Best way to hide TPMS warning light?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Sep 12, 2019.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,119
    626
    Southern California
    What's the best way to cover up the TPMS warning light on the dash? A bit of electrical tape would work but it seems likely to gunk up the surface. As I understand it there is no way to permanently disable the circuit with TechStream.
    That light is now lit because apparently one of the sensor batteries died. It is a 2007, and if all the sensors are original they were living on borrowed time. The dealer wanted my left nut just for a diagnostic, and the tire shop we usually use asks $123 to fix one and $87 more for any others. The thing is, I have this magic tool called a "pressure gauge" which is employed periodically, and I also am in the habit of walking around the cars to check the tires by eye, so I'm not at all worried about a slow leak. I suppose the TPMS might provide a few extra seconds warning if we ran over a nail on the highway, but other than that, it doesn't have much value. Certainly not the ~$400 it would cost to change the sensors on all 4 tires, because if I just do the one, another may very well go next month.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    1. Those prices are way high. You can buy aftermarket TPMS sensors for a lot less than that shop quoted you for a repair, so a bit of shopping around may be helpful if you do want to service or replace the TPMS.
    2. If you do decide to abandon the TPMS, then just electrical tape over the light. You won't be removing the tape, so gunking the surface shouldn't be a problem.
    3. Ignore the light. After a while, a constantly lighted warning light is soon ignored. We run snows on a car in winter with no TPMS and we pretty much ignore the light.
  3. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Don't suppose you have a Sam's Club membership? Much cheaper...
    moto g(7) power ?
  4. frodoz737
    frodoz737 Top Wrench
    4,464
    2,412
    33
    Best way? Fix it.
    Skibob and John321 like this.
  5. Skibob
    Skibob Senior Member
    2,912
    1,501
    Northern California
    Do you have a copy of techstream? Can your copy access the TPMS feature? New Denso sensors are 32.79 each on Rock Auto and there has to be an independent tire shop near you that could do the swap. Then you just input the new code yourself.
    Aegean and John321 like this.
  6. pasadena_commut
    2,119
    626
    Southern California
    Yeah, I saw those on RockAuto. I don't know yet if any of the software I have can talk to the TPMS. In the meantime I called a couple of other shops and they were all very close to $120 to replace one sensor (they supply the sensor and program.) Kind of ridiculous that this sensor costs roughly as much to replace as a tire. One might have thought they could design a sensor that screws onto a shorter stem, with the weight landing on the rim. Basically just an electronic pressure gauge that can stay on the car. Then changing it would be roughly as difficult as changing the cap.
    Duh, of course they have:
  7. pasadena_commut
    2,119
    626
    Southern California
    The cap ones are interesting but I do wonder about the forces. The sensors can't weigh much, but once the tire is rotating at 700 RPM (about right for highway speed) that will apply some force to the valve stem and the tire as a whole. Perhaps the latter isn't enough to unbalance the tire significantly, but I suspect that stems in general, and those on the internal TPMS systems in particular, are not designed for any type of load at all (caps weigh nothing.) Also, if one uses the little lock nuts that come with these then adjusting tire pressure becomes a minor PITA. At least it is trivial and cheap to change the batteries on them, as they use CR1632 batteries and the two halves unscrew. Also the displays on these cheap units show much more information than do any of the car TPMS systems I have seen.
    Wouldn't it be wonderful if the little cap units were compatible with the Prius's system?
    It seems wildly unlikely though.
  8. pasadena_commut
    2,119
    626
    Southern California
  9. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    I bought a used ‘14 Scion iQ back in 2017. I think three times now I’ve seen the TPMS warning light on, only to resolve itself later. The first time it happened I went to get out the tire goo service kit that came with the car, only to find out that the goo had been dispensed. Replacement Toyota tire goo is very expensive, more than Porsche tire goo ironically. (Cheapest tire goo I’ve seen so far is Tesla). I suspect it has something to do with that....
  10. ChapmanF
    16,963
    If the light was on because of stuff left unplugged behind the dash, imagine the frustration of paying some tire shop for new sensors and not solving the problem.
    I imagine that reading the trouble codes from the TPMS computer (or discovering that the codes couldn't be read from it) would have helped distinguish between wheel sensor batteries and some other problem. Was that ever done?
  11. pasadena_commut
    2,119
    626
    Southern California
    Sounds like a new and creative way to throw money down the drain.
