Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. Mendel Leisk
    40,492
    Longest I see with quick look on Amazon:
    Resorting to AutoCAD, still a little on the steep side:
    Going to give it a try, hopefully ok with pooch. :)
    #2461 Mendel Leisk, Jan 23, 2025
  2. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,150
    1,683
    Iowa
    DOG RAMPS
    Dog ramps are a long running issue for me. I first had one when I had my rottweiler. That dog was 120 pounds and as she got older she could not leap into vehicles. Lifting her was a bit of a chore. I did it -- but it was a sort of Homer Simpson act. She did not like being lifted and would squirm and I would stumble about before shoving her into the car.
    A ramp saved both of us from injury.
    It seems you want to build your own and that is great, but maybe my experience will help you with your project?
    My big goldens are 97 and 93 pounds. They CAN get in my Subaru Outback, but they usually won't, without A LOT .of hassle. One of them was in a car accident with me when she was a pup and somehow survived and I think she is passing her anxiety off to the second golden.
    I can lift them in without much trouble, but my husband forbade it -- Mendel -- don't tell him I still do it now and again.
    My latest ramp is WeatherTech. They want $140 for it now, I got mine six or so years ago for $89. Indeed, the ramp came by UPS and the next day a second ramp showed up. I refused delivery and several days later another ramp showed up....:whistle:
    I am sure you have looked at WeatherTech, but they have two styles. The EasyRamp and the PetRamp.
    I have the Pet Ramp. Not a great fan, but it works. They claim it is 15 inches wide. It is, but that includes the molded edges -- subtract those and I don't know 13" or 12" inches wide. It has a steep pitch when I use it with my Outback. The pitch would be less in a rig closer to the ground, of course.
    The dogs hate it, but will use it. I think they would be better with it if it were wider. The surface has a ribbed rubber (?) covering so the dogs have excellent traction. Both "feet" have rubber cleats(?) to stop sliding -- very important -- and they work well.
    My smaller dogs don't mind the ramp -- width?
    Finally, folding it can really pinch your fingers. I still manage to get "bit" after six years.
    Don't have experience with their EasyRamp.
    Had a sliding wood ramp with the rott. Don't remember details, but it was much longer than the ramp I have now. Heavier too. It was wooden so sometimes sliding was a bit "sticky." Used indoor/outdoor carpet for the surface.
    It worked O.K. Was destroyed when a tree smashed my rig.
    kris
  3. Mendel Leisk
    40,492
    Thanks @cyberpriusII!
    DIY yielded to expedience: I ordered this (pictured above)
    71" Max Length & 20" Width Dog Car Ramps,Large Dog Folding Ramp with Non-slip Carpet Surface,Pet Stairs Ramp for Large Cars,SUVs, Trucks & Outdoor Steps, Durable Dog Stairs for Large Dogs Up to 285LBS : Amazon.ca: Pet Supplies
    The lack of side curbs is concerning, but allow it to fold more compactily for sure. Weighs around 20 pounds.
    Hopefully our Shiba Inu will breeze up it, but I've a hunch that may take some coaching. He's 14+, so in his sunset years, a little lame.
  4. jdenenberg
    jdenenberg EE Professor
    3,919
    1,917
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Mendel, Taking the tangent of the angle yields the }Rise over Run of the ramp. That should give you the information needed.
    JeffD
  5. cyberpriusII
    1,150
    1,683
    Iowa
    I think you will be fine without sides. 20" -- so probably 16"-18" wide walking surface. Shiba pups are around 50 pounds, right and not real broad like a rott, so I bet it will work fine. And the pitch looks very good. With the Outback floor being some 27" above ground, it makes for a bit of a slope.
    Of course, you start talking engineering, I am at a bit of a loss, but if you need air-speed velocity of an unladen swallow
    kris
    #2465 cyberpriusII, Jan 23, 2025
  6. tochatihu
    tochatihu Senior Member
    9,513
    3,672
    Kunming Yunnan China
    2001 Prius
    Now that's a tangent.
  7. Paul Gregory
    Paul Gregory Senior Member
    1,388
    360
    Alberta
    2024 Prius Prime
    XSE
    Five Man Electrical Band -1973, love the reference!
    ETC(SS) and cyberpriusII like this.
  8. cyberpriusII
    1,150
    1,683
    Iowa
    Folks always said I am different.
    kris
  9. hill
    8,624
    Wooah !! Saw them live at Magic Mountain So Cal, I believe in the 1970s
    Great LP
  10. ETC(SS)
    6,920
    :rolleyes:
  11. ChapmanF
    17,196
    This used to be an awesome anode rod to buy for a water heater:
    It was "R-Tech" branded, meaning an anode rod with a resistor in series. The picture shows the insulating spacer between the threaded head and the rest of the rod. There's a little ~ 62 Ω resistor across the spacer (seen here on my old one):
    It was an awesome anode rod because:
    • it's magnesium, not aluminum, which (a) creates a larger voltage difference to the steel tank, and (b) doesn't fill the bottom of the tank with the same oxidized-aluminum gunk an aluminum rod does.
