first oil change: report
Discussion in 'Gen 5 Prius Technical Discussion' started by peternumber2, Jan 10, 2025.
  1. peternumber2
    peternumber2 Member
    120
    27
    Rome
    2023 Prius Prime
    yes, shame on me. I'll have a look at it.
  2. Trollbait
    12,319
    My 1996 Taurus was the first car with one.
    They aren't HEPA filters.
    Judging by what I find on them, I think they are more for keeping the air box and vents from clogging with leaves and maple seeds.
  3. Prodigyplace
    12,396
    11,676
    Central Virginia
    My 2000 Tundra does not have one but the 2008 Corolla i owned had one.My engine air filter especially gets clogged with basic road dust.I realize they are not HEPA filters but restricting air flow to the engine is not optimal.
  4. Mendel Leisk
    40,490
    Well it's your money. If you rely on the dealership to tell you what needs doing, that's pretty much the same as having the proverbial fox guarding the hen house. ;)
    Prodigyplace likes this.
  5. Trollbait
    12,319
    I was talking about cabin air filters. I find leaf chunks on mine.
    Road dust will eventually clog the engine air filter, but the restriction most see before changing only has an impact at wide open throttle. Going back to the cities. It is a low speed environment; less road dust kicked up. Then diesels are cleaner, and the particulates coming out of a gas tail pipe are too small for the filters.
  6. peternumber2
    peternumber2 Member
    120
    27
    Rome
    2023 Prius Prime
    Here I am, digged into the glove box and found the maintanance book: it states that 15k km or 1 year service must include:
    1) oil and oil filter replacement
    2) air filter (ICE) inspection
    3) HVAC filter replacement
    4) top up (??) fuel additives.
    5) brake discs and pads inspection
    6) tires, lights, whipers and liquid inspection
    7) floor mat inspection
    based on the above, I filed a complaint through the "satifaction survey", stating that:
    a) the oil level was too high and the oil used, though compatible, was not the recommended grade.
    b) the tires were overinflated to 2.7 bar, while the user manual recommends either 2.6-2.2 or 2.4-2.3 bar.
    c) HVAC disinfection was proposed without mentioning it was not necessary according to official maintanace schedule.
    d) delay in the return time (more than half an hour)
    as soon as I submitted the complaint, I got a call from the dealer, asking me to bring the car in again, with no need to set an appointment.
    I'll keep you updated.
    PS why do they use "top up" (rabbocco in Italian) when they refer to additives? there is no additives tank, as far as I know....another very bad translation from Japanese (as innumerable others scattered through the manual)?
  7. Prodigyplace
    12,396
    11,676
    Central Virginia
    Great that they actually looked at the satisfaction survey. Dealers here in the US usually ignore that but if you call and complain to Toyota US, the dealer service manager sometimes responds.
    I had a question on a recall that did not involve any problem with the dealer. Basically, right after I had the recall performed, Toyota extended it to another area of the car. Right after talking to Toyota, the dealer service manager called me. I ended up bringing the vehicle back in to them to get the issue corrected to my satisfaction even though they could not bill Toyota gagin for their work..
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    739
    Monument, Colorado USA
    Engine air filters' lives can vary greatly so best just to check them every 6-months when you do an oil change. Mine normally are ready for changing every-other oil change, or once a year.
    Cabin filters are the same and, in some of our cars, they are dirty after just 6-months but, generally, they last a year or more. I buy after-market carbon-activated ones MUCH cheaper than the Toyota brand so, as a minimum, they are changed yearly. (The charcoal activation only lasts that long once you open the plastic container.)
  9. priusdriver223
    82
    31
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I would stick with 0W-16 for your viscosity as modern cars have very tight tolerances on gaps and such, if the manufacturer tells you to use 0w-16, you should stick with 0w-16. Then again, some people believe that thicker oil will prolong the oil but my take is that, if you stick with the manufacturer oil and you change it every 3-5k miles, you will last alot longer than those who change every 10k. As for your oil level, they did add a little too much, will it be detrimental to your engine? No, but just keep in mind, next time please do check your level AFTER the engine is warm and if it’s not in the middle or within max line, tell the dealer to redo it. Fuel additives are perfectly fine, it works the best when your tank is almost empty since it will be mixed properly once you fill up, I add it once 2-3 months into my car, does it actually clean out your injectors? Not sure since it’s such a controversial topic, but I believe in it and extra 10 dollars for a peace of mind isn’t so bad. And for your filters, both engine and cabin, I replace mine every 10k miles or year, and for the battery filter, I replace it every 20k miles. Cabin and engine filter won’t cost you over 30 dollars, replacing the engine filter frequently has more benefits than you think, the debris that goes into your engine is one of the main factors that will damage your engine in a long run so I wouldn’t skip on the engine filter myself. Take all my words as a grain of salt but it’s my take. Cheers!
