TPMS Flashing with New Wheels Installed
Discussion in 'Prius v Accessories and Modifications' started by h-dogg, Feb 13, 2012.
  1. h-dogg
    h-dogg Junior Member
    44
    South Bay
    The TPMS on my Prius v 3 keeps blinking after I installed new aftermarket wheels. I followed the steps for resetting the TPMS button below the steering wheel from the priuschat forum. After a long drive it will blink again.
    Any thoughts on fixing the blinking light besides elec. tape?
    I sure miss my simple car that didn't have all these fancy sensors.
  2. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Did you get TPMS sensors on your new wheels?
    If so, you'll have to go back to the wheel vendor or a Toyota dealership to get the new sensors "registered" with your vehicle's TPMS.
    If not, you'll have to just live with the flashing light.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    If I am not mistaken, after 2007(?) all new vehicles are req'd to have a TPMS. Your simple car must have been an older model.
    Have to checked to make sure your pressure is set high enough? Check in your manual and make sure that the resetting procedure is the same as the one you read here n Priuschat as well.
  4. qbee42
    3,079
    You need to have your car programmed to use the new TPMS sensors. This is something you will have to do every time you switch the wheels.
    Alternately, use Schrader EZ-sensor TPMS sensors on your replacement wheels. These are programmable, and can be set to echo the same ID as your existing sensors:
    http://www.schraderinternational.com/Products/Sensors/NA-Schrader-EZ-sensor
  5. h-dogg
    44
    South Bay
    Thanks for the replies!!
    I got it..the aftermarket wheels don't have the TPMS installed on them. I don't feel like taking out the OEM ones out after installing the wheels.
    Any tips on buying aftermarket ones? I'll look into the Schrader link you posted qbee42.
    The OEM ones are pretty expensive and you still have to go back to get them programmed.
    I guess I'll live with the TPMS light on for now.
    My simple car is a 2000 echo..
    Thanks!
  6. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I assume it's the same sensors that they've used in the Gen 3 Prius, and you can typically find them on eBay too. It's actually a pretty common sensor, there's a thread somewhere on here with the part # by Pacific that you can search by if it's the same one.
    If you use the Schrader one, you need to get the existing TPMS IDs to know what to program them to also.
  7. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    You can also bypass the TPMS. There is a link in my winter tire advice thread or search for TPMS bypass in the gen III mod forum.
    I bypassed on my V. It is super easy to do.
  8. padrino
    padrino Junior Member
    Sun Diego
    I just did the bypass also. Super easy once you know the pin numbering diagram is looking at the male AND NOT the female side of the connector. I used 18 ga solid wire and shoved it in the back of the female side of the connector shunting the number 5 and 7 pins. Do not plug the connector back in. Red tape it so no one will. Thanks forum for this tip!
