Ohmmu LFP battery in a Gen 5 Prius ?
Discussion in 'Gen 5 Prius Technical Discussion' started by RandyPete, Nov 10, 2024.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,264
    1,115
    Update with the LiTime battery:
    We hit some serious cold here, down to the negative thirties for a couple weeks straight. What I learned is if I shut off the car for about 8 hours, running it just before getting into bed and then just as I got out (and yes, running out there at -35 °F in my pajamas) and turned on the car, the battery would hold enough heat to not shut down completely even at those very cold temps.
    At around -10 °F to -15 °F it seems kind of hard to get it down cold enough to get it to shut off with driving the car home at around 4 or 5pm the previous day and getting in and starting up at around 6 to 9am the next. Only if you leave it off all day and all night does it become a problem at those temps.
    If it's just going to dip down to -4 °F or -5 °F or so in the morning, it's seemingly impossible for the battery itself to get that cold and shut off.
    • So all in all, if it's getting down to -10 °F to -20 °F, then I make sure I'm driving the car at some point the afternoon before.
    • If it gets down from -20 °F to -35 °F, then it's important to do something like run the car before bed and after getting up, because when you don't then you're going to have to jump start the car with another battery, which also seems to work too, it just resets all your car's computer stuff.
  2. vvillovv
    vvillovv Senior Member
    4,318
    1,498
    NY
    Have you tried a trickle charger to see if that will kick on the batteries heater while the Avalon is sleeping?
    Do the specs say what kinda charge the heater needs before it switches on?
    It's a balmy 17 F today and I keep the Prime plugged in a LOT to keep those traction heaters on alert.
  3. RandyPete
    RandyPete Active Member
    379
    156
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Car parked outside or in garage ?
  4. Gokhan
    Gokhan Senior Member
    5,618
    2,214
    Paramount CA
    So, an LFP 12-V battery doesn’t really work in cold? Great.
  5. Isaac Zachary
    2,264
    1,115
    Outside.
    If you live where it gets down to negative 20 °F and below, you park outside all night and you're not willing to do something about it, no.
    Gokhan likes this.
  6. RandyPete
    379
    156
    2024 Prius Prime
    XSE
    ?? Don't understand your reply.
  7. Isaac Zachary
    2,264
    1,115
    You asked if I park outside. I don't have a garage, so yes, I park outside, all night long. So yes, I was able to get the car through the night outside with it as cold as -35 °F and the car still started the next morning. All I needed to do was run the car half an hour before bedtime and then go out and start the car early. An appropriate battery charger would also keep this self-heating battery warm all night.
    @Gokhan indicated that LFP batteries won't work in the cold. But as I've demonstrated, they work just fine down to around -15 °F. So if you don't get down past that, you'll probably never have any problems.
    RandyPete likes this.
  8. RandyPete
    379
    156
    2024 Prius Prime
    XSE
    Ask a simple question, got a thorough in depth answer. Thank You !
    vvillovv and Isaac Zachary like this.
  9. RandyPete
    379
    156
    2024 Prius Prime
    XSE
  10. Isaac Zachary
    2,264
    1,115
    This one: LiTime 12V 100Ah Self Heating LiFePO4 Lithium Battery – LiTime-US, but no, it does not fit in the stock battery holder. Mine is wired to be in the trunk. I'm not sure of the dimentions of the stock battery, but LiTime does have a newer self-heated battery that is smaller, group 24 sized battery that might fit, although I have my doubts.
    vvillovv likes this.
  11. RandyPete
    379
    156
    2024 Prius Prime
    XSE
    Yea, that's the battery I linked above.
    LiTime
    Group 24 size
    Self heating
    Blue tooth
    100 AH
    And if I remember correctly, your vehicle is not a gen5 Prius but an Avalon.
    #51 RandyPete, Feb 1, 2025
    Isaac Zachary likes this.
  12. Trollbait
    12,310
    The real risk to most Li-ion batteries in the cold is with charging. Do so when the battery is below freezing, and damaging it is possible.
  13. Isaac Zachary
    2,264
    1,115
    This is quite true, and why I got a self-heating battery that shuts off charging when it's below some 40 °F but still discharges through a diode unless the battery itself gets down to -4 °F, at which point it shuts off completely.
    So usually it starts the car fine, then the charging current of the car just warms the battery warmers until it gets warm enough to start accepting the charge for the battery itself.
  14. Bill Norton
    Bill Norton Senior Member
    2,126
    725
    MONW, Ks.
    These cars are at most 2 years old. Why would you be spending $$ to replace a fine battery? Is your stock battery dying frequently?
    An expensive LFP is not going to fix that.
    I swear, sometimes it's like young boys gluing on chromium geegaas from another model just because they like to modify/personalize their toys.
  15. Isaac Zachary
    2,264
    1,115
    If it isn't broke don't fix it.
    In my case I use mine for amateur radio and having about 4 times or more the battery capacity comes in handy for me.
    Bill Norton likes this.
  16. RandyPete
    379
    156
    2024 Prius Prime
    XSE
    Here's an OHMU battery install in a Prius Prime pic.
  17. Gokhan
    5,618
    2,214
    Paramount CA
    Have you been monitoring its voltage with a BM2? An LFP battery might be running at a very low SOC because I doubt the car’s BMS/DC–DC converter is compatible with it.
    Ohmmu LFP battery in a Gen 5 Prius ? | PriusChat
  18. Isaac Zachary
    2,264
    1,115
    Your chart seems about right for modest charging but maybe a bit off for resting voltages. I get 13.1V resting voltage at 100% charge.
    Then again, it's pretty cold here, so the voltage may be lower than normal. It's snowing again as I type this.
    #58 Isaac Zachary, Apr 4, 2025
