NexPower V3 hybrid battery unveil - Sodium-ion battery
Discussion in 'Gen 3 Prius Accessories and Modifications' started by amarino, Jul 4, 2024.
  1. Bill Norton
    Bill Norton Senior Member
    2,126
    725
    MONW, Ks.
    1. My home grown vegis would disagree with you.
    2. Did you know some days, in some states, ALL the electricity comes from solar, wind, hydro? How is that explained away?
    But please, tell us more Luddite thoughts!
    I'm sure you guys cussed all that "Pollution Crap" under the hood back in the day... ,,, and probably deleted much of it. :mad:
    Rmay635703 and Isollas like this.
  2. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    The documentary “planet of the humans” would make you happy. For every solar panel plant that was built in the US, a coal plant was built near by to provide power when there’s no sunlight. I recommend this for you to watch.
  3. Bill Norton
    2,126
    725
    MONW, Ks.
    Do you have documentation on this bold statement?
    Are you sure it wasn't a Nat Gas powered peaker plant? Do you know about battery storage for excess solar?
    You can be a Luddite. But when you make bold Luddite statements you should have facts backing them up.
    Isollas likes this.
  4. tony_2018
    tony_2018 Member
    225
    66
    I can confirm that Jack stepped up. I even offer to pay for shipping. Jack has taken most of the hits and is still here developing new replacements.
  5. Hayslayer
    Hayslayer Member
    180
    98
    Someone once told me: The best warranty in the world is.....
    the one you never need to use....
    Next best is one where the seller strives to make the customer whole. Good to see one like this, since this is the one you don't see very often, because there's always some fine print.
    pollypocket53132 and vvillovv like this.
  6. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    You’re calling me a Luddite? Ha! Michael Moore “planet of the humans” is the information he provided in the documentary. I don’t make bold statement, just listening to them and inform others.
  7. ASRDogman
    ASRDogman Senior Member
    7,109
    3,713
    Well, consider the source, moore.....ewww
  8. Bill Norton
    2,126
    725
    MONW, Ks.
    This was your bold statement. Period.
    Seems easy enough to fact check. How many 'solar panel plants' (manufacturing?) are there in the US? Not many, I assume....
    Here's my bold statement: You can't make gasoline on your roof.:D
    I'm not sure what you're saying here.....(n)
    But GadBless and GadHelp the young people forced to go to this 'University'.
    It's basically the Faux Gnews of 'Colleges'.
    I wonder what 'degrees' the graduates have and where they end up....:whistle:
    They can't be science related degrees. Cause they don't like science, right?:unsure:
    #168 Bill Norton, Jan 2, 2025
  9. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    It was my statement as the fact was taken from Michael Moore’s research and finding. I am the messenger and I come in peace.
  10. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Haha!!!...
  11. sharpdoug
    sharpdoug Tig
    It’s been a year,
    My name is Doug K. I live outside of Houston Texas. My car is a 2015 Toyota Prius with the solar roof. As of today my car has 237,600 miles on the clock. Last year in late January, Jack at NexPower, upgraded my LiPo V1 to a V2.5 pack. At that time he asked, if I would be a Beta tester, for a new system. I said yes, for my own curiosity and for the good of the Prius community. My initial expectation was low, due to the fact that it got really hot here and even the stock NiMH won’t last, prior to the NexPower battery pack, I have been through 2 NiMH packs from Toyota. The first battery was original, and the mpg had deteriorated to 39-40mpg. I had Toyota install a factory new battery the mpg only improved to around 42-43mpg. The dealership said my car was old and I wouldn’t be seeing the original mpg. They charged me $3,300 and kept my original pack. I then found Nexpower and took the hit and purchased the V1 pack. The mpg immediately rose to 46-49mpg. I was able to resell the second Toyota pack for $1,400. A terrible loss. My lack of research cost me, so moving forward.
    The Sodium prototype arrived several days later, it is the Build #003. The instructions and installation were ridiculously easy, two modules drop in and couple of nuts and bolts and done. Immediately the Sodium system worked as advertised and has been to say the least flawless. The pack charges quicker in my opinion. The driving performance seems quicker with better acceleration, (that’s my opinion). I monitor the battery performance with the OBD to my iPhone and the pack runs cooler in all weather conditions. Did I mention it gets hot here in Texas?!!! I regularly get 7 bars on the charge indicator. That rarely happened with the original NiMh the V1 LiPo or pack. So far, in one year, I have driven 20,641.6 miles. I have used 2,052.29 gallons, with 44 fill up’s and averaged 46.64mpg. of mixed driving.
    I feel comfortable in concluding that after a year of using the Sodium pack it just works. I’ll let Jack at NexPower, explain the technical details. I am just a tester. I am not an engineer or a chemist, just a Prius owner. Jack’s support along the way has been wonderful. We are in semi-regular communication with screenshots of Dr. Prius App. Nothing has gone wrong and the system is functioning properly. My feeling is that the simplicity of the product, being a basic plug and play resolves the installation questions of the other systems available. The fact that the chemistry involves a far less hazardous material is a plus for the environment.
    As a side benefit, Jack also offered and I accepted a 12volts Sodium starter battery. It simply works as it is designed specifically to fit a Prius. Again, as stated above Sodium is cleaner system, than the lead acid from Toyota.
