Light-bar upgrade for LE and SE
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Sep 24, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,191
    2,449
    Paramount CA
    I drove behind a gray Gen 5 LE for a long time last night.
    Conclusion: It looks like the tailight bulb burned out. It is an awful, awful design by Toyota. Why would you put a taillight lens without a bulb inside? It has no reflectors; so, it makes no sense whatsoever.
    Eventually, I passed it, and the headlight design is equally awful. There are no yellow marker lights or accent lights visible from the front and the headlights look tiny, barely visible to other drivers. In contrast, the quad LED headlamps on my 2021 Prius Prime Limited are simply beautiful, and I have yellow marker lights visible from the front, accent LED lights, as well as driving/fog lamps. I have so many lights that when I am behind someone, it scares them, which should be the way it is for best visibility.
    Why spend so much effort in designing an elegant shell but completely ruin the taillight and headlight design?
    soft_r likes this.
  2. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    To try and get us to buy upper trims for another 5-6k ;D
    FWIW at least while driving the headlamps feel plenty bright and the turn signals are very visible. But yeah upper trims do have prettier versions.
    Maybe far into the future if/when the lamps get gross and burn out they get swapped XD
    Lantaral and Gokhan like this.
  3. swisshurb
    swisshurb Junior Member
    CA
    2023 Prius Prime
    SE
    anybody has any progress around here ? :D
  4. Gokhan
    6,191
    2,449
    Paramount CA
  5. EnriqueDFA
    EnriqueDFA Junior Member
    Mexico
    2023 Prius
    Will probably try next year. It is quite expensive, specially the harness to the rear door, I'll probably use connection to the side tail lights like the Japanese blog post lol
  6. Avade
    Avade New Member
    california
    2024 Prius
    LE AWD-e
    hello!...it's been a year.... anybody tried them yet? a youtube tutorial will be a banger
  7. EnriqueDFA
    Mexico
    2023 Prius
    Not yet, I barely got the car 3 months ago lol I've decided to pay out the car first before modding it, so it'll take more time. So far the japanese blog post has been the best guide i've found.
    Avade likes this.
  8. Gokhan
    6,191
    2,449
    Paramount CA
    Actually, having seen a lot more Gen 5s on the road, I think the LE/SE taillights are not that bad. Light bars have become too common, and they are starting to appear nauseating. So, I think the LE/SE taillights look good—albeit perhaps with the caveat of being a little too small for the safety aspect.
    Avade and Alessandro_Ibi like this.
  9. Gokhan
    6,191
    2,449
    Paramount CA
    I also still get highly impressed when I see Gen 4 Prius Prime taillights on the road at night. They are one of the best taillights ever when viewed at night with the way they light and the way the center high-mount stop light lights (like a quasi light bar).
  10. scotched
    scotched Member
    65
    86
    Encino, CA
    2023 Prius
    At night, I don't like the design of the uni-tail light on the Gen 5 for two reasons.
    1. It isn't straight. It has the shape of a bow-tie rather than a line. Instead of minimal is looks "busy".
    2. It isn't WIDE. The rear lights do not span the width of the car due to the way the rear fenders bulge. It make it look like there is less car on the road.
  11. EnriqueDFA
    Mexico
    2023 Prius
    Well, after a long time of planning, I might do this, I have most of the parts identified but I'm missing one, and it's the harness that goes from the fuse box (I think) to this one 81935-47090 (the one that powers up the middle brake light and the two lights for the bar) since the one on my prius doesn't have constant power for the two lightbulbs on the bar. Any one has a clue on the part number for that?
  12. Perfectpacman
    Perfectpacman Junior Member
    84
    22
    United Kingdom
    2024 Prius
    ----UK----
    Absolutely. Of course they're visible, but by far my most annoying thing about the car. Completely ridiculous decision by Toyota.
    Gokhan likes this.