    • it's a lot of magnesium. Some anode rods are much skinnier. This has about the maximum diameter you can fit through the hole at the top of the tank. It takes a long time for all that to be sacrificed away.
    • the resistor slows down the sacrifice even more. Because magnesium has a higher voltage difference to steel than aluminum has, a magnesium rod with no resistor can sacrifice itself extra fast, and maybe even make smelly gas in the process, and the conductivity of the water coming in has a big effect on the current. With the resistor in series, the current is lower overall (still enough to protect the tank), and less affected by changes in the water conductivity.
    Apparently you can't buy it anymore. Keeping the same part number :mad: they have changed it to a non-resistored (branded "ProTech" instead of "R-Tech") rod. It's still shown as resistored in that Amazon listing and in the catalog at my local Ferguson's, but if you buy one you end up getting the "ProTech" one without the resistor. Now I have to send this Amazon order back.
    :mad:
    douglasjre likes this.
  12. John321
    John321 Senior Member
    1,354
    1,346
    Kentucky
  13. ChapmanF
    17,196
    Have you bought one of those lately and received a resistored version?
    SupplyHouse also still has the SP11526C listed as R-Tech, though I had a string of emails with them this week where they eventually had someone at their fulfillment warehouse take a photo of the item, which showed it to be non-resistored. Presumably they'll get around to correcting the product listing. At least they were helpful in getting a photo of the item so I wouldn't have to order one and send it back. My local Ferguson's checked it at the warehouse too.
  14. hill
    8,624
    Corrosion. Not a fan of gravel Road salts that make most pickups around here look thusly;
    We pay a monthly fee for a conveyor type car wash that gets that kind of slop (most importantly from underneath) off the vehicles - as well as the upsell of protective ingredients in the hot high pressure auto sprayers.
    Poorer folk can't necessarily afford that luxury in an area that's too cold to hose stuff off, as outside hose bibs are invariably winterized anyway. To add insult to injury, you can't use your fancy schmancy car wash all month long necessarily, once the temperatures dip Maybe 10°, 20° below freezing - as the attendants would be freezing after an hour or so
    #2474 hill, Jan 30, 2025
  15. Mendel Leisk
    40,492
    If it's just a matter of expense, maybe it's time to weight the financial impact of road salt on cars, versus the increased expense of less corrosive alternatives, plus their efficacy. I'd suspect it's not been explored sufficiently, and salt is the quick-and-dirty, that's worked for us up to now.
    There's also the environmental impact of salt, on plants, animals, waterways, and so on.
    hill likes this.
  16. ETC(SS)
    6,920
    They put SALT on ROADS???
    Why???
    PS.
    Do not feel bad.
    You have 4 seasons.
    In the deep South?
    We only have 2.
    Too or Too cold.
    A few rusted fenders is a small price to pay!
  17. hill
    8,624
    Observing my grandkids, there seems to be a hay fever season also (smirk). High School history class seems to come to mind when some soldiers froze to death. Single digit (°f) isn't necessarily just a Northern thing alone. Our Nashville area community (built 2010-2013} had nearly ⅕ of the auto fire sprinkler plumbing systems burst - resulting in attic insulation wiped out, ceiling drywall &/or walls wiped out, floods/ especially for poor slobs not home. Way too easy for fly-by-night contractors to fold up shop & go destroy (people's homes / Possessions) lives.
    #2477 hill, Jan 31, 2025
  18. ETC(SS)
    6,920
    :cautious:
    I remember Chinese drywall in the SE.
    Not 'winter' caused but the autumnal storms in the SE were a contributer.
    I remember wondering HOW the bleep the ChiCOMMS can send drywall from there to here more profitably than we can make it and sell it here.
  19. ChapmanF
    17,196
    My house was built in 1929, using plaster.
    I suppose all the hurricane and fire reconstruction demanding gypsum for drywall must be part of why it's become so BLEEPing hard to find plaster to buy.
  20. tochatihu
    9,513
    3,672
    2001 Prius
    Lath, plaster and horsehair. By product of a transportation age mostly gone by. 1950 ish, fewer horses led to use of asbestos fibers instead. Unclear how widespread that was, but fibers of one type or another oppose shrinking in drying plaster.
    Moderns use acrylics instead to 'glue' the plasterettes in place. Avoiding shrinkage a different way.
