Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. xliderider
    xliderider Senior Member
    8,037
    3,211
    Honolulu, HI
    Are the PCV valves in the diagram backwards? The threaded portion of the valve is in the block, no?
    SM-G781V ?
  2. PTS
    PTS Member
    74
    34
    Austin, Texas
    2013 Prius v wagon
    Here is another one. Flow is always engine to intake.
  3. xliderider
    8,037
    3,211
    Honolulu, HI
    Thanks, that makes more sense.
    SM-G781V ?
  4. hotelprisoner
    hotelprisoner Member
    101
    85
    Ontario, Canada
    Technology
    Frankenbuilt this while the car was down for HV battery reconditioning this past week. It’s based on the larger OCC Victorine posted about above and is a replacement to the smaller Mishimoto version that was previously installed.
    This iteration seeks to address 2 issues. Firstly, I reside in SW Ontario, Canada where the winter produces large volumes of condensed shmoo. Secondly, on reading about flow resistance to some of these setups, the goal was to reduce resistance to airflow by increasing the filtered surface area. On cleaning the previous model last summer, I found the disc filter to be clogged enough to restrict cleaning fluids from passing and it’s cleaned on a regular basis.
    Minor mods were required to enlarge the diameter to allow for the threaded pipe nipple and create a hole in the baffle to accommodate the same. If I remember, I’ll update this winter to see how it goes.
    I admittedly have no way at the moment to test for a performance increase due to less flow restriction. If the unit behaves, I’m just going to put it down to a feel good win. A proper test would have been to document pressures before and after modding.
    When installing it, the clearances were very tight and I fabricated the brackets from steel stock obtained from Crappy Tire. I had to swap the straight pipe fitting from the drain to the outlet and bend the elbow towards 45 degrees. All threaded fittings were sealed with a high temperature thread sealant.
    It’s not light so I added a second support bracket. I admit I don’t totally love the location, I’d rather have it low, but I need accessibility to drain it almost weekly in the winter.
    iPad ?
  5. Abarnabe
    Abarnabe Member
    149
    Netherlands
    Last Sunday I installed my OCC under the snorkel, I drilled 2 x 3mm holes and used 2 self tapping screws and at the same time did some intake cleaning with a collection of steel brushes and an aluminium pipe as extender.
    It is accessible from above once removed the snorkel, and it' s almost invisible, but the occ hoses are very close to the ac hose and I'm worried about long term wear if they rub during accelleration and brake.
    Also I'm concerned that some oil might pool in the hoses since the occ is about the same height of the holes it taps from, so I'm considering to relocate it down on the lower beam as Mendel did.
  6. rjparker
    9,519
    5,825
    The last thing you want is your pcv hoses or catch can filling up enough to stop pcv flow. At that point you start creating oil leaks due to crankcase pressure, usually starting at the timing chain cover.
    Keeping the engine from burning oil is the preferred way to minimize piston ring blowby which moves more liquids through the pcv system.
    Newer Toyotas have built in catch cans which drain liquids back into the crankcase.
    Abarnabe likes this.
  7. Mendel Leisk
    40,495
    Which ones? I know the Gen 3 has a rudimentary labyrinth behind the PCV valve, but not very effective.
    ^ Did you consider just cutting the original PCV hose, per @danlatu describes, on page one? It's a perfect fit at the intake manifold (of course), much less bulky with it's original spring clip, and serves as an elbow, can be turned downwards and out of the way very compactly.
    Note too: airplane clips such as those shown are hard on plastic, create point loads. Also, clips of any sort or not needed, when hoses are pushed onto properly sized barb connectors.
    ^ The only clips I use are the two original spring clips, on the ends of the cut-in-half, stock PCV hose. If you're concerned about compromising that hose, say if you want to return the system to stock before selling, replacement PCV hose only costs about $10~15:
    #2327 Mendel Leisk, Jan 14, 2025
    Abarnabe and MAX2 like this.
  8. rjparker
    9,519
    5,825
    The gen5 engines like the 2.0L and 2.5L with dual injection and electric variable intake timing.
  9. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    Someone on here did a mod on their Gen 3 that routes the pcv to the crankcase.
    Not sure how it worked out for him but if Toyota did it to their Gen 5 then it must work.
  10. Mendel Leisk
    40,495
    PCV is coming from the crankcase; not sure how that’d work. Maybe just the collected liquid?
