WeberAuto: 2024 Prius Prime PHEV Low-Voltage Charging System Testing
Discussion in 'Gen 5 Prius Technical Discussion' started by KMO, Jan 7, 2025.
  1. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    He promises more videos coming including HV battery disassembly - he had some stills from a transaxle disassembly too.
    One new piece of information in there is that it can charge the 12V battery while charging the HV battery - I believe we all previously thought that the DC/DC converter used by the charger only output enough to prevent discharge.
    It may be true that the charger's DC/DC converter can't charge the 12V battery - but he had a low 12V battery, and the car actually activated the main DC/DC converter with the usual 14.1V.
    A bit weird - I'd been under the impression that they wanted to keep the charging and drive systems fully separate, and there were interlocks at the battery to ensure the charger and hybrid systems were not connected simultaneously. That's clearly been relaxed. Maybe part of adding "My Room" mode which presumably needs to activate a bunch of the AC stuff, which is high-voltage? Plus the battery cooling?
    Raises the question of why have a DC/DC converter in the charge unit at all? Couldn't you always use the main one? It did seem to be the case that the G5 diagrams did show the relevant wiring and fuses for the charger DC/DC, so I'm pretty certain it still exists.
    Julio_E likes this.
  2. Trollbait
    12,238
    The disconnect between battery and the rest of the car when shut down was a safety precaution for hybrids. Plus, it could have helped with the NiMH standby discharging. Good to continue the precaution with plug ins, though i don't know of any hard rules that says charging is the same as shut down for this.
    Toyota could have always used the main DC-DC converter during charging; I believe others do. I'm guessing they didn't want to muck too much in the hybrid software. The behavior seen here could the result of updating the software after field data showed their initial approach wasn't keeping 12Vs charged.
    RandyPete likes this.
  3. Julio_E
    Julio_E Junior Member
    17
    Michigan
    2024 Prius Prime
    XSE Premium
    In the youtube comments, Professor Kelly said there is a "software update to address the 12V battery drain". Perhaps this software update has already been mentioned in this forum .
  4. Hammersmith
    Hammersmith Senior Member
    1,886
    1,875
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yes it has. Only applies to Primes.
    Julio_E likes this.
  5. peternumber2
    peternumber2 Member
    117
    26
    Rome
    2023 Prius Prime
    is there any way to check if my software is updated?
  6. Mendel Leisk
    40,235
  7. RandyPete
    RandyPete Active Member
    369
    150
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Same question. Is there any way to check if my software is updated ?
  8. Gokhan
    Gokhan Senior Member
    5,541
    2,174
    Paramount CA
    This was already posted elsewhere. There is not much info in the video than we already didn’t know.
    Gen 5 Low Voltage Charging System YouTube Video | PriusChat
  9. Gokhan
    5,541
    2,174
    Paramount CA
    There is no DC–DC converter in the charger. The charger is an AC–DC adapter—120/240 V AC input, high-voltage DC output. There seems to be also a DC–AC inverter in it to supply the 120 V AC sockets from the high-voltage battery.
    Yes, the DC–DC converter, which converts high voltage DC to 12.89–14.4 V DC, turns on both in Gen 4 and Gen 5 during active charging and turns off when the traction battery reaches 100% SOC. The difference between Gen 4 and Gen 5 is that in Gen 4, the voltage is kept at a float voltage (about 13.0 V), whereas in Gen 5, it is about 14.1 V and charges the 12-V battery.
    As for the causes of the 12-V-battery problems, the main cause is the miserly battery-management system (BMS), which likes to keep the 12-V battery at a lower SOC (~75%) most of the time. An AGM-battery upgrade seems to somewhat help, as it charges faster. Other than that, the best thing you could do is to occasionally hook up a battery maintainer to bring the SOC to 100% to reduce sulfation. It is not mention that if you don’t drive the car every few days for at least one hour each time, the parasitic drain will keep lowering the SOC and add to the sulfation.
    #29 Gokhan, Jan 12, 2025
  10. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    It seems that thread was posted nearly simultaneously, just a couple of minutes after this one. It would make sense to merge it with this, as this is the correct forum, and looks like we're discussing the same stuff.
    And there's been more on another thread - going to repost my thoughts from there as they're more relevant here.
    My current view is that there still is a second DC-DC converter, cos you can see the wiring and fuse in the diagrams, which then suggests the systems can still be isolated - otherwise why retain the second?
    My guess is it activates the main one for 12V charging (as was happening in that video), My Room mode or HV battery cooling, but otherwise leaves the main system off. More investigation required.
    It occurs to me that we don't know the car was actually charging the HV battery in that video for certain. He had no instruments on it. It could conceivably have decided to charge the 12V battery first.
    He mentioned the green 'charging' light being on, but that doesn't mean 'charging', just 'drawing AC power'. It comes on when just heating the HV battery before or after charging.
    So no definite evidence of it breaking the 'only one system accessing the HV battery at a time' rule yet. (Although I still suspect it does).
