2026 Gen. 5 Prius Wish-List
Discussion in 'Gen 5 Prius Main Forum' started by PriusPeep, Feb 23, 2025.
  1. bisco
    51,877
    prius gives plenty of warning if they overheat
  2. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    Here is what I would like to have changed to my 24:
    1) More reliable and faster Android connection.
    2) Better design on the center counsel display so that you can have quick access to radio and tune adjustability (treble, mid, bass) when in Carplay.
    3) Faster response on the steering wheel volume adjustment & clicking on the dash volume control.
    4) Tachometer option like in the 2025 Camry. I much prefer to be able to see the RPM going up and down in relationship to the changes in gear ratio even though you have a steady throttle input.
    5) Battery charge status meter or %, and coolant temp meter or deg. both showing without changing view.
    6) More sound deadening especially the front doors they don't feel a quality thunk when closed and feels a kind of noisy on rough freeway.
    7) Body color wheel arch not black.
    8) Custom drive mode will not be defaulted back to normal drive mode next time.
    9) Retune the eCVT to not let the engine rev up so quickly even at half throttle.
    These may seem like a lot, but each one is a simple fix.
    10) High Performance option with the Camry's more powerful engine+electric motors for $1000.
    Prodigyplace likes this.
  3. Winston Smith
    Winston Smith Active Member
    358
    241
    OH
    2024 Prius
    LE AWD-e
    Not having a tach is weird.
    There is one of these in the left half of the display. It's three screens down from the efficiency display in mine. It also shows whether you are charging or discharging.
    Tande likes this.
  4. Prodigyplace
    12,540
    11,767
    Central Virginia
    That depends. On my Camry I use the Hybrid system Status indicator instead of a tach.
  5. Mendel Leisk
    41,379
    I’ll reluctantly disagree, considering the Prius transaxle, and the total disability to do anything about the revs, it’s the car’s domain.
    Would like to see more stuff though, coolant temp for sure.
    Trollbait and Prodigyplace like this.
  6. Prodigyplace
    12,540
    11,767
    Central Virginia
    My Camry permanently shows a coolant gauge.
    Tande likes this.
  7. Winston Smith
    358
    241
    OH
    2024 Prius
    LE AWD-e
    I'd like to see an oil temp reading. I don't see how an engine that runs intermittently even in cold weather will get hot enough to cook moisture out of the oil.
    I get that the only control one has over revolutions is indirect and through the accelerator. I still don't like not knowing the engine speed.
    I have that too, but it isn't a tach.
    Engine speed, oil and coolant temp are on a need to know basis in a Prius, and it assures me that I don't need to know.
    #47 Winston Smith, Mar 3, 2025
    Mendel Leisk and Prodigyplace like this.
  8. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    Coolant temp is needed if you have a leak in the system and you're low on the coolant which can leads to engine overheating in a short time even though the chance is slim on a Toyota but you never know.
    I know I can see the battery charge status, but in order to see that, you will sacrifice the showing of the MPG. I wanted to be able to see both together with the coolant temp or oil temp and the tach.
  9. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    I really also wanted the tachometer because whenever you press the throttle past halfway, you can hear the engine thrashing sound, and I wanted to know how fast my engine is spinning. Before I bought the car, I thought if I put the drive mode in eco, the engine would not rev so high, but found out it didn't matter.
  10. Prodigyplace
    12,540
    11,767
    Central Virginia
    The Camry XSE & XLE have a larger meter display that lets us see more items at once. The lower trims have the 7 inch one which, i assume, is the same as the Prius.
  11. Winston Smith
    358
    241
    OH
    2024 Prius
    LE AWD-e
    Have you considered an aftermarket display like this on Amazon?
    Lufi Xs Obd2 Gauge Display,car inclinometer, Boost Gauge, RPM Meter, Multifunction Heads up Display Cluster
  12. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    #52 Humble Bear, Mar 3, 2025
  13. Winston Smith
    358
    241
    OH
    2024 Prius
    LE AWD-e
    Aesthetic considerations will be subjective. I have my radar detector mounted above and behind my center screen. I could imagine an extra small screen mounted above the driver's screen or to either side.
    The real obstacle for me would be getting the thing wired in so that it both works and doesn't cause a problem elsewhere. I wouldn't like to upset the digital black magic so that I could read revolutions only to find out that cruise control and headlights no longer worked. I try to follow the first two rules of horsing around with things I like: 1) first do no harm, and 2) modify the less expensive part.
  14. VelvetFoot
    VelvetFoot Active Member
    582
    198
    New York State
    2026 Prius
    Even though I'm still waiting on a '26 LE AWD, I've found three apps so far that appear as apps on CarPlay in a friend's '25 CrossTrek. Only text is available. I displayed engine parameters, such as rpm and coolant temperature, on the car's Infotainment screen.
    Something CarPlay compatible catering to hybrid would be nice, which could access all the available info, but I don't know if that exists, what the capabilities of those three apps, etc, etc.
    I created a topic:
    https://priuschat.com/threads/gauges-on-infotainment-screen-via-carplay-app-and-obdc-port.257299
  15. Paul Gregory
    Paul Gregory Senior Member
    2,133
    557
    Alberta
    2024 Prius Prime
    XSE
    The radio stations you store (like) are not for you to choose; they are the ones you are steered to like. Paid for by big media no doubt.
  16. VelvetFoot
    582
    198
    New York State
    2026 Prius
    you talking to me?
    I'm talking obdc
  17. markpenske
    markpenske New Member
    North Tonawanda NY
    I would love to see a 2027 GR Prius prime
  18. markpenske
    North Tonawanda NY
    Taxi driver?
    VelvetFoot likes this.
  19. Gokhan
    Gokhan Senior Member
    6,156
    2,434
    Paramount CA
    The biggest wish: Get rid of the giant P R I U S emblem on the back so that the road rage ends. It is ruining the appearance of an otherwise halfway-decent-looking car.
  20. VelvetFoot
    582
    198
    New York State
    2026 Prius
    Penske, from the Penske files?
