2011 Steering Knuckle Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kthi, Mar 1, 2025.
  1. Kthi
    Kthi Junior Member
    Help... Doing front right brakes, it went wrong. Torque wrench set at 101ft-lbf and some how stripped upper bolt. Any feedback would be appreciated.
    INSTALL FRONT DISC BRAKE CYLINDER MOUNTING
    (a) Install the front disc brake cylinder mounting to the
    steering knuckle with the 2 bolts.
    Torque: 137 N·m (1394 kgf·cm, 101ft·lbf)
  2. Mendel Leisk
    40,478
    Clarify "stripped". Any lube on the bolt threads?
  3. Kthi
    Kthi Junior Member
    No lubrication or anti-seize used. When I pulled the bolt out the threads from the knuckle are on it :(
  4. Mendel Leisk
    40,478
    Tried running another one of the bolts into the hole in question?
  5. Kthi
    Kthi Junior Member
    Here is a picture of bolt
  6. Kthi
    Kthi Junior Member
    The bolt is fine
  7. Kthi
    Kthi Junior Member
    No, the bolt is not stripped
  8. Kthi
    Kthi Junior Member
    Thanks for asking about the bolt. I went out checked. Not steering knuckle, but the caliper bracket... No threads in knuckle lol. So I need to replace the caliper bracket. Thank you
  9. ASRDogman
    ASRDogman Senior Member
    7,123
    3,721
    100 sounds like it's WAY too much. Where did you get that number from?
    Either the threads were already messed up, or cross threaded.
    You should double check that. And your torque wrench.
    Tombukt2 likes this.
  10. Mendel Leisk
    40,478
    101 ft/lb is the repair manual spec, for the caliper mounting bracket bolts. The bolts going onto the caliper slide pins are much lower torque.
  11. Mendel Leisk
    40,478
    Agree:
