Gen2 Prius oil type: petroleum based, semi~synthetic, synthetic?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusrust, Feb 16, 2025.
  1. priusrust
    priusrust Member
    197
    70
    MA
    so many related posts thought I'd cut to the chase. I'm leaning semi`~synthetic for my gen2. This ok? thanks! And if so, assume perhaps 5k mile change interval? (vs 3k with petroleum based)
    51,838
    Sure, it’s fine. You’ll never get consensus on oil
    priusrust likes this.
  3. priusrust
    priusrust Member
    197
    70
    MA
    thanks...suspected as much.
  4. Mendel Leisk
    41,302
    Toyota doesn't say a thing, about conventional vs synthetic, or in-between. The stipulate spec's and a weight. 5W30 IIRC, which comes in both. I'd be inclined to use synthetic, just to play it safe I suppose, not that knowledgeable though. Here's some thoughts:
  5. rjparker
    10,073
    6,239
    gen2 came with dino oil. I used full synthetic in the two I had.
    gen3 came from the factory with synthetic.
  6. bisco
    51,838
    and the engines blew up :p
  7. pasadena_commut
    pasadena_commut Senior Member
    2,584
    765
    Southern California
    It was just ahead of its time. Now all the engines blow up.
  8. priusrust
    priusrust Member
    197
    70
    MA
    Video helpful! thanks! wish he addressed "semi synthetic".....but he sort of umbrellaed it all. Very good.
  9. rjparker
    10,073
    6,239
    Semi synthetic is a blend of conventional and synthetic.
