Bad engine Rattle in 2010 Prius
Discussion in 'Gen 3 Prius Main Forum' started by kingkoopa, Jan 2, 2025.
  1. kingkoopa
    kingkoopa New Member
    Dallas,TX
    hello prius peeps
    i have a 2010 Prius with 200,000 miles.
    The engine rattles like crazy upon startup.
    i have a video attached.
    does this sound like a head gasket issue? or is this a badly clogged EGR?
    any help/advice/pointers are very much appreciated.
    fyi this is my first hybrid. all my life ive driven hondas ( pilot and accord)
  2. rjparker
    10,083
    6,254
    Welcome to the gen3 head gasket world. It is not an egr stumble or a clogged egr cooler.
    Don't let it fool you if it is intermittent; that strategy will cost you an engine.
    Don't be fooled if it easily passes a coolant combustion gas test, a compression test or a leakdown test; that strategy will cost you an engine.
    Don't be fooled if the coolant does not seem to drop; it may only lose a few drops for a few seconds.
    A borescope test under pumped up coolant pressure when cold can be definitive but the symptoms are also very common.
    Car Care Nut HG Borescope at 11:00
    #2 rjparker, Jan 2, 2025
    Brian1954 likes this.
  3. rjparker
    10,083
    6,254
  4. Mendel Leisk
    41,328
    Long neglected EGR cleaning, it’ll be totally clogged, has caused head gasket to fail. Various relevant links in my signature, if you stick with it (on a phone turn it landscape to see signatures).
  5. kingkoopa
    Dallas,TX
    thank you so much, i will work on the prius this weekend. need this thing fixed....BIG BIG THANKS
    Thank you sir...watching...i appreciate ur help
    #5 kingkoopa, Jan 4, 2025
  6. Brian1954
    Brian1954 Senior Member
    2,148
    835
    South Central PA, USA
    Are you going to replace the head gasket this weekend? That is a time-consuming process.
    Merkey likes this.
  7. GEN3PRI8
    GEN3PRI8 Junior Member
    31
    UK
    Hello My Prius makes a rattling sound from the engine every now and again and has only done over 58000 Miles. do you still think I may need a EGR cleaning / clogged ?
    thanks in advance.
    #7 GEN3PRI8, Jan 5, 2025
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Cost of new head gasket and use an entire day to repair? Or pull $15000 out of thin air for another vehicle? I say $15000 and junk it!!! Time is just that precious
  9. Mendel Leisk
    41,328
    I’ve settled on 50k miles as a prudent cleaning interval for the EGR system. More risky, leave the first cleaning as late as 100k.
    Disconnectin of coolant hoses is necessary with removal of the EGR cooler, so it’s opportune to do in conjunction with engine coolant change. Or just drain a couple of quarts/liters of coolant, into a clean container, and return it to the reservoir afterwards.
    Is the engine shake a regular thing? At cold-starts, say after sitting overnight? Or more random? Head gasket failure leaks coolant into combustion chambers, causing shake on startup. Another possibility is if you’ve say done a very short run the day previous: water can condense in the EGR and/or intake, get drawn into combustion chamber at next start up.
    with your miles head gasket failure is unlikely, but there may be exceptions. A member here, @bisco, apparently had head gasket failure at 70~80k miles. This was a plug-in model too, with a fair amount of electric-only usage.
    Grit likes this.
  10. Brian1954
    2,148
    835
    In my opinion, you do not need to clean the EGR system at 58k miles.
    bettergolf likes this.
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    You don’t need to, but when you get knocks at 100,000 miles, you wish you should have rotated your phone side ways on mendels signature at post #9.
    AVTrainz likes this.
  12. rjparker
    10,083
    6,254
    First it's best to start your own thread rather than confusing things for the 200k guy.
    Cleaning everything is nice but it is highly unlikely cleaning the egr will solve your problem if your symptoms are like post 3's video with or without smoke.
    If it's a head gasket don't waste money (~$1,000 at a dealer) on an egr cooler, pipe and intake cleaning when it's easier to inspect them during a hg repair.
    If it's just a stumble with no severe metal to metal sound, it could be a sticking open egr valve which is designed to be closed at low rpm. Some oem egr valves have internal wear and an updated oem valve or sealing of an air leak can fix that kind of mild stumble. Aftermarket egr valves are often bad out of the box.
    The system checks egr flow almost every drive and will code if it sticks open or clogs. A good scanner can read the test results.
    20 kPa is pretty good an an engine with 58k miles which should not be burning oil yet.
    #12 rjparker, Jan 5, 2025
  13. OptimusPriustus
    OptimusPriustus Active Member
    332
    141
    Finland
    I had terrible rattle and reason was egr valve that was stuck open. Something worth checking before rushing to replace head gasket. Easy procedure:
    I also had sw updated as per new egr valve instruction. And yes my egr cooler was pretty gunked up when it was cleaned around 210kkm.
    After replacing the egr valve car has worked perfecly couple years now.
    #13 OptimusPriustus, Jan 14, 2025
