Thing that sticks out from the drivers/passenger's lower door
Discussion in 'Gen 5 Prius Main Forum' started by Argyros, Oct 9, 2023.
  1. Argyros
    Argyros Active Member
    274
    141
    2023 Prius
    There is a metal protrusion that sticks out from the driver's and passenger's door; does anyone know what this is for? Never saw anything like this before on any car.
    otatrant likes this.
  2. aforkosh
    aforkosh Active Member
    412
    272
    Oakland, CA
    2023 Prius
    It's to keep the door aligned in a crash so that it can still operate.
  3. Argyros
    274
    141
    2023 Prius
    That is so interesting! Once we see the crash tests from IIHS, I'll be interested to see if the door kept it's shape in order for it to open.
  4. KMO
    KMO Senior Member
    1,910
    654
    Finland
    2023 Prius Prime
    That thing isn't there in European versions. There's a plug on the door, and no hole punched in the body. Targetting something particular to US safety tests?
    Safety things is definitely one of the areas there's always minor variations in.Different airbag layouts in US/Europe/Japan too:
    Driver+passenger front+side airbags: All versions
    Curtain airbags: All versions
    Rear side airbags: America only
    Driver knee airbags: Japan + Europe
    Front centre airbag: Europe only
  5. blacknova
    blacknova New Member
    GA, USA
    2024 Prius Prime
    XSE Premium
    I don’t see how a small pin can withstand a collision that could involve several tons of force & keep the door “aligned”? Is this purely a mechanical solution, ie: just a tab? or does this make an electrical connection for a sensor?
    If this really is for the reason stated in the video, this is such a terrible implementation. I was searching for this as I kept gouging my foot ankle on that damn spike when entering/exiting the car- it’s dangerous!
    (If implementing something protruding, they should have maybe swapped the male/female connectors & made sure it is embedded in the hole to avoid injuries?)
  6. Tideland Prius
    16,534
    Likely the small offset crash test.
    Small overlap front
  7. bbkh
    bbkh Junior Member
    San Diego
    2024 Prius Prime
    SE
    Does anyone know why the US gen5 has one very bulky windshield wiper base, but both wipers on the Japanese/European ge5 are both slim and thin?
  8. KMO
    KMO Senior Member
    1,910
    654
    Finland
    2023 Prius Prime
    Fancy linkage on the passenger wiper to cover more area than a simple rotating arm. Was also the case in at least one previous generation.
    Maybe a US legal requirement?
    bbkh likes this.
  9. ChapmanF
    17,933
    As far as I know, gen 4 was the only generation that didn't have the double-jointed passenger wiper in the US. All prior generations had it, and it seems to be back again.
    bbkh likes this.
  10. Blackat
    Blackat Active Member
    445
    307
    Colorado
    2023 Prius
    Limited AWD-e
    How does this even happen? I've never even come close to hitting it
