AC Auto Button will not work
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pidancer789, Feb 22, 2025.
  1. pidancer789
    pidancer789 New Member
    White
    Hello everyone I have a 2011 Prius Four and I bought it a few months back for heavy amounts of driving. Well upon buying it I knew it had a few issues and the Auto Button was one of them and I'm not exactly sure how to fix this issue but if I could get some troubleshooting help it would be appreciated. I have scoured the internet for my exact issue and I seem to be the first to encounter my AUTO ac button not working or turning on. Basically, the issue is exactly as it sounds I hit the AUTO button on my AC cluster and it does NOTHING no light just nothing but every other button on the AC cluster works fine. Additionally I have test both AC related fuses in the driver side fuse panel and in the engine bay fuse panel both tested for continuity and both work fine.
  2. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Do other buttons work? Windscreen heating, temperature setting, etc.
  3. pidancer789
    White
    Yes presently every other button on the AC cluster and in the car works fine the AUTO button is the only one that does not.
  4. ChapmanF
    18,080
    There may be some dried 7-Up or something that found its way into the AUTO button while an earlier owner had the car.
    If you're game to disassemble and clean that panel, it may turn out to need nothing more than that. If that seems daunting, you could try plugging in a replacement panel to see if it works better.
  5. pidancer789
    White
    So I disassembled it and cleaned the button and nothing worked still so I’m thinking it’s just a dead motherboard cause nothings blocking the button or making it not click on except the motherboard itself
  6. pidancer789
    White
    Auto button pictured here nothing wrong with it that I can see
  7. ChapmanF
    18,080
    I suppose you could try carefully powering it up in that state and poking a little jumper wire across the auto button solder pads, see if that gets any action
    MAX2 likes this.
  8. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    If you find out that the button is faulty, the button can be replaced for a small fee.
    Find a suitable one in stores selling small electronic parts.