  10. Prodigyplace
    12,396
    11,676
    Central Virginia
    My 2025 Camry Hybrid has the same engine as the 2024 Camry Hybrid but they changed the oil recommendation from 0w-16 to 0w-8, Many people think the lower viscosity is just for slightly greater fuel efficiency while shortening the engine's useful life. YMMV.
    xliderider and Mendel Leisk like this.
  11. priusdriver223
    82
    31
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, yea I believe that, that is a pretty big jump for your engine, but as for the Prius engine, the viscosity between 16 and 20 is so minimal, i’ll trust toyota engineers. But i know plenty of people that will choose 20 everytime which I’m not against, very interesting though. I do think the EU regulations are also contributing to the oil viscosity they’re using, I believe they mandate manufacturers to thin the oil every so often to comply with their environmental bs. Cheers!
    Mendel Leisk and Prodigyplace like this.
  12. Trollbait
    12,319
    Same engine doesn't mean Toyota stuck with all the same parts.
    The 8 is also pretty close to the 16 and 20. Japan started with these viscosities to conserve the use of resources(fuel).
    priusdriver223 likes this.
  13. Gokhan
    Gokhan Senior Member
    5,647
    2,226
    Paramount CA
    The statement that SAE 0W-8, SAE 0W-16, and SAE 0W-20 are very close is absolutely false.
    SAE 0W-20 is very close to SAE 5W-30, yes, but ILSAC has separated the viscosity classes in GF-6 as GF-6A (all except SAE 0W-16) and GF-6B (SAE 0W-16) so that people would not accidentally put SAE 0W-16 in cars requiring SAE 0W-20 or thicker.
    SAE 0W-8 and SAE 0W-12 are not even in ILSAC yet. They are only part of JASO GLV-1. It looks like even the upcoming ILSAC GF-7 does not have them.
    Regarding differences in viscosity, even a small difference in HTHS viscosity could make a huge difference by lowering the minimum oil-film thickness (MOFT) to the point that you get metal–metal contact in the bearings or cylinders, causing exponentially increasing wear.
  14. priusdriver223
    82
    31
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, yea you probably know alot more on this topic than me for sure, i personally don’t think 20 and 16 are big enough difference that your car will break down significantly faster if using 20, real world performance probably won’t get affected by much, that’s my personal opinion but I do believe in what you say. Cheers!
  15. Gokhan
    5,647
    2,226
    Paramount CA
    If the manufacturer OK’s it, it’s fine, but otherwise, it may not be worth taking the risk. The oil in hybrids do not get very hot (therefore, very thin) when they are driven gently, as the engine would be off half the time; so, it’s less of a concern in that case.
  16. purplePriii
    purplePriii Active Member
    275
    119
    I changed mine after about a year and 20-25k miles when the AC unit started smelling. Filter was pretty dirty with bugs and stuff. I was surprised it happened so quickly. Engine one looked fine though.
  17. Mendel Leisk
    40,490
    The smell can be mold growing on the AC radiator (aka evaporator) fins. Comes from water condensing on the fins, repeatedly sitting there after the cars shut down. It can be avoided by using AC sparingly, and shutting it off a mile or more before destination, while continuing to run fan. Which is a hassle, I appreciate.
  18. purplePriii
    275
    119
    Yeah, I was still learning how to use the AC. I disabled the auto a/c mode and used the a/c cleaner cartridges from Toyota to clean it out. We'll see how long it takes for it to happen again now that I'm in control!
  19. peternumber2
    peternumber2 Member
    120
    27
    Rome
    2023 Prius Prime
    I think that running only the fan before turning off the system may make things worse: forcing hot (thus humid) air into the system will promote condensation over the cold walls of the conduits. Unless you wait long enough for the system to warm up uniformly, but that would spoil any comfort.
  20. Mendel Leisk
    40,490
    It takes a mile or two, running the system with fan somewhat accelerated and AC off, to clear the condensation that’s accumulated on the evaporator fins. You can tell you’re getting somewhere when the muggy/steamy abates. And yeah you need to crack windows, endure ambient air temp. First world problems.
    if the system would somehow “shed” that condensation when just shut down, or was able to quickly and thoroughly evaporate it off, mould would be that common. But it doesn’t so here we are.