  11. Prodigyplace
    12,366
    11,661
    Central Virginia
    Good idea. Perhaps @Tideland Prius can clean this up (and then delete my post?).
  12. Gokhan
    5,541
    2,174
    Paramount CA
    I think the professor is mistaken. I don’t think there is a “sub DC–DC converter” in the AC–DC charger. I do not see any such wiring in his video.
    As far as I know, there is only one DC–DC converter, and there is only one 12-V system. There is not a second 12-V system or a second DC–DC converter. Again, I think the professor was mistaken. The DC–DC converter also turns on in Gen 4 during AC charging, but the voltage stays around 13.0 V (float voltage) instead of 14.1 (charge voltage) as I explained.
    The AC–DC charger also seems to have a small DC–AC inverter for the my-room mode. That is all. See the three wirings: 120/240 V AC input, high-voltage DC output (AC–DC adapter), and 120 V AC output (a small DC–AC inverter for the electric outlets). There is no 14.1 V DC output as the professor claimed.
  13. Mendel Leisk
    40,235
    Hah, you’re right.
  14. Tideland Prius
    16,402
    Threads merged
    Brian1954 and Prodigyplace like this.
  15. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    A note in both the G4 and G5 manuals suggest that might be a thing:
    "In the following situations, charging time may become longer than normal:
    The charge in the 12-volt battery is low, for example due to the vehicle being left unused for a long period of time."
  16. Gokhan
    5,541
    2,174
    Paramount CA
    Come on, that is a trivial statement saying that the current the DC–DC converter draws comes from the traction battery, which increases the charging time by reducing the total current going into the traction battery. If you are drawing 15 A at 14.1 V, that is about 0.2 kW, which reduces the charging power from 3.5 kW to 3.3 kW, increasing the charging time by about 10%. (Again, there is only one DC–DC converter—no such thing as a sub DC–DC converter as the professor mistakenly claimed.)
    @Roy Peterson has done much better experiments than the professor on this. In Gen 5, the DC–DC converter turns on at 14.1 V while the traction battery is charging. It turns off when the charging is complete. It is the same thing in Gen 4, except the voltage is kept at about 13.0 V instead of 14.1 V.
  17. Prodigyplace
    12,366
    11,661
    Central Virginia
    If you watched the whole video, the professor corect his statement after his tests.
    Gokhan likes this.
  18. Gokhan
    5,541
    2,174
    Paramount CA
    Ah, @KMO, see the very end of the video where he admits he was wrong and there was no such thing as a sub DC–DC converter.
    I mean—this is such a trivial observation for us owners with technical knowledge, but I guess even professors can reach silly conclusions by not doing a careful observation. Why so trivial? Because the 12-V charging system works through a battery-management system (BMS), which controls the DC–DC-converter output voltage. It behaves similarly when the car is in the ready mode or the traction battery is charging—controlling the voltage as needed. To add more to the obvious, there was clearly no 14.1 V DC output terminal on the AC charger.
    #38 Gokhan, Jan 13, 2025
    Prodigyplace likes this.
  19. Prodigyplace
    12,366
    11,661
    Central Virginia
    i thought perhaps the previous generation has 2 DC-DC converters.
  20. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    All we can gather from that video is that it's not true that the main DC-DC is never used.
    Be careful to not end up like Paul whats-his-face and his "never engine braking in D" obsession based on incomplete data.
    Still, it does look suspiciously like we need to recheck that the sub DC-DC exists.
    I've been rechecking the NCF and wiring diagrams. I only see one direct mention of the sub DC-DC converter in NCF:
    "Using the sub DC-DC converter built into the electric vehicle charger assembly, the auxiliary battery is charged with the minimum necessary power to reduce power consumption."
    But that presumably could be an erroneous carry over from G4.
    In the list of components used by charging, the NCF does state that the main DC-DC converter is used for the battery heater:
    "DC/DC Converter (Inverter with Converter Assembly): When the battery heater system is operating, supplies power to the battery heater at a reduced voltage."
    Which, by omission, suggests it is not used for normal charging. But then of the charger assembly it only says:
    "Electric Vehicle Charger Assembly: Boosts the AC voltage from the external power source and converts it into DC power to charge the HV battery assembly."
    Leaving open the question of who's supplying DC to the system.
    Fuses and connections in the wiring diagram show:
    AMD -> DC/DC 130A from main inverter with converter
    AMD -> AMD2 40A from the solar assembly
    AMD2 -> AMD2 CHG 10A from the charger
    Common naming strongly suggests that those are all outputs, rather than the charger only drawing power. Although I don't know what "AMD" stands for. Anyone have any idea? (And it is possible that the AMD2 naming is just a holdover from a previous implementation where it was an output.)
    But the 10A fuse indicates that if that is an output the charger really cannot be capable of supplying very much at all.
    So in that video, to keep charging the battery, the main DC/DC would absolutely have to have been enabled.
    But you can't conclude from the evidence in that video alone that it wouldn't shut it off when the 12V was charged and the 12V load was back in single-digit amps.
