Coolant Temperature Sensor Location?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Ferdman, Dec 22, 2024.
  1. Ferdman
    Ferdman Junior Member
    southern California
    2014 Prius c
    Hi All. First post here. I got the the red flashing coolant warning. It only happens an freeway speeds. At low speed it's OK. I pulled the ODB2 code an saw the P1117 thrown which indicated the coolant temperature sensor. I purchased one as well as a thermostat. My question is where is the coolant temperature sensor located? Google searching only gave results for the regular Prius, but not the C. Maybe I'm not searching well enough, but could use some help here. Thanks in advance.
  2. Ferdman
    southern California
    2014 Prius c
    Anyone? BTW, it is a P0117.
  3. Ferdman
    southern California
    2014 Prius c
    If it's in the same location as the 1.8L engine, I got it.
  4. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    If you don't get any helpful info here, I'd recommend you try following the coolant hoses using the info you already found about the regular Prius location. If that doesn't help than there is always a 2 day $25 subscript to the repair manual which will include detailed instructions on how to actually install the part.
  5. ChapmanF
    18,088
    P0117 is a "low" input from the coolant temperature sensor, and Toyota uses negative-temperature-coefficient thermistors (the resistance goes lower when the coolant gets hotter) for these sensors—so a "low" input from the sensor corresponds to very hot coolant (or could also mean damage to the sensor wires so they touch each other and short). A wiring problem is more likely than the sensor itself going bad, something I've never seen happen, but there's a test if you want to be sure.
    Because your overheat warning light ("hey the coolant reads hot") flashes at times of high load on the freeway (when hot coolant could be believable), and the P0117 code ("hey the coolant reads off-the-scale hot") can also mean just what it says, I think the first order of business is to make very sure your engine is not really overheating at those times.
    If you're sure it's not really overheating, then you can proceed with whether the sensor or (more likely) wiring might be bad.
    But I would start with what the coolant level is (in the bottle and in the radiator neck). With an OBD-II scan tool you can watch the temperature reading as you drive. If the reading matches the weather when the car has been sitting before you start it, and if the reading increases steadily as the engine warms up, and on the freeway keeps rising to where the warning light flashes, I would say the sensor is doing its job just fine and you shouldn't shoot the messenger just because it's telling you the engine's too hot.
    On the other hand, if you see the reading not match the weather when the engine is cold, or you see the reading bouncing weirdly or flakily like it isn't really tracking the coolant temperature, that could be more of a sign of a sensor or wiring issue.
    MAX2, Brian1954 and Ferdman like this.
  6. Ferdman
    southern California
    2014 Prius c
    Thank you. Do you have a link to this manual?
  7. Ferdman
    southern California
    2014 Prius c
    I was wondering if my engine was actually overheating or just a bad sensor. My ODB-II reader only gives codes. Guess I'll have to get one that monitors in real time. The coolant is full on both reservoirs. Heater works, if that says anything.
  8. ChapmanF
    18,088
  9. Blaine F
    Blaine F New Member
    Ohio
    OP, did you have any luck on this?
    I recently got the same code and am having the same issue. Can not find any good info on the location of the sensor. Thanks for any info!
    Cheers
  10. Brian1954
    Brian1954 Senior Member
    2,162
    839
    South Central PA, USA
    How many miles on the car?
    The temperature sensor is very reliable and rarely fails. You need a scanner to monitor the engine coolant temperature. Read post #5.
    My guess is a failing engine water pump.
  11. Blaine F
    Blaine F New Member
    Ohio
    I’m at 160k and haven’t had any over heating issues. I have about a 35 min commute and haven’t had any problems other than average mpg has dropped slightly. Temp seems good. Heat still coming through fine and no warnings on the dash
  12. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    89429E
    89429-47010
    WATER TEMPERATURE [12.2011 - 12.2014] NHP10
  13. ChapmanF
    18,088
    If that's a Prius c diagram then it appears the c has the exhaust heat recovery system like the liftback, and the sensor shown there as 89429E is almost certainly the EHRS one. If the similarities to the liftback hold, then a concerning reading from that sensor would give a B1503 code, and the engine coolant sensor (the one a P0117 code is about) will be one that's threaded into the cylinder head.
    Brian1954 likes this.
  14. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Yes, that's right. The second temperature sensor is on the cylinder head.
    89422-33030
  15. Blaine F
    Blaine F New Member
    Ohio
    So it sounds like I should check the one on the cylinder head as the primary source of the issue?
    Thanks for all the insight. I’m not too savvy with working on cars, so this has been immensely helpful
  16. Brian1954
    2,162
    839
    Do you have a "check engine" light and trouble code P0117 when the engine is cold in the morning after sitting overnight?
    #16 Brian1954, Jan 26, 2025
