Coolant disappearing and can't find where
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Carsten, Jan 22, 2025.
Tags:
  1. Carsten
    Carsten Junior Member
    60
    Columbia, SC
    Hey all,
    2017 Prius 2 So I'm having to add a little coolant like every other day, probably put in almost 2 gallons over 6 months and it seems to be going quicker now. I don't see any drip on the ground and am not finding any leakage at hose connections I can easily reach. Not seeing any residue, but I assume it's hitting the engine and boiling off.
    I know the heat exchanger has been a problem on these, that has been disconnected and the lines that went to it removed, I can reach in and feel where it was bypassed, no leak.
    Is there anything else I can do before I have to take it to a pro?
    Thanks
    51,552
    any white smoke from the exhaust? you might want to do a head gasket test
  3. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    Coolant leak is a serious problem. It is necessary to urgently find the place where it is leaking.
    It is worse if it is the engine.
    The piston jamming from hydraulic shock, due to coolant leaking into one of the cylinders will provide a problem with engine replacement.
  4. BiomedO1
    3,160
    1,673
    SacTown, Ca
    That coolant is going somewhere. Which coolant tank are you refilling?
  5. Leadfoot J. McCoalroller
    8,013
    7,492
    Pennsylvania
    2018 Prius c
    A few Priuschatters have had problems with the exhaust heat recovery system leaking coolant directly into the exhaust.
  6. BiomedO1
    3,160
    1,673
    SacTown, Ca
    he claims that it has already been bypassed, his second paragraph.
  7. Mendel Leisk
    41,000
    Maybe effectively stopped the leakage? He's a little vague:
    @Tideland Prius could this thread be stickied:
    TSB: Coolant leakage at front exhaust pipe (Prius & Prius Prime) | PriusChat
    douglasjre likes this.
  8. Tideland Prius
    16,505
  9. Carsten
    60
    Columbia, SC
    engine coolant, not inverter
  10. Carsten
    60
    Columbia, SC
    no white smoke
  11. Carsten
    60
    Columbia, SC
    Thanks for reaching out y'all, I meant to respond sooner but... life...
    Anyway, the problem might have revealed itself... Started the car tonight and it ran crazy rough, popped the hood didn't see anything obvious, drove half a mile and the mil came on. Plugged in my handy dandy Autel MaxiAP200 - P0301 cylinder 1 misfire.
    Maybe my coolant is going into #1 but there's no white smoke and the engine oil looks good so maybe not. Gonna tear into it tomorrow, I'll keep you posted.
  12. BiomedO1
    3,160
    1,673
    SacTown, Ca
    Pull all the spark plugs and compare the top of the pistons. They should all be universally black across the top. If coolant is leaking into one or two of them, the pistons tops will look like they been steam cleaned.
    FWIW: white smoke out the exhaust pipe is a very large leak into exhaust pipe, milk shake engine oil is a coolant leak into the engine oil jacket. If there is a head gasket issue that's causing a misfire - coolant is going into the combustion chamber. Run it like that too long, you risk bending a rod or punching a hole in the side of your motor.
  13. douglasjre
    douglasjre Senior Member
    2,147
    711
    Null, NL
    After cat heat exchanger.
  14. rjparker
    9,892
    6,095
    Jan 22
    Since July
    Nov 8
    Tuesday
    Cars can go ten years without using any coolant. Any loss is an emergency.
    Probably had the exhaust heat exchanger leak, eventually bypassed, but coolant loss occurred over a long period.
    The engine overheated many times causing a blown head gasket. Good chance there is a warped head or block as well. A rebuilt or JDM engine should be the plan.
    #14 rjparker, Jan 29, 2025
  15. Prodigyplace
    12,463
    11,706
    Central Virginia
    Did you mean OEM engine?
    I am not sure he could import a JDM engine from Japan to the US, ;) Typoes can be fun.
  16. rjparker
    9,892
    6,095
    JDM engine from distributors in the US.
  17. Prodigyplace
    12,463
    11,706
    Central Virginia
    I thought JDM meant Japan Domestic Manufacturing, destined for the Japan market, not the US. I have seen posts of people with JDM Prius wanting help with the Japanese only interface, for instance.
  18. rjparker
    9,892
    6,095
    Search JDM engines. They are used in Japan engines already imported to the US and sold at distributors in major US cities. Often in the $1200-$1500 range.
    douglasjre and Prodigyplace like this.
  19. Prodigyplace
    12,463
    11,706
    Central Virginia
    Sorry for my ignorant misunderstanding.
  20. Carsten
    60
    Columbia, SC
    Piston 1, passenger side, looks like it might be "steam cleaned". The other pistons are more tan color. It's so hard to tell tho. I'm going to get some kind of light I can stick down in there to be sure.
    I think the coolant is leaking into one or more of the cylinders, where else could it be going.
