Rough startup when cold, P0300-P0303 codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LazuliNyx, Jan 18, 2025.
  1. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    Nice photos!
    Is there a photo of the intake manifold and EGR pipe?
    Are they clean or do they have traces of carbon soot on them?
  2. Mendel Leisk
    40,492
    Compare the turning of both old and new water pump? I think that’s the go-to check.
    regarding form-in-place gasket choices, I should note: I’ve NEVER done anything remotely close to a head gasket replacement. Or even timing chain cover reseal. I’ve cleaned the full EGR system a couple of times now, and fervently pray that’ll let me whistle past the head gasket graveyard. (with the odo on our 2010 at 103k kms, adding 3k yearly, I think we’re ok…)
    That said, Gasket Master’s form-in-place gasket pick seems sensible for DIY. Toyota spec’d FIP gasket comes with instruction to apply and install the cover within 3 minutes, and have all the bolts installed and torqued by the 15 minute mark. All 20 plus of them, varying bolt sizes and torque values.
    #22 Mendel Leisk, Jan 23, 2025
  3. Mendel Leisk
    40,492
    Had a question about which face of gasket was shown, figured it out (it’s the face against the head).
    #23 Mendel Leisk, Jan 23, 2025
    LazuliNyx likes this.
  4. LazuliNyx
    LazuliNyx Junior Member
    39
    28
    Georgia, USA
    175K. City. I got it around 120K and took care of it, but didn't know about the EGR flaws in this car.
  5. LazuliNyx
    39
    28
    Georgia, USA
    Yup. It's amazing how a simple black coating failing can destroy a whole engine.
  6. LazuliNyx
    39
    28
    Georgia, USA
    Good luck with your 3rd gen's head gasket. That's definitely a low mileage car. Makes sense about toyota's pick, they want something fast for when the engines are being assembled in the factory rather than when a mechanic or home mechanic is turning with a wrench by hand.
  7. LazuliNyx
    39
    28
    Georgia, USA
    I haven't taken pictures, but I cleaned them and replaced the EGR valve 2 months ago. There was some additional soot building since them, so I cleaned it out. It's a dirty as **** EGR system in that car. Also, if you look at the intake passages on the head, you can see there's carbon and oil buildup there.
  8. Mendel Leisk
    40,492
    Clogged EGR likely the ultimate culprit.
  9. Mendel Leisk
    40,492
    That was the car’s first EGR cleaning presumably?
  10. LazuliNyx
    39
    28
    Georgia, USA
    The first since I learned about it, I’ve had it since 120k miles. I don’t know if the previous owner cleaned it. When I did it, it wasn’t too obstructed but I don’t know how much carbon it takes to fowl things up. The biggest problem I had was the old EGR valve had the groove cut into it leading to a check engine light. Hence why I replaced it.
  11. Mendel Leisk
    40,492
    Frustrating, the plastic built into crucial components. Also there the water pump impeller, oil filter housing, also problematic.
  12. LazuliNyx
    39
    28
    Georgia, USA
    Yeah. The first time I did my oil (lived at an apartment for 5 years so I took it to a shop) I bought a replacement oil filter housing just in case.
  13. Mendel Leisk
    40,492
    I did the conversion to spin-on. Appreciate the stock system is ecologically superior, but it’s problematic.
  14. rjparker
    9,518
    5,825
    Original oil filter housing after more than 60 oil changes; same with water pumps. Use right tool and change coolants. Not Toyota's fault in this case.
    If we need to complain think about the brake booster, inverter and rings. But Toyota extended their warranty on each, just not forever.
    When I started buying cars we were happy to get 50,000 miles on an engine, routinely changed master cylinders and never heard the term inverter until college and power electronics 301.
  15. LazuliNyx
    39
    28
    Georgia, USA
    Oh, got a link for that?
  16. LazuliNyx
    39
    28
    Georgia, USA
    I forget, what's the recommended mileage interval for the EGR cleaning?
  17. rjparker
    9,518
    5,825
    Prius Gen3 Oil Filter Conversion
    • Oil Filter Bracket (15609-37060) (15609-0T060) old
    • Union (90904-04006)
    • O-Ring x2 (96723-24020)
    • Flange Bolt x4 ( )
    • Oil Filter (90915-YZZN1) (90915-YZZF2) old
    Instructions
    Tech: Lexus CT200h Spin-On Oil Filter Conversion – Ptetra Automotive
    Video
    A key point to buying Toyota parts is to use their online Toyota dealers. Most dealers have one, prices vary so you shop but 25% off and free shipping is the bar. Sometimes a local dealer has an online shop and you may have an option for local pickup (ship to store).
    I have had some luck just asking for a discount at the parts window. Discount to repair shops can be 50%- dealer cost is less than that. Dealers are independently owned by billionaires so your guy may or may not participate.
    There are annual nationwide sales as well usually around holidays.
    These are two I use most often.
    McGeorge/Ourisman
    Genuine Toyota Online Parts| OEM Toyota Parts| Toyota Parts Store | Toyota Parts|Toyota Online Parts| Toyota Parts Online
    Hoover Toyota (sometimes sells on ebay as well)
    Genuine Toyota Parts and Accessories: Official Online Store Hoover Toyota
    Finally Hybridpit sells these as a package minus the bolts for $205 shipped. You can do better if you shop.
    #37 rjparker, Jan 24, 2025
  18. Mendel Leisk
    40,492
    Yes, Spin-On Oil Filter link in my signature (on a phone, turn it landscape to see signatures).
    Definitely, approx. $70 USD was my all-in, shipped cost. See attached Amayama receipt:
    #38 Mendel Leisk, Jan 24, 2025
  19. Tideland Prius
    16,433
    *Threads merged*
    Brian1954 likes this.
  20. LazuliNyx
    39
    28
    Georgia, USA
    Current status: Head is back on the car. I got it back from the machine shop Friday, lapped the valves and replaced the valve stem seals Sunday. The machinist could tell the head gasket had blown due to overheating, so I'm guessing the blocked EGR valve causes localized overheating the gasket. He was impressed I had done my research and knew my shit on this particular car (Thanks everyone who's posted on these forums). I'm a disabled person so I am having to pace myself. Hoping to get the camshaft carrier on the car today, and maybe the timing chain and cover, so that I can put oil in tomorrow evening after the RTV cures. I decided to go for broke and also order a replacement oil pan gasket, I'm sure that's gonna fail in the next few thousand miles. In for a penny, in for a pound. I hope this car can take me to at least 250k miles (Mid 170s now), maybe even 300k, with regular maintenance of the EGR valve.
    In these forums, I've seen discussion of the AISIN WPT-190 water pump being the same thing as the OEM since AISIN makes it for Toyota. The original and new pumps are exactly identical except the Toyota name is etched off the AISIN part. Both have AISIN's name on the housing. So if you're looking to replace the pump, get the AISIN part if it's cheaper, it's the same thing. The old pump has an intact impeller, and spins fairly, so I'm keeping it as a spare that I'll throw on should the new one fail while waiting for a replacement from Amayama or Rock Auto so that I can keep running, but I am not trusting it for the life of the car. IMG_2386.jpeg
