Prime SE owners: anyone driven to empty ?
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Jan 13, 2025.
  1. Templeton
    Templeton Member
    279
    84
    usa
    2024 Prius Prime
    SE
    For gen5 prime SE owners (and/or maybe prime XSE owners too), has anyone driven their prime in HV mode to "zero miles" HV range and then all the way until the ICE stopped because of a lack of gas? (and then continued on in EV mode to a gas station)
    If yes, how many miles further (after the HV range indicated "zero miles") were you able to go on gasoline (not electricity)? While driving those last few gasoline miles, were you on a freeway at 70mph, or on slower surface streets? If you were on surface streets, what was your approx (average) speed?
    I ask only because certain cars have a lot of "reserve" in their fuel tanks. And sometimes it is good to know (at least approximately) how many more miles might be possible after the GOM displays "zero miles" HV range.
  2. Xse
    Xse Member
    72
    29
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    Never let pirus run that low
    Don’t do it you will be sorry
  3. Templeton
    Templeton Member
    279
    84
    usa
    2024 Prius Prime
    SE
    No plans to do it, more just wondering if anyone else has already done it.
    Interesting side note: on another forum, multiple rav4 prime owners have done exactly this (driven to empty, and then the car auto switched to EV mode) and none have reported any lasting ill effects.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,140
    557
    Alberta
    2024 Prius Prime
    XSE
    I ran my Gen 3 to the point of the gas engine stopping more than once. As a test, when I was coming home from a vacation in BC, my refuel light came on at Field BC, and I hit the trip meter. I nearly got home, but the engine quit when the trip meter said 180 kms. I could have probably limped along on electric power for another 20 kms, at about 30 kph max, but that's when I elected to put 10 L of gasoline in the tank. It started and ran normally, and it easily made it to the next gas station.
    Another time, I had been running around town on Empty, not paying attention, and the engine quit. I ran for a while on electric, but I stopped a bit short of a gas station. I had to walk for a jerry can. Once again, it started and ran normally afterwards.
    I honestly can't imagine that this was damaging to the vehicle in any way.
    I have tried similar tests with my Gen 5, but so far the car hasn't run out of gas.
  5. bisco
    51,882
    doesn't the manual state how many gallons are in reserve? i think my gen 3 said 2g or so when the refuel light comes on.
    i ran my gen 2 out of gas by accident. drove on electric until it shut down and the dash lit up.
    added a few gallons and she fired right up
  6. Gokhan
    Gokhan Senior Member
    6,163
    2,434
    Paramount CA
    @bwilson4web experimented with that in his Gen 4 Prime. I don’t understand why you would do that, but his conclusion was that the car eventually refuses to drive if you keep doing that.
  7. Paul Gregory
    2,140
    557
    Alberta
    2024 Prius Prime
    XSE
    On my Gen 5, it shows the range to empty. Once it reaches zero, it resets again to 40 kms. (with the warning light on). Once that depletes, it simply says, "refuel." So far, I've always got to a gas station before it stopped running.
  8. Paul Gregory
    2,140
    557
    Alberta
    2024 Prius Prime
    XSE
    I'm not sorry at all. I wanted to determine the actual range.
  9. KMO
    KMO Senior Member
    1,953
    678
    Finland
    2023 Prius Prime
    The G5 is specced to have 6.0 L / 1.7 US gallons of fuel remaining when the "low fuel" warning appears. That should easily be good for at least 100 km / 60 miles of HV. There's no direct spec of where "zero range" is, but you can infer it from that.
    This weekend I drove down to 10km left on EV range and "Refuel" (what it says after reaching zero) on the fuel range.
    Low fuel warning had come on with 35km left on the fuel range - I drove on maybe 15km past "refuel", but not sure how much of that was EV.
    When filling up it took 35 L (9.2 US gal), suggesting 5 L (1.3 US gal) left in the tank. More than I expected - suggests the low fuel indication being a bit conservative, or maybe the pump just cut off early.
    Based on a conservative 6.0 L / 100km, if the "low fuel" comes on at 35km, you could expect at least 65 km of HV past "refuel"/zero range.
  10. Gokhan
    6,163
    2,434
    Paramount CA
    You don't need to run out of of the fuel to determine the range. You know the average mpg and the fuel-tank capacity given by Toyota and combined with the gas-station receipts (how much gas left in the tank), you have all the info you need.
