Trunk light - any way to add switch to it or turn it off? It drained my battery.
Discussion in 'Gen 5 Prius Main Forum' started by wstt, Jan 14, 2025.
  1. wstt
    wstt Member
    147
    22
    My battery went dead and I couldn’t start the car and had to call Geico to get a jump start. is their any way to add a switch to the cargo light, or disable it in the menus? I’d still like to be able to turn it on at times but would prefer it to be off most of the time.
    51,040
    did you leave it on? dead 12v in gen 5 is fairly common
  3. Blackat
    Blackat Active Member
    398
    264
    Colorado
    2023 Prius
    Limited AWD-e
    Mine is off all the time until I open the hatch
    Sharol likes this.
  4. Paul Gregory
    Paul Gregory Senior Member
    1,391
    360
    Alberta
    2024 Prius Prime
    XSE
    Mine doesn't stay on. It only comes on when I open the hatch. Sounds like a faulty switch to me.
  5. hill
    8,624
    Don't they normally turn off after 5 or 10 minutes when it's left open? Ours is LED so the draw is minuscule
    #5 hill, Jan 14, 2025
  6. Paul Gregory
    1,391
    360
    Alberta
    2024 Prius Prime
    XSE
    Any small jump starter will start your Prius. Even those small ones, no bigger than an iPhone.
  7. priusdriver223
    82
    31
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, yea I recently found a someone that sells something like that on eBay, it has a on and off switch, off being permanently off, and on being regular oem function. Been couple of days since I bought mine, it’s VERY bright and works well. Listing is “LED trunk light for 2023 prius”Cheers!
    Templeton likes this.
  8. Mendel Leisk
    40,495
    For sure it’s got no switch? Our gen 3 has one. Seems like Toyota keeps finding stuff to delete.
  9. hill
    8,624
    It's getting kind of frustrating. What's next on the delete list, customers?
  10. Paul Gregory
    1,391
    360
    Alberta
    2024 Prius Prime
    XSE
    I mounted a cheap battery operated light on the rear hatch lid.
    Much more useful.
  11. bisco
    51,040
    It’s amazing how weak the lighting can be with all the modern options
  12. Paul Gregory
    1,391
    360
    Alberta
    2024 Prius Prime
    XSE
    The existing light is not very bright, and in a poor location. Mounting the light on the hatch works well.
  13. Girl__wonder
    Girl__wonder Junior Member
    My solution: always lock the car, even in the garage. If the hatch door is ajar, it won’t lock.
    (FWIW This happened to me last year on my 2006. The AAA guy who came to jump the car said I was the second Prius with that problem that day! In my case, a cloth shopping bag kept the hatch from completely closing. Oof!)
  14. Paul Gregory
    1,391
    360
    Alberta
    2024 Prius Prime
    XSE
    Yeah, like the grill shutters and the exhaust coolant heater.
  15. Paul Gregory
    1,391
    360
    Alberta
    2024 Prius Prime
    XSE
    When I got mine last year, a dead battery was almost a daily occurrence. I had to carry a booster pack, because I didn't have the patience to call for a jump start every time. I don't know the exact voltage where it happens, but it only has to drop a little below 12V for there to be a message saying "battery too low" and it won't start up the car.
    There should be a simple mod that takes a small amount of power from the 222V hybrid battery, to activate the DC-DC converter in order to charge the 12V battery to start the car. Instead, you are expected to get a jump start or call the dealer. Totally stupid design.
  16. Mendel Leisk
    40,495
    Or find and remedy whatever imposing the excessive load on the battery. If it’s systemic Toyota “should” step up. Don’t hold your breath.
  17. Paul Gregory
    1,391
    360
    Alberta
    2024 Prius Prime
    XSE
    The drain was variable when I measured it. I decided to assume it had something to do with the data connection for over the air updates. I had a dealer check it out, and they had no answers. At any rate, my workaround is a battery maintainer and an auxiliary battery.
