Any Gen 4 Owners Out There With Blown Head Gasket ??
Discussion in 'Gen 4 Prius Main Forum' started by AmazingFacts, Jan 14, 2022.
  1. RachaelRainer
    RachaelRainer Junior Member
    Los Angeles
    Gasket Masters on youtube said they have seen many Generation 4 prius with blown head gasket. (Youtube Shorts) I saw it yesterday.
  2. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    Most if not all of those are due to faulty heater control valves along the exhaust system that stick and dump all the coolant out of the tailpipe causing an overheat condition. I think I've only seen one early 2016 car with "Uber miles" on it go through a head gasket naturally from a bad water pump.
  3. V Sport Wagon
    375
    131
    Southern California
    If I may, it's not virtually the same at all on the inside. There are a ton of differences for the better, like more efficient cams, heads, pistons, water jackets..etc. Remember head gaskets fail mainly (Gen 4 since this is the forum to discuss this... because A) Water pump old and failing/failed B) Never flushing engine coolant C) Gen 4 heater control valve down below. If there's any evidence of gasket material being the issue on Gen 4's failing prematurely outside of those scenarios listed above....please, would love to see the evidence.
  4. V Sport Wagon
    375
    131
    Southern California
    Leak maybe, likely just coolant reservoir level dropping and/or Temp Light at which point you've done damage to the head gasket already or it's already failing. Always pop the hood and watch coolant levels on ALL Prius cars.
  5. bryanpenn
    bryanpenn New Member
    Oregon
    Hopping in here as a first time poster but long time reader of these threads fir helping with repair. Had a 2010 Prius for 12 years, bought with 11k miles and traded in at 186k only having to do spark plugs, regular fluid changes and a set of rear brake pads. Traded for 2016 prius 3 about 9 months ago with 50k and have loved it, just had a cold spell in Oregon last week and just the other day my heater stopped working... Hadn't seen any fluids going down or temp light come on but am seeing white smoke while going uphill on my commute to work. Was going by toyota dealership on way home from work and to look at picking up a thermostat to start with and found this thread today at work. I had a talk with the guys at service counter and was news to them about the heat exchanger as well. Have an appt for tomorrow to have them diagnose the issue and hoping will be covered under the TSB! Thank you all for help along the way, your time spent sharing this information is very helpful!!
  6. bryanpenn
    Oregon
    Not a whole lot for the update yet, have been in contact with the service rep to see if they will confirm that it is something that will be covered by them to repair after they do the diagnostics or if something that I will be charged for after they confirm the issue. They will not give me a straight answer on that... I do not have an extended warranty on the car which gives me a slight pause as to if it will be something that will b e covered, but it is at just over 50k miles and everything else is in good shape. I am leaning to just do the bypass for now and then work on a few of the different Toyota dealerships around here to see if I can get anyone to state that they will cover the expense to replace.
    AmazingFacts likes this.
  7. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Thanks for the update. Have you checked the coolant level? If it's low, that's an almost sure sign that it's leaking at the exhaust heat exchange. Don't let the coolant level get low as it will cause the HG to fail. And glad to hear you're learning about the bypass. The Gates part in my signature works excellent.
    bryanpenn likes this.
  8. bryanpenn
    Oregon
    Thank you, yes the coolant level was low initially once noticed the heat wasnt working. Got that topped off and been keeping that way, picking up the gates hose to get that done for now and will see if I can stay on toyota for getting the section of exhaust replaced.
  9. Oleg Prisacari
    Oleg Prisacari New Member
    Georgia
    I change my oil every 10000 miles but i do use the 20000 mile synthetic oil and 20000 mile filter, so far i got 150000 miles on the car and its working good, i drive a lot working as food delivery
  10. Kristen C.
    Kristen C. New Member
    Las vegas
    I am having the same symptoms On my 2016 gen 4 Has 82,000 miles on it. Is this covered by the Toyota Federal Emissions Warranty?
    #190 Kristen C., Jan 21, 2025
  11. bisco
    51,037
    Not that I have read, but it’s always worth asking the dealer, and calling Toyota if they decline
  12. Mendel Leisk
    40,492
    I thought Toyota had acknowledged it, published a TSB. IIRC member "electroeng..." started a thread, posted the TSB. Sorry, can't remember his full name.
  13. Mendel Leisk
    40,492
  14. BiomedO1
    2,727
    1,456
    SacTown, Ca
    If your still within Federal Emissions Warranty period, the answer would be yes. There's no warranty question if Nevada ascribes to stricter CARB pollution standards which some states do.
  15. Kristen C.
    Las vegas
    Is this
  16. Kristen C.
    Las vegas
    No I live in California. Caris registered and insured in Cali, just visiting las vegas and was driving one nite and noticed my heater wasn't woring I thought hmmm that's odd ok well maybe it's just taking longer to come on becuz it started to get to colder 29 degrees, then not 5 miles I to the drive
  17. Kristen C.
    Las vegas
    Ok so I just took my 2016 Toyota Prius, where it broke down in Las Vegas. But I am just visiting on vacation. I I'm a California resident.I bought the car in California.It's registered in California.It's insured in California so it's all California anyhow.I had it towed to the dealership in Las Vegas with that And I want to say if it wasn't for this forum and me stumbling on it by accident.
    And having read that I should take the TSB bulletin paper with me and hand it directly to the service manager at the dealership.I'm almost 100 positive They would have made me pay for this repair period so I cannot thank you enough for me.Stumbling on this forum and for all the awesome threads I read.
    You literally saved my life!!
    BiomedO1 likes this.
  18. Mendel Leisk
    40,492
    Toyota shows their true colors with stuff like this. An "honourable" stance would be:
    1. Admit they messed up.
    2. Increase manufacture of the required part.
    3. Nix the time/mile limit.
    4. Make sure dealership are fully responsive, and aware of the coverage.
    Food for thought, next time you're buying a car. Maybe they're all the same, but who knows.
  19. Kristen C.
    Las vegas
    Well Here's an update to my previous Post.When I thought I was all in the clear and they were going to covor the repair for fixing the heater exchange, I was dead wrong They told me my car was not vin specific and it was over 80,000 miles which is what they said the warranty was for. ( I have 82,000) so they made me pay for the exact parts that are on the TSB 0135-19 which I handed to The service guy when I went into the dealership. The repair cost was $2307.35. I am in California.I registered my car in California.I bought my car in California.It's insured in California.Why is this not covered according to the TSB its 180 mo or 150,000? They had me Call their brand engagement dept. What A
    Joke they were. I got hung up on put on hold ignored for 3 days Meanwhile, I am missing work due to not having a car finally on the 3rd day.
    I got through to somebody and they told me the bad news that they weren't covering it! I feel I got GOT!! So I guess my question is, even though there is TSB Is does your car have to be vin specific. ?
  20. Mendel Leisk
    40,492
    You've got the repair done, paid, then? I'd keep all the paperwork, contact corporate again. Email preferably, so there's no discussion as to what's said. The car's registered in California, not Nevada?
    Even if they're legally "correct", say through a weasel-out clause, there's corporate "good will", aka "we don't like to look like jerks", might help.
    Keep in mind: Toyota writes these TSB's, and they make sure it's in their best interest, requires the mininum outlay of $'s, customers be damned. There's likely US government regulators overseeing crap like ths, that you could contact too.
    #200 Mendel Leisk, Jan 27, 2025
    Kristen C. likes this.
