Confirmed - Home charging HV battery charges Aux 12V battery too!
Discussion in 'Gen 5 Prius Technical Discussion' started by WaikikiPrius, Feb 20, 2025.
  1. WaikikiPrius
    WaikikiPrius New Member
    2024 Prius Prime
    XSE
    At 32:00 in the video, it shows that the DC/DC converter is active and charges both the HV and Aux 12V battery while plugged in.
    However, Toyota's service manuals provide conflicting information, stating that you should unplug the charger, start the car in READY mode, and let it charge for 30 minutes to maintain the 12V battery.
    To verify this, I conducted the same experiment. With the charger plugged in, I measured the Aux 12V battery voltage using a voltmeter—it read over 14V, indicating that it was charging.
    Conclusion: In theory, keeping the Prius Prime plugged in daily should keep the 12V battery topped up, contradicting Toyota's manual instructions.
  2. BiomedO1
    2,580
    1,388
    SacTown, Ca
    DETAILS MATTERS....
    I don't have a gen5 to experiment with, but on a gen4 the DC-DC converter is ONLY actively charging the low voltage system ONLY WHEN the traction battery is actively being charged. Just plugging-in the car DOES NOT automatically charge the low voltage system. That's why the Toyota manual states "unplug the car, when if finishes charging". Leaving it plugged-in will force the ECU to perform more frequent readiness testing powered by the 12VDC battery alone, that isn't receiving a charge - because the traction battery is already FULL (see first sentence).
    FWIW; The only reason the low voltage system is active during charging is to ensure cooling fan operations, so the traction battery doesn't overheat during the process. Up there in Canada, the DC-DC converter may also activate to keep the traction pack warm and ready for vehicle operations. If that has changed for the gen5 - GREAT, but I doubt it - since there's been many reports of dead low voltage batteries.
    YMMV....
    schja01, Trollbait and MAX2 like this.
  3. WaikikiPrius
    2024 Prius Prime
    XSE
    I specifically posted this thread in the 5th gen...
  4. Hammersmith
    Hammersmith Senior Member
    1,890
    1,881
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    But he's actually correct in this case. Yes, the gen5 will charge the 12V while plugged in, but ONLY when the HV battery is also being charged.
    So imagine you come home with your HV battery almost completely full. You automatically plug it in because you've gotten in that habit. But then you don't end up using the car again for several days. Because it's plugged in, some of the computers stay active(the ones that monitor HV battery temp and state of charge). Those computers draw power from the 12V battery. Let's also say it's reasonably warm, so the car never needs to use the HV battery heater. The HV battery started full, and there's been no draw on it, so it hasn't needed to be charged over those several days. But the 12V has been slowly depleted by the extra draw from the awake computers. It's this issue the manual is trying to prevent.
    Now if you're in a cold enough climate, the HV battery heater will kick on from time to time. That's powered by the HV battery, so eventually it will deplete enough to kick on the HV charger. When that happens, it also checks the 12V battery and tops it up if necessary. Also, if you come home with your HV battery significantly depleted, the HV charger will stay on long enough to charge up the 12V at the same time it charges the HV. The main problem areas are if you plug in a car with a full HV battery in a warm climate, or if you leave the car plugged in for several days in a warm climate.
    As to the video, what he's saying is that the gen4 Prime had two DC-DC converters, while the gen5 only has one. In the gen4, there was the big converter in the engine compartment, but there was a second converter as part of the HV charger and that one handled charging the 12V battery. But in the gen5, Toyota eliminated that second converter and integrated its function into the main converter. But that doesn't change the behavior of the system. It still only charges the 12V when the HV is also charging.
    BiomedO1 likes this.
  5. KMO
    KMO Senior Member
    1,790
    580
    Finland
    2023 Prius Prime
    You're only contradicting known information and instructions if you were seeing 14V when the green LED on the charging cable was off and it wasn't charging the main battery or running the heater.
    The belief is that it won't take any action to maintain the 12V battery except as a side-effect of being on for charging or heating.
    And Hammersmith just said that.
  6. BiomedO1
    2,580
    1,388
    SacTown, Ca
    Thanks guys; I didn't think Toyota's army of technical writers and/or lawyers would make a glaring mistake like that in the operations manual.
