Hit a broken tire on highway
Discussion in 'Gen 4 Prius Main Forum' started by Joe Dipierro, Jan 3, 2025.
  1. Joe Dipierro
    Joe Dipierro Junior Member
    31
    SNJ
    So last night I hit the remains of a tire on the highway. It cracked my bumper which I’m so annoyed about. Is there any quick fixes I can do? I was thinking of gluing it? Thoughts?
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,028
    517
    Tucson, AZ
    2021 Prius
    I whacked one of those with my Gen III and ended up getting the whole front end piece replaced. They said whatever method I might try to fix it, JB Weld, etc., it would end up cracked again.
  3. Leadfoot J. McCoalroller
    7,835
    7,302
    Pennsylvania
    2018 Prius c
    You could probably weld that back together with a hot plastic welder. They're cheap on Amazon and it isn't exactly a precision skill, for a bumper anyway.
    Or drill a couple of holes on either side of the tear and bind the halves with black zipties. You want the black ones so sunlight doesn't break them down in a few months.
    Joe Dipierro likes this.
  4. Hayslayer
    Hayslayer Member
    187
    99
    J-B Weld Plastic Weld High Strength Automotive Epoxy Gel 0.85 oz Mfr# 50132 - Ace Hardware
    99% of the battle is the prep you put into it before actually applying an adhesive.
    The majority of failures are due to improper preparation and lack of proper support while curing.
    A small piece of flat lumber and a jack would probably work wonders for keeping it aligned and pressed together while curing. Regardless of how fast it says, I'd let it sit undisturbed at least overnight.
    #4 Hayslayer, Jan 3, 2025
    Trollbait and ETC(SS) like this.
  5. Mendel Leisk
    40,495
    Is it just me, or is there more stuff hanging down, further back?
  6. Joe Dipierro
    31
    SNJ
    There may be I have to get down there and actually look at it
  7. xliderider
    xliderider Senior Member
    8,037
    3,212
    Honolulu, HI
    Yeah, looks like the undercover is hanging down in the rear.
    SM-G781V ?
    Joe Dipierro and Mendel Leisk like this.
  8. BiomedO1
    2,730
    1,456
    SacTown, Ca
    Yep, JB plastic wield and drill a couple of holes to zip tie that crack together. You probably sheared a few of those plastic pop rivets on that rear under body cover too. Those will also need to be replaced, otherwise they will slap around down there and eventually tear-off.
    Hope this helps....
  9. Joe Dipierro
    31
    SNJ
    There is, my coworker put zip ties but said it’s still kind of hanging since he couldn’t get under the car too well.
  10. Joe Dipierro
    31
    SNJ
    Thank you
  11. Joe Dipierro
    31
    SNJ
    It is
  12. Joe Dipierro
    31
    SNJ
    SM-G781V??
  13. ETC(SS)
    6,921
    ^That.
    Judging from the photo this isn't the first time you've had Foreign Object Damage or what we squids call FOD, and this is a 2016 car that we're talking about, so looks aren't the number one log on your pile - am I right??
    Do the J-B Weld thing - CORRECTLY, and get on with your life.
    NOBODY else is getting this close to your bumper ANYWAY, unless they're up to no good.
  14. Mendel Leisk
    40,495
    Yeah you’ve got to raise it to properly deal with it. Google search for:
    tsb-0032-11
    One of the top results should be direct to the pdf on PriusChat, has all the info for fasteners.
    #14 Mendel Leisk, Jan 8, 2025
  15. Joe Dipierro
    31
    SNJ
    Yup once it warms up a little I will take care of it, too cold right now.
  16. Joe Dipierro
    31
    SNJ
    It had some knicks I thought the car used I also put some on there, the car is so low to the ground. I looked into buying a new bumper cover but that’s a lot of work. As long as I can deal with it I’m fine. I just gotta focus on the cover underneath. Thank you everyone for your help.
  17. Mendel Leisk
    40,495
    For the painted front fairing, if you remove it, clean up the crack with alcohol, tack it together with with super glue, then apply 2-part epoxy glue, reinforced with fiberglass mesh on the backside, you can get a fairly seamless repair. Get a spray can of your color code, and just go over it lightly. It's down real low, hardly noticeable.
    ETC(SS) likes this.
  18. Starship_Enterprius
    Starship_Enterprius Active Member
    322
    158
    Ottawa, Ontario
    2018 Prius Prime
    Plastic zip ties might not be a good idea. I zip tied rubber pads to my roof bars last summer for my kayaks, and by fall they were brittle and broken. Same with the ties i used for my Prius plastic underbelly. All brittle and broken in less than a year.
  19. Trollbait
    12,321
    Lowes has some of the more common type of auto part fasteners when looking for a source.
    Guessing these were the whitish cable ties. Those are for interior use. Need to use the black ones for outside like @Leadfoot J. McCoalroller said; those have UV protection. The other colors may or may not survive in the sun.
  20. Mendel Leisk
    40,495
    That aforementioned TSB attached now.
    The Toyota fasteners for the engine underpanel were reasonably priced through Amayama, even with shipping cheaper than local dealership: If you bundle with other items the shipping doesn't change much either:
    One advantage, you know they're going to fit. Also, in oil change link in my signature, there's some tips on preserving those fasteners. I've purchased a complete replacement set for the engine underpanel, and so far have only replaced 4~5, typically due to a broken tooth.