  11. Paul Gregory
    2,140
    557
    Alberta
    2024 Prius Prime
    XSE
    I prefer my way.
    It's more accurate.
  12. Xse
    Xse Member
    72
    29
    2024 Prius Prime
    XSE Premium
    Think about 2 things low fuel or out off gas
    Fuel pump needs to be in fuel to stay cool or overheat
    Cat Converter plus damage exhaust system
    Up to you all
    #12 Xse, Jan 14, 2025
    Prius Maximus likes this.
  13. Templeton
    Templeton Member
    279
    84
    usa
    2024 Prius Prime
    SE
    Unfortunately, knowing the size of the tank does really answer this question. Because all fuel tanks have some amount of unusable fuel.
    The reason l ask this question is that some people with rav4 primes have reported being able to drive over 100 miles in HV mode beyond the point when they get a 'refuel' message. I was wondering if this is similar on the prius prime as well.
  14. Trollbait
    12,511
    Which isn't an accurate measure of how far the car can go in HV mode alone, if there was grid charge left. An owner has seen that the car will use some of that grid charge in HV mode for better efficiency.
  15. Paul Gregory
    2,140
    557
    Alberta
    2024 Prius Prime
    XSE
    Think about this: If the engine's not running,
    there's nothing to overheat the fuel pump.
  16. Templeton
    Templeton Member
    279
    84
    usa
    2024 Prius Prime
    SE
    I am not familiar with the term, 'grid charge'. Do you mean electric charge (drawn from the grid) in the traction battery over and above the minimum needed for HV operation?
    Per some posts I have followed about rav4 prime range in HV mode, I think folks did indeed have some grid charge on their rav4Ps, but they were driving in HV mode with the HV indicator showing (i.e., the ICE was on and moving the car). And they noted that their grid charge did not decrease appreciably during their test drives, or changed maybe plus/minus 1 mile. So, you are right, an exact number miles in terms of range might not be possible. But just seeing that it was possible to drive over 100 miles on gasoline past the "zero miles" indication meant that the usable reserve on a rav4P was fairly generous. Which made me curious if a similarly large gasoline reserve exists on the prius prime as well.
  17. KMO
    KMO Senior Member
    1,953
    678
    Finland
    2023 Prius Prime
    Are you sure they said "past zero miles" or was it past the low fuel warning, which happens considerably earlier?
    The low fuel warning in the RAV4 is specced as 8.3 L (2.2 US gallons). 100 miles past low fuel would hence require 45 US mpg - possible, but far from guaranteed.
    Given the smaller 6.0 L (1.7 US gallons) value for the Prius, you're not realistically going to get 100 miles in HV past low fuel. As I said above, 60 miles or 100km should be easily achievable.
    Trollbait likes this.
  18. Mendel Leisk
    41,384
    With our ‘58 VW bug my dad would take off the gas cap (under the hood) and check how much gas was left, with a stick. There was no gas gauge. There was a last minute recourse: when the engine started to sputter, you could reach down and rotate this lever on the firewall, which release an emergency reserve. Gives you a different perspective.
    Now, you buy a $40k vehicle, with a gas gauge and this miles-to-empty jazz, and still you want to run it down till there’s about about a tea cup of dregs sloshing around in there.
    Xse, Gokhan and Trollbait like this.
  19. Trollbait
    12,511
    Correct.
    One of the first owners here was trying to test the hybrid fuel economy. They did this by putting the car into HV mode with charge left. The results were unexpected, too high IIRC. Over an entire tank, the EV charge display did start to drop. That display, nor the range estimate, is not accurate enough to let the driver know how much the battery was depleted. Then just giving a hybrid more capacity to use will improve fuel economy with the balance of the charge averaging the same.
    A Prius PHV will go about 85 miles on 1.7 gallons by the EPA combined rating. I would not plan on it going farther than after the low fuel light came on.
    I agree that they were likely reporting range from low fuel light. My Toyotas stopped displaying a distance to empty figure once that came on. Easy to mistakenly report that as zero miles.
  20. Paul Gregory
    2,140
    557
    Alberta
    2024 Prius Prime
    XSE
    I was able to do my test by carrying a 10L fuel container. Something I learned to do years ago (from bitter experience). It may not be strictly legal to do so, but I'll chance the consequences against the peace of mind I get from having it in my car.