  11. AzusaPrius
    2,137
    900
  12. Abarnabe
    Abarnabe Member
    149
    Netherlands
    Yes, next weekend I'm going to do that and I'll move the occ on a lower location if it doesn't rain :)
  13. Mendel Leisk
    40,495
    When I installed my bracket on the lower cross beam I drilled through-holes, 3/8" diameter in the beams top flange, then ran 5/16" or 1/4", forget bolts through from the underside (there are some cutouts in the bottom flange of that beam, that you can fish the bolts through. then rubber gasket, then bracket, and nuts and washers on the top. I installed a first nut just firmly snugged, then a second nut atop it, torqued the second nut against the first, locking it.
    That was majorly difficult though. In hindsight, it'd be preferable to just drill pilot holes in the top flange, then rubber gasket, bracket, washer and self-tapping screws.
    What I do now, on the one or two occasions I've taken that bracket off (mainly when I replaced single OCC bracket with one long enough for dual OCC), I stuff rags into that lower opening, so when I remove all the top side parts, the bolts stay in position. :)
    I also added slots to the bracket, between the original slots and the flange edge, so that I can just slghtly loosen the bolts on my OCC brackets, and lift them up and off. This is the old bracket, for single OCC, similar slots:
    #2333 Mendel Leisk, Jan 15, 2025
    Raytheeagle, MAX2 and Abarnabe like this.
  14. Abarnabe
    Abarnabe Member
    149
    Netherlands
    Thanks for sharing Mendel. Very useful information, especiallly the drawings the double nuts and the rags tip. I will take it in to account.
  15. Awells80
    Awells80 Junior Member
    36
    Louisville, Ky.
    I have a catch can on my SC and I now after reading this thread, I think it might be the CT’s turn!
  16. Mendel Leisk
    40,495
  17. xliderider
    8,037
    3,211
    Honolulu, HI
    Or... you could've used some rivnuts/rivet nuts, and set them in those holes you drilled in the crossmember. If you don't have a rivet nut tool, there are manual kits that let you set them using only wrenches.
    Limited-time deal: HARDELL Rivet Nuts Tool, 14" Hand Rivet Tool Kits with 100Pcs Rivet Nuts and 7 Metric & Inch Mandrels M6 M8 M10, 1/4-20, 5/16-18, 3/8-16, 10-24 and Rugged Carrying Case https://a.co/d/j8qJLl5
    HIFESON Hand Rivet Nut Tool,Handy Rivnut Tool - Metric & SAE with 30pcs Steel Rivet Nuts,Rivet Nut Kit with Sturdy Case Packed, Designed for Tight Space (Steel) https://a.co/d/bKm6pQE
    Best part about rivet nuts is, you don't need access to the backside of the hole, the rivet is the nut, so no fumbling with loose nuts when assembling or securing the bolts.
    SM-G781V ?
  18. Mendel Leisk
    40,495
    You jogged my memory, yeah, I was toying with that idea too. They'd be more "pro" than self-tapping screws too. (y)
    I've got 3/8" holes drilled there now. They just might be appropriate size, for a 1/4" dor 5/16" bolt, or at the least on the small side, could be drilled out to suit.
  19. Abarnabe
    Abarnabe Member
    149
    Netherlands
    Yesterday I relocated the occ to the lower beam, cut the original elbow hose and inserted a 9.5 mm aluminum pipe I had in the shed also painted and cutted an L plate coming from the same pile of metal scrap.
    The hoses are now shorter and pointing straight down.
    The foto shows the liquid collected in a week or 500 km of my previous set up.
    I followed the advise to place some rubber between plate and beam, but fastened with 3x 3.5 mm self tap screws because it was too cold to lay on the ground with 0°C.
    A few years ago I got one paralized leg by laying down on the groud with that temperature .
    The coolant hose coming from the thermostat is in direct contact with the occ hoses so I laid in between a layer of rubber ( an old bicycle inner tube ) and fastened with zip ties.
    Same thing between the coolant hose going to the throttle body and the OCC hose maybe overkill.
    #2339 Abarnabe, Jan 19, 2025
    xliderider and Mendel Leisk like this.
  20. Mendel Leisk
    40,495
    Barb splicers (or similar Pex splicers) will be much more secure. The sharp ridges secure and seal very effectively. They’re also almost impossible to get the hoses off afterwards, so what I did was slightly blunt the sharp edges.
