09 buzzing drivers side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dahvid, Feb 12, 2025.
  1. Dahvid
    Dahvid Junior Member
    43
    Usa
    So I've just discovered a light buzzing sound that comes on for 2 seconds every 10 seconds
    I do not believe I've heard it before but it slight sounding so it's possible I am just not noticing but my ocd is strong so I feel like it just started
    From my searches it seems it's just normal inverter noise but others have said it could be the brake accumulator/ abs going out?
    The vids I found saying it was the brakes sounds very clacky and louder. I do not believe that is the sound I'm hearing.
    I also think it happens after I power down the car before I get out I still hear it for a few minutes.
    Could it be my inverter coolant is low? I checked but it doesn't look low but it's also freezing out so didn't check that well
    Please advise
    #1 Dahvid, Feb 12, 2025
  2. ChapmanF
    18,078
    Everybody on the internet seems to have some idea what "normal inverter noise" is, which is often something else entirely. The inverter is darned near silent when it isn't handling significant power accelerating or regen braking. One of people's favorite candidates for "normal inverter noise" is a whine you can hear pretty well with the hood up that is in fact made by the throttle body motor.
    But when you describe any sound that lasts around 2 seconds at a time and repeats at times, my first, second, and third guesses will all be the brake pressure pump. It doesn't have to sound clacky and loud. I sometimes describe it as a distant rattlesnake, or joy buzzer. There's a range of variation in the sound; some are pretty quiet.
    It's a pump that runs whenever needed to shove more brake fluid into the pressure accumulator so there's enough pressure there to work the brakes. Takes around 2 seconds to do that. Pretty certain to be what you are hearing.
  3. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    The sound when you turn off the car is most likely associated with the pumping of heated coolant into the thermos.
    Periodic creaking sounds can come from ABS pumps, inverter pumps, heater pumps.
  4. ChapmanF
    18,078
    The car will use a pump to store hot coolant in the thermos at shutdown; this can become a familiar, recognizable sound also. It runs for rather more than just 2 seconds to do this, and does not repeat.
    You may, when making the car READY a following morning, notice the same pumping sound for the same matter of seconds just before the engine starts, as the saved hot coolant is pumped back to the engine to pre-warm it.
    Once familiar with both sounds (this coolant pump, and the occasional 1 or 2 second rattlesnaky buzzes from the brake pump, neither sounds very much like the other.
  5. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    I agree that the sounds are different.
    In absolute silence, from the moment of switching on until the moment of starting the engine, there are sources of sounds - the thermos system, the inverter pump, the ABS brake system.
    If the climate control is on, then the sound of the air flaps is also possible. But it is unlikely to be repeated periodically.
    Pumping pressure into the brake system when it is worn out is the most likely event.
  6. Dahvid
    43
    Usa
    Thank you for all the replies
    I hear the inverter pump run when I turn off the car. That's more of a whirring sound
    This sound I'm trying to figure out is constant on and off even when I press the brake. I don't hear anything when I press it
    Could I be low on brake fluid?
    I'm trying to upload a audio / video file and video it says it's to large audio says m4a is not allowed. How can I upload something for you all to hear it ?
    I found this on another thread I think it sounds like this
    Buzzing noise from engine bay | PriusChat
    #6 Dahvid, Feb 13, 2025
  7. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    You can easily check the brake fluid level by opening the hood of the engine compartment.
    You can also check the level in the tanks for other process fluids.
  8. Hayslayer
    Hayslayer Active Member
    390
    219
    The noise you hear is your brake actuator. It's a very common problem on the Gen 2. I've had that cycling going on with my current car for over a year. It's normally due to an internal leak causing accumulator pressure to drift down and then the pump runs for a couple seconds to re-pressurize it. Eventually, (it may take months or years) the actuator/accumulator/pump assembly will not be able to keep up and the car will throw a code. I've replaced a few, but on my current car, I'm just going to see how long it can go as it is
    Toyota 44500-47141 Actuator Assembly, Brake .... if you need specific terminology.
  9. Hayslayer
    390
    219
    That noise is most likely the transfer pump moving hot coolant from the engine to the storage tank.
    The inverter cooling water pump runs when the car is ignition-on, or READY. Car off=inverter cooling water pump off.
  10. Dahvid
    43
    Usa
    It's right in the middle of the min max level. Color looks OK I guess
    I've heard of someone using a transfer pump to remove what's in the reservoirs and replace with new fluid. I might give that a shot?
    How much fluid does the brake system take? I know i probably won't remove that much in the reservoir but at least want an idea so I can be prepared
    I am hearing a click in the fuse box when the sound comes and go. Can I pull the fuse to see if it goes away so I can help pin point where the sound is coming?
  11. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    It is enough to remove the relay from the socket to stop the voltage supply to the system.
    This is usually done when eliminating leaks in the brake system or replacing parts.
  12. Dahvid
    43
    Usa
    Could you tell me which one it would be? Is there a diagram that would help.
    I don't have the owners manual to help with identifying which relay/ fuse to pull.
    Thank you.
    I don't think its the inverter pump as someone stated before. That sound i think sounds lower in the engine bay and isn't as buzzy as I'm hearing.
  13. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    The relays are labeled on the box cover.
    In the photo, there are two blue relays, next to green relays.
    Removing them from their sockets will not supply power to the ABS pumps.
  14. Dahvid
    43
    Usa
    Awesome this is very helpful thank you!
    Just for clarification, the brake accumulator (entire abs system) will not work after pulling those relays? I'm sure it will throw codes but i can just clear them?
    Also I wanted to ask if there's any other methods to diagnose the noise? I'm shopping for the part; any recommendations? Thinking of going used bc of cost but also don't want to have to do this again anytime soon.
    It's interesting. The last few days have been relatively mild and I have not heard the buzzing noise. It happens once in a while (kinda rarely) but almost gone completely. Thoughts?
    Thanks