    @WaikikiPrius This wasn't a personnel attack, I'm just trying to tamp down on incorrect or inaccurate information - especially when your telling everyone to contradict the OEM manual. That's fine, if your information is correct, but there's already been a lot of discussion about this since the first gen5's came out. Sorry....:( Who knows; maybe your one of the first to get a new firmware upgrade to address that 12V battery depletion issue, but we don't know until a TSB or something else comes out. If this was a fix, it wouldn't fix the non-plugins 12V battery issue.
    YMMV
    #6 BiomedO1, Feb 20, 2025
  7. Trollbait
    12,240
    The safety protocols of the charging standard call for the high power cables to be energized after the EVSE establishes communication with the car, and only when the car calls for the power. There isn't another cable in the charge cord that c an supply power to charge the 12V when the high power cables are de-energized.
  8. bisco
    50,815
    Would it be possible for a manufacturer to add a circuit from the hybrid battery to the 12v when the car is off?
  9. Trollbait
    12,240
    A step down DC-DC converter right at the battery that then feeds the battery would be possible.
    Simpler way would be to just monitor the 12V, and when it hits some low point, the car just re-engages the traction battery to top off its charge. Some EVs do this. Another solution is to build a 12V section in the traction pack, and ditch the lead-acid battery(Hyundai). Have a button to charge from the main battery if the 12V portion ever 'dies'.
  10. Mr.Vanvandenburg
    1,311
    534
    2020 Prius Prime
    The 12 v doesn’t charge when traction battery is being charged on my 20 Prime. I charge it every day using free to me wall socket or level 2. Weber State video has the 12 v charging with a gen 5. Have to look at it again to remember the specific conditions it charged.
    So after hundreds of charging sessions and looking at my 12 volt battery monitor every time,I can say it does not charge the 12 volt. Many times when I get home after traction charging, I have to get the 12 v maintainer out and charge the 12 v.
    I rarely finish charging the traction battery, it’s always still charging when I stop it. No idle time with cord plugged in.
  11. Paul Gregory
    Paul Gregory Senior Member
    1,178
    312
    Alberta
    2024 Prius Prime
    XSE
    I'll confirm this as well. I saw a 0.7V drop over a 24 hour period, from 12.5 to to 11.8V, As soon as I plugged in the hybrid charging cable, the battery was reading 12.0V, which confirms that some charging is happening. For me, it means one less job; I won't need to plug in the battery maintainer when the hybrid battery is being charged.
    Good to know.
    WaikikiPrius likes this.
  12. BiomedO1
    2,580
    1,388
    SacTown, Ca
    I never claimed that plugin-in your car will properly maintain your 12VDC battery, the author of this post did. (see his conclusion above).
    In fact, this is what I stated:
  13. Paul Gregory
    1,178
    312
    Alberta
    2024 Prius Prime
    XSE
    7 hours later, the battery is at 13.2V.
  14. bisco
    50,815
    better than new!
  15. Paul Gregory
    1,178
    312
    Alberta
    2024 Prius Prime
    XSE
    It just means that the small battery will continue to charge and maintain, even after the hybrid battery is fully recharged.
  16. bisco
    50,815
    even better!
  17. Dany Dan
    Dany Dan New Member
    Québec, Canada
    2024 Prius Prime
    SE
    I installed a small voltmeter permanently on the 12 volt battery of my Prius Prime 2024. When connected to recharge the high voltage battery, the DC/DC converter works and the voltage begins at 14.3 Volt and decreases gradually up to 12.7 Volt after a few hours.
    So he loads a little at first and afterwards, he only maintains it.
  18. Paul Gregory
    1,178
    312
    Alberta
    2024 Prius Prime
    XSE
    I keep a voltmeter plugged into my lighter socket to keep an eye on battery voltage before I try to start it. I can't say for sure, but I think below 11.5 volts, the car is disabled, requiring a boost or a service call.
  19. Dany Dan
    Dany Dan New Member
    Québec, Canada
    2024 Prius Prime
    SE
    We cannot read the tension of the Cigar lighter if we do not start or we are not accessory.
    When starting, there is a consumption of 8 amps.
    If the tension is 11.5 volts at this time, your 12 volt battery is unloaded or sulphate.
    During start -up, a non -sulphated loaded battery gives a voltage between 12.4 and 12.5 volts.
  20. Paul Gregory
    1,178
    312
    Alberta
    2024 Prius Prime
    XSE
    New car, new battery, and it still went dead, so don't give me that.
    I wired a new socket direct from the battery, but when you first hit the start button, it shows the battery voltage for a second or two before the converter kicks in.
