, but you could still get the 31%+20%(44.8%) or 31%+25%(48.25%) discounts.
    Buying the OEM Toyota tools would lose some of those savings. For whatever reason, Toyota doesn't sell the tools for either Crown as a kit.
    The key tools are:
    09111-28150 - JACK SUB-ASSY, SPARE TIRE-TEMPORARY(T165/80R17) - about $115
    09113-30060 - HANDLE, JACK, SPARE TIRE-TEMPORARY(T165/80R17) - about $30
    09151-78010 - WRENCH, HUB BOLT BOX, SPARE TIRE-TEMPORARY(T165/80R17) - about $50
    The first two are available through Toyota sources, but the wrench only seems to be available from some Lexus sources. Total cost is an outrageous(IMO) ~$200.
    Then there are the extra tools. One is a simple tool to help you snug down the wheel bolts before using the lug wrench:
    0915A-53010 - SOCKET, HUB BOLT TEMPORARY SETTING, SPARE TIRE-TEMPORARY(T165/80R17)
    About $15, so not insane, but it's of questionable utility. Another Lexus product.
    The other extra tool is for helping you get the wheel on the car. You screw it into the top-most hole, mount the wheel, screw in the other 4 wheel bolts, then remove the tool and screw in the final wheel bolt.
    0915B-53010 - PIN, WHEEL GUIDE, SPARE TIRE-TEMPORARY(T165/80R17)
    About $25 seems steep for a piece of hard plastic(?). Lexus again.
    Finally, I found that there's also a little bracket to secure the jack into the car:
    58792-48010 - SUPPORT, JACK CARRIER, SPARE TIRE-TEMPORARY(T165/80R17)
    Only about $5 from Toyota dealers, so probably worth it.
    Gokhan likes this.
  2. daisy555
    daisy555 Senior Member
    1,651
    692
    CT
    There is a YouTube video of someone installing all the parts along with a list of the part numbers which are the same parts listed in this thread. I’m still waiting for my Prius XLE AWD to be removed from a quality control status : / so I haven’t purchased the parts yet.
  3. Hammersmith
    1,968
    1,973
    North Dakota - USA
    2023 Prius
    Limited AWD-e
  4. Mendel Leisk
    40,495
    As expected, the spare is "where equipped". Attached Owner's Manual excerpt has more info. It's also drool-worthy, you can see all the stuff you don't get:
  5. Gokhan
    Gokhan Senior Member
    5,653
    2,229
    Paramount CA
    Interesting. Gen 4 Prius Prime already comes with the jack and tool bag despite having no spare tire. For Gen 5, they provided the slots for the jack and tool bag but they asked you to buy them from the dealer separately.
    daisy555 likes this.
  6. Mendel Leisk
    40,495
    ^ Continuous Improvement is now continuous corner-cutting. :rolleyes:
  7. Tanegashima
    Tanegashima New Member
    Maryland
    2024 Prius
    New to PriusChat, so I clearly have a lot of reading to do. I have a 2024 XLE. Didn't like the idea of not having a spare, but also hadn't had a flat in more than a decade, so I begrudgingly accepted it. Of course, I got a flat, likely from going over a pothole, on Christmas day. Sidewall damage, so fix kit was useless. Fortunately it happened while I was close to a family member's home, so could spend the night there. Also fortunately, the nearest Toyota dealer had a tire in stock, and I was able to get on the road again later the next day, after spending nearly as much as it looks like folks are spending on getting an after-market spare and tools. (Toyota roadside service couldn't send a tow sooner than 5 hours after I called the morning of the 26th, so I ended up paying for towing on my own.) So.... is there a consensus here on what's the best option? Would the dealer sell me a suitable spare and tools? Are those of you who've gone with Modern Spare happy with that purchase?
  8. Tanegashima
    Maryland
    2024 Prius
    Roadside assistance will NOT bring you a tire. I asked, on Christmas night, when I was 2.5 hours from home with a sidewall slit from a pothole. Needless to say, I didn't drive home that night. All they would do would tow me to a dealer or gas station, where the car would be left overnight. Obviously, I declined, and instead drove the short distance back to my brother's home and spent the night.
  9. Tanegashima
    Maryland
    2024 Prius
    OK, I've read the whole thread now! Not sure exactly how things ended up with what jack adaptor is needed, but I'll get back to those posts later. Basic detail I'd like confirmed right now is whether the part numbers are the same independent of whether a 2023 or 2024. My understanding from this thread is that they are the same, but I'd like to confirm. I have a 2024 XLE. Thanks!
  10. daisy555
    1,651
    692
    CT
    Thank you for sharing this. I have been wondering how the center of the cargo floor directly above the spare tire would be supported. I need that space to be solidly supported.
  11. Tanegashima
    Maryland
    2024 Prius
    One more question: Is the only difference under the deck of the hatch between the AWD and FWD versions of the XLE the presence of the exposed charging cable in the case of the AWD? If someone converted their FWD XLE and happened to take a picture with everything out, I'd appreciate seeing it. Otherwise, I'll wait for another warm day and take mine out to see. Thanks!
