Complete Gen 5 (2023+) Repair Manual Available
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by scotched, Dec 30, 2024.
  1. scotched
    scotched Junior Member
    48
    65
    Encino, CA
    2023 Prius
    It’s done.
    This is the complete repair manual for all trims and configurations (LE, XLE, LTD, AWD / PHEV). It includes guides for premium features as well (panoramic glass roof, digital rearview mirror etc.)
    I also duplicated the Dealership Accessory Guides (PPF, Homelink mirror), Quick Training Guides, and TSB’s. The complete list of all DTC explanations and troubleshooting steps are also included.
    The compressed file is just under 1GB and almost 4000 PDFs in total. Every file is named and organized as it appears in the TIS directory.
    All in all this cost me multiple TIS subscriptions, two full weekends wasted, and the resurgence of an old right shoulder injury to get this done. Fun stuff.
    It’s completely free - but if you’d like to tip me for the work done I’ve set up a BuyMeACoffee account.
    PM me and I will send you a link for the download (Google).
    dagaph, Edward Coan, yj4x4 and 26 others like this.
  2. Lantaral
    Lantaral Member
    66
    30
    US
    2024 Prius
    Just downloaded, it works great.
    That had to be a tremendous amount of work.
    Thanks! It's greatly appreciated.
    Gokhan and scotched like this.
  3. Gokhan
    Gokhan Senior Member
    5,634
    2,220
    Paramount CA
    No kidding! Each subsection needs to be downloaded separately, and there are thousands of them.
    Lantaral likes this.
  4. scotched
    48
    65
    Encino, CA
    2023 Prius
    TSS 3.0 added a TON of complexity to this car. Something as simple as replacing a bumper cover is no longer simple, as you'll see.
    Marwan Luay, Lantaral and Gokhan like this.
  5. Gokhan
    5,634
    2,220
    Paramount CA
    Oh, replacing bumper covers with ultrasound sensors has never been simple. The dealer will charge you eight hours of service for recalibrating the sensors unless you do it through a insurance company.
    Luckily, when I removed my rear bumper cover on my 2021 Prius Prime Limited to replace the combined lamp, I didn’t have to touch the sensors; so, the calibration did not change.
  6. PTS
    PTS Member
    74
    34
    Austin, Texas
    2013 Prius v wagon
    Not too shabby! Next up should be the electrical and wiring diagrams, often more useful than the repair manual.
    Put them altogether as a couple of searchable pdfs and you will have a winner that could be sold on ebay as a link. I used to do that on some construction equipment which had ridiculous faded hand drafted drawings the company wanted hundreds to buy.
  7. scotched
    48
    65
    Encino, CA
    2023 Prius
    I had considered adding the full electrical (TIS website gives you live circuit simulation) and collision repair sections but ultimately did not. I think both of these are beyond the scope of what the average DIYer will use. If I had the extra time I would have but when I tell you it took me 2 full weekends I mean it. I was physically exhausted.
  8. PTS
    PTS Member
    74
    34
    Austin, Texas
    2013 Prius v wagon
    The electrical diagrams are what you see the most here.
  9. scotched
    48
    65
    Encino, CA
    2023 Prius
    I'll be a little upset if folks are chasing down electrical issues with this car less than 2 years after it rolled out of the factory. But knowing how modern Toyotas are now I would not be surprised. Maybe I'll duplicate the rest one day or someone else can step up and finish it off.
    The main reason I wanted the repair manual myself was torque specs and disassembly procedures so instead of yanking off parts on a new car I can actually go at it informed.
  10. ChapmanF
    17,185
    The New Car Features manual is an overlooked gem. PriusChatters love talkin' about things that got improved or added and how.
    Gokhan likes this.
  11. RandyPete
    RandyPete Active Member
    379
    157
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    I'd like to see that New Car Features manual made available as a zip file.
    Gokhan likes this.
  12. Gokhan
    5,634
    2,220
    Paramount CA
    Yes, NCF please!
  13. MS72
    MS72 New Member
    Italy
    2024 Prius
    I would do, but I can't PM you (I don't figure out the reason), I'm wondering if you can be so kindly to send me the link, thanks!
  14. simonpp
    simonpp New Member
    Taiwan
    2024 Prius Prime
    Could you pls send me the link for this manual.Thank you!!!!!!
  15. RandyPete
    379
    157
    2024 Prius Prime
    XSE
    Thanks for the reply to my messaging and help downloading the manual zip file and the pointer to install and use 7-zip to extract the pdf files from the zip. mucho info there.
    scotched likes this.
  16. scotched
    48
    65
    Encino, CA
    2023 Prius
    (I cannot edit the original post in this forum so I'll post it here)
    The BLUE INFO buttons in the manual are a direct links to a PDF on Toyota's Website which requires access that you do not have.
    However, every PDF that exists online also exists within the repair manual folder.
    If you hover your mouse over the BLUE info box it will give you the name of the PDF it refers to. You can then search for that within the repair manual folder in Windows.
    The caveat is that you cannot have file names with special characters like colons or slashes. Omit them in the search and file name should be exactly the same.
  17. Mendel Leisk
    40,459
    Any way to modify those links, to point to the downloaded PDFs? Or better: amalgamate all into a single pdf, and have the links point to correct page within that file.
    that’d be a first, previous Gen PDFs just have broken links. Still you can search for the mentioned text with the link, and that’ll usually get you there. But it’s cumbersome.
  18. Schize
    Schize Junior Member
    United States
    2023 Prius Prime
    XSE
    I seem to be running into an issue with being unable to send a PM - is there an alternate route to see the manual?
    kw_as_45, TriJetScud and scotched like this.
  19. kw_as_45
    kw_as_45 New Member
    2024 Prius
    @scotched I'm also unable to send a DM - it might be because i have a new account? Would love to get a copy of the manual and happy to contribute to the coffee fund. Thx!
  20. keryst
    keryst New Member
    Pittsburgh, PA
    2024 Prius Prime
    SE
    @scotched I can't send you a pm, too new probably. I'd like to have the 5th gen repair manual if you wouldn't mind initiating the pm.