    Not by me. I was never motivated to fix this problem because for all practical purposes nothing was broken - the tire pressure is checked periodically in any case, TPMS or no TPMS. It would have been nice if the Prius's MFD was able to display the tire pressures, eliminating the (oh so slight) burden of having to carry a tire pressure gauge. I would have missed that convenience and might have spent some time trying to figure out the issue.
  12. Mendel Leisk
    40,244
    I'm thinking the same.
  13. ChapmanF
    16,963
    They can be read over the diagnostic port. ScanGauges with a later firmware rev than mine, I'm told, can show them.
  14. pasadena_commut
    2,119
    626
    Southern California
    Had a little time on my hands today and decided to see what Techstream actually showed for the TPMS system. The one I use runs in VirtualBox and I have not figured out yet how to get a screenshot out of that. This Techstream worked correctly with my mother's Gen 3, showing that one tire was low, and the various data fields were all filled in. Anyway, on our 2007 Techstream clearly talks to the TPMS computer since it sees the ID values, but it doesn't look like the TPMS computer is talking to any of the sensors. Either that or all of them now have dead batteries. The data list said:
    Mode start: Normal
    Main Tire: 4
    2nd Tire: 4
    Select Switch: Main
    Vehicle Speed: 0 MPH
    Registered ID1: A7CF1D2
    Registered ID2: A6F91D2
    Registered ID3: 3CAF1D5
    Registered ID4: 3C081D5
    Registered ID5: 000000
    ID transmission Status: Finish
    Initialization Switch: OFF
    ID1 Tire inflation Pressure: N/A (ditto ID2-ID5)
    ID1 Temperature in Tire: -40F (ditto ID2-ID5)
    ID1 Battery Voltage: Over (ditto ID2-ID5)
    Select SW Info: without
    Initialization SW info: with
    Threshold Low: 26.5
    ID1 Initial Threshold of Low Pressure: N/A (ditto ID2-ID5)
    Number of DTC: 5
    Additionally asking for trouble codes or utility->signal check -> one signal check
    both gave error 0x91020324.
    Since we can talk to the TPMS computer, and the TPMS computer cannot talk to the sensors, maybe the antenna is not plugged in (or completely missing)? Where is that connection?
    Edit: forgot to mention, scanned the whole car for DTCs and it only gave the spurious light sensor in the dash one. So I don't know what the "Number of DTC" line is about.
    #14 pasadena_commut, Feb 1, 2025
  15. rjparker
    9,303
    5,669
    In this case ID2 was out
    #15 rjparker, Feb 1, 2025
  16. pasadena_commut
    2,119
    626
    Southern California
    Is there a way to distinguish with Techstream "all 4 TPMS sensors are dead" from "cable to receiver is not plugged in" or "receiver has failed"?
    The screen shot doesn't show the DTC field. Mine said "5" and according to the TW part of the manual that is the count of stored DTCs. But the ECU didn't report any failures to Techstream. If all 4 were dead, shouldn't there have been C2111 through C2114? Did the car for the screen shot show a C2112 code?
    Apparently the receiver signal is on the one cable going into the ECU, so it isn't possible to leave that unplugged at the ECU without taking the whole thing off line.
  17. rjparker
    9,303
    5,669
    No code. Here is another screenshot that includes the dtc field. It's possible the horz scrollbar on the first pic needed to be moved.
  18. mr_guy_mann
    mr_guy_mann Senior Member
    3,922
    1,888
    NJ-USA
    Faults with the TPMS system on the car / ecu end of things is extremely rare. Failure of TPMS sensors is extremely common. Typical battery life is around 10 years.
    If you want to be sure, drive the car above 20 mph for 30 seconds then recheck data. The sensors go to "sleep" after sitting still for a few minutes. They have an accelerometer to wake them up once moving.
  19. pasadena_commut
    2,119
    626
    Southern California
    So how do tire shops set these sensors up if they go to sleep on cars which aren't moving? Do they perhaps respond to a "wake up" signal from the programming devices, or the car itself? There is something similar to that in network computing, where "Wake on Lan" packets cause computers to come out of a low power state and boot.
    When I read the TPMS values on my mother's 3rd generation it had not been driven in quite a while. Probably it was showing the last valid readings it had received.
  20. rjparker
    9,303
    5,669
    Yes. Autel sells specific tpms tools that directly talk to the sensors both as an initial diagnostic and as a sensor wake up mechanism.
    Other shops will simply install new sensors, write the new ids to the tpms ecu via obd2 and drive around the block to test.
    Newer cars including Toyota can recognize the same sensors automatically or through a mfd setting.
    #20 rjparker, Feb 2, 2025