    (waiting patiently for the moderator to approve my posts)
  12. Hammersmith
    1,968
    1,973
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's a bit of overkill. Here's a photo of the OEM boards side by side. The one on the left is the one that comes standard in the XLE & LTD in the US, while the one on the right is the one that comes in cars with the spare tire. The only difference is the four blocks of foam/rubber.
    The larger blocks of foam are roughly 2.3"x2.3"x1.25".
    The smaller blocks are roughly 2.0"x2.0"x0.75".
    They seem to be made out of fairly dense, compressed, recycled rubber.
    I took some photos of the blocks to get placement dimensions, but they turned out like crap. RobotBastard did a much better job with their pics at the top of page 19 in this thread.
    tat2boy and zare34 like this.
  13. daisy555
    1,651
    692
    CT
    Thanks so much! This looks more practical. I’ll take a look at RobotBastard’s post.
    I’m having car color envy. Was thinking early today…if this silver Prius on a QC hold falls thru, maybe I should snag a red one. Still a bit flashy for my circumstances but it sure is beautiful!
    #413 daisy555, Jan 2, 2025
  14. daisy555
    1,651
    692
    CT
    I just read your posts. Sorry you had to deal with that especially on a holiday. Your incident is why a spare is must in my situation.
    2023 and 2024 are the same. From what I understand the only difference with FWD and AWD is the AWD has some components below the cargo area but thankfully they don’t interfere with adding the spare.
    I would suggest using the YouTube video that’s posted
    several posts above this one. The video addresses the required parts. A few people have saved money by cutting the original styrofoam to fit the spare instead of buying the new OEM foam pieces. Sounds too messy for me.
    I think the Modern Tire spare is heavier but someone else can chime in on that and your jack question.
    #414 daisy555, Jan 3, 2025
    Tanegashima likes this.
  15. Templeton
    Templeton Member
    214
    58
    usa
    2024 Prius Prime
    SE
    For anyone interested, a late 2024 pricing update. Using the best december 2024 discounts (it was 25% off the already discounted online parts prices) that I could find, I was able to get these spare wheel parts for (including sales tax, and also got free shipping on everything):
    $54.07 for the 42611-21280 OE toyota prius steel spare wheel rim
    $67.70 for the 09105-47020 OE scissor jack w/ crank tool + lug wrench (no bag)
    $86.40 for a new Yokohama T145/90D16 donut tire (off ebay)
    I didn't get any of the other hardware, as I will be unable to mount the tire under the cargo bed, since I have a prime/phev. But I did get a very simple spare wheel bag off amazon, just to keep the car a bit cleaner during road trips, and the "65cm" version of the bag fits this spare perfectly:
    "EKDJKK Car Black Sliver 13-19'',17-22'' Spare Tire Tyre Wheel Cover Bag with Carrying Handles" (search on amazon)
    (fyi, when you strap the wheel down during travel, you most definitely want to anchor it by the rim, not by the bag, as the lightweight bag will tear instantly in an accident.)
    Weighing the whole spare (after the tire and valve stem installation) got me an actual weight of 28.8 to 29.0 lbs.
    Related, anyone know what is the recommended operating pressure for this donut spare? The tire sidewall says a max of 60psi, but I imagine that the optimal tire pressure is a lot lower for a gen5 prius?
    #415 Templeton, Jan 23, 2025
    zare34, Winston Smith and daisy555 like this.
  16. Mendel Leisk
    40,495
    From page 524 of the Toyota USA 2023 Prius Owner's Manual: 60 psi. (it's always been thus)
  17. Templeton
    Templeton Member
    214
    58
    usa
    2024 Prius Prime
    SE
    Thanks.
    I gotta say, that toyota recommended psi seems extremely high, given that, while this tire is narrow, it is not that narrow compared to the 195mm OE tires.
    Puzzling.
  18. Mendel Leisk
    40,495
    Think of it like a bicycle tire? They can quite high pressure spec.
    again, it’s always been thus, any car we’ve had over the decades, with the temp spares. Full size spares are per regular, but they’re extinct.
  19. Templeton
    Templeton Member
    214
    58
    usa
    2024 Prius Prime
    SE
    Of course, but:
    Narrower bicycle tires = higher pressures
    Wider bicycle tires = lower pressures
    (with my 3" wide bike tires, I run 9 psi !)
    If this 145mm spare went on a heavy car with wide tires, yes, it would make sense to go with higher pressures. But this spare is only about 25% narrower than the OE full size tires. And the full size psi is 35-36 psi.
    So, just based on a "w.a.g." (wild --s guess), I would think that 50 psi would seem to make more sense for a 145mm wide spare on a gen5. But, I guess I will defer to toyota.
    #419 Templeton, Jan 23, 2025
  20. Mendel Leisk
    40,495
    And Honda, Mazda, and… ;)
    Templeton likes this.