    Thank you for taking the time to read this and best of luck in 2025. Doug K.
  12. Bill Norton
    2,126
    725
    MONW, Ks.
    Understood.(y)
    Maybe next time, when you are quoting someone else you should state that.
  13. black_jmyntrn
    black_jmyntrn Senior Member
    1,690
    392
    2013 Prius Plug-in
  14. Bill Norton
    2,126
    725
    MONW, Ks.
    Thanks for the report!
    Just to recap your battery pack adventure...
    - The original got weak, at some point. - How weak? What mileage?
    - And you replaced it with a $3300 OEM pack. - How did it perform? Why did you replace it so quickly?
    - Then "Last year in late January, Jack at NexPower, upgraded my LiPo V1 to a V2.5 pack." - Did you pay for this V1 to V2.5? How did it perform and what was your cost for those two Li-Ion packs?
    - I guess you then quickly replaced it to test the Sodium. Was there a cost to you?
    Is this the correct sequence?
    How much out of pocket are you for 4 different pack replacements?
    Counting the OEM that's 5 packs in this car. In less than 10 years.
    I'd like a report on what major maintenance items you have been through in 237k miles!!(y)
    I bought a Prius to save money and not burn so much of that smelly stuff.
    I have a '10, level 5 with the ATP package. Love it!
    At 155k miles the original pack is doing well. It gets hotter here than in Houston, and it gets very cold in the midwest. We get a few days of any environment you can imagine.
    At some point my pack will start showing age, but until I need a replacement, I'm not touching it.
  15. rjparker
    9,484
    5,807
    I have to agree four hv batteries in 237k is ridiculous. Maybe if you said you were on the second since 175k miles it would seem more logical.
    Heat in South Texas is higher and lasts longer than Houston which benefits from Gulf breezes and far more rain. Oem are fine here. I might suspect a clogged battery fan or running without much ac in the summer might have been the issue.
    20k miles is not much of a test of Sodium especially when never getting extended freezing weather. The Lithium batteries were always defended to death with complaining customers dismissed as liars or incompetent - until there was something else to sell instead.
    #175 rjparker, Jan 8, 2025
  16. Bill Norton
    2,126
    725
    MONW, Ks.
    In his defense, it sounds like a lot of the replacements after selling off a $3300 OEM pack were for 'Research'.
    V1, then V2.5 Li-Ion and then on to the Sodium, in short order.
    Waiting to hear how much was the 'Out of Pocket' on this 'Research Project'.
    Thanks for doing this work! It's nice to have options. We need beta testers!
    I'm keeping an open mind on this 'new to me' production Sodium battery.
    Is it being used in any consumer goods, like battery banks, power tools or such?
    Is it happy in cold and hot temp extremes? It will have to be.
    The Gen3's TMS is a tiny fan that blows cabin air through the pack.
    At the moment, my Gen3's pack is around 6° F. It's been sitting, parked outside for over a week of nasty cold weather in KC.:( Honest, there's a Prius under that snow pile.:unsure:
    Any yet, the Ni-MH cells will handle the current of starting the engine and the charging that follows.
    Then gadknows how long it would take for the pack to get up close to cabin temp. How would the Sodium pack handle these temps?
    Also, what is the 'Self-Discharge' rate on this chemistry compared to the two other options?
  17. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Lifepo4 cells deteriorates when charging below 32F, I was told here by the defendants that they tested the pack in cold weather and it was still fine. None cameback with a capacity test showing capacity weren’t lost in the cells. Now the former lithium to sodium converts are still carrying water.
  18. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Don’t forget the soother add on charge also in between the lithium pack.
  19. Bill Norton
    2,126
    725
    MONW, Ks.
    "How cold was it?"o_O Where I live we get all sorts of 'cold weather'....
    I trust the spec sheets from the cell manufacturer on 'operating temp range'.
    Not a bunch of beta-testers or a shop that says "It's OK to operate these cells WAY outside the original spec sheet temps."
    "Soother"? wth is that? There's a bit of hardware that needs to be added to a lithium cell replacement pack? I'm still learning....
    Is this bit of hardware also required with the Sodium cell replacements?
    Is it included when you buy the cells, for either chemistry?
    Still learning....
    My ~15yr old NiMH cells are hanging in there. I had a friend buy a 'reconditioned' pack from Greentech, for his Gen3.
    It didn't last the 1 year warranty.
    He did get that pack replaced, no problem. But what if the few modules that failed waited another 2 months before showing up as bad?
    I don't want to go that route because all the NiMh modules they use are getting older by the day. It sounds like a gamble...
  20. ChapmanF
    17,174
    The "signal soother" was a small voltage divider/ opamp gadget with matching plug and socket connections to be inserted between the battery voltage sense unit and the harness of slim wires that monitor the voltages of individual battery blocks (which, in the original NiMH design, were pairs of modules).
    It was offered in one version of the lithium retrofit pack because earlier versions had tripped codes for voltage differences exceeding the programmed-in code threshold for NiMH.
    For a while there was an information vacuum about what the soother actually did, which got filled with some fanciful stories like it "distributes, manages and regulates things" ... a tall order for the simple device it turned out to be.
    Turns out it replaced each original voltage reading with the average of two adjacent ones, this making individual voltage differences that much less likely to be detected and trip a code. The threads where that was worked out can be found in a search.
    Bill Norton likes this.
