Loud embarrassing noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Royalwithcheese, Mar 5, 2025.
  1. Royalwithcheese
    Royalwithcheese New Member
    Hawaii
    Hoping to get some help with this noise my 2011 Prius is making,it has 162k miles,I bought it second hand as it was all I could afford. About 2 weeks ago it started making this noise(attached an audio clip), it occurs usually after sitting in traffic,also occurs when the engine is off in park,while driving or at idle. Itg has been getting more frequent the more I drive it. Very loud and is coming from the engine compartment on the left side. Sounds like a screeching. Hoping someone here has ran across this,every time I get by a shop the noise isn't happening and I cant find any help locally. I recorded the noise in the video here
  2. ETC(SS)
    6,910
    You're going to have to make a few more posts before you're able to attach an attachment.
    You may want to consider not driving the car in the meanwhile and you should check your coolant and oil levels much more regularly - especially the coolant level.
    The 'Prius Death Rattle' is more of a 'knocking' than a screeching, but screeching usually isn't good!!!
    If you do not know what the Prius Death Rattle is, you need to look into it fairly soon - as in immediately.
    Enter that phrase into the search bar and you will get about 4 pages of results.
    You also need to check your oil and coolant levels every time you fuel the car AT LEAST.....for now anyway.
    Good Luck!
  3. dolj
    dolj Senior Member
    8,186
    4,168
    Wellington, New Zealand
    You need to use the 'Advanced Search' and limit your search to search only the 'Gen 3 (2010-2015) Toyota Prius Forums'; also tick the 'Search child forums as well' checkbox. This will cut down search results to your generation Prius.
    ETC(SS) likes this.
  4. PriusCamper
    PriusCamper Senior Member
    11,982
    4,872
    Pacific Northwest, USA
    Never heard that sound before. On the bright side the engine sounds ok. See if you can find the exact location it's coming from by putting one end of the stick on various parts in the engine compartment and the other end of the stick up to your ear.
  5. PriusCamper
    11,982
    4,872
    Website-based search engines are terribly innacurate. It's best to use your preferred online search engine with key word 'priuschat' if you want to get a thorough list of all articles on PriusChat. Of course this noise, which sounds a bit like an air powered impact driver, isn't something I've ever read about on here.
  6. dolj
    dolj Senior Member
    8,186
    4,168
    I wouldn't go as far as to say inaccurate, but using the advanced search as I recommended goes a long way to cutting down on irrelevant results. I do recommend using a search engine from time to time as well. I personally have to resort to that infrequently so it is not in the forefront of my mind. Including the extra keyword 'gen 2' or 'gen 3' helps cut down irrelevant posts from other gen forums, in my experience.
    As for the sound the OP posted, I have nothing to offer as I have no Gen 3 experience.
    #6 dolj, Mar 6, 2025
    PriusCamper likes this.
  7. PriusCamper
    11,982
    4,872
    Now that Google has bailed on being a sophisticated search service and sold out to spew ads for almost every question asked, it's about time to create a new effort to do way more than ever to help people... Maybe we start organizing and work with owner Danny to create the next iteration of PriusChat? Maybe a link on website called: "Need Diagnostics Help, Click Here" and have that go to an AI system built on PriusChat data?
  8. Tombukt2
    12,015
    2,124
    During this crazy noise is your air conditioner on inside of this vehicle or the defrost something running the air compressor that almost sounds like high pressure freon being forced out to high pressure relief valve
  9. Royalwithcheese
    Hawaii
    I check them daily,found a slow leak from the bypass hose V connector and replaced that. Vehicle never got too low on coolant,oil is fine,no milk in it. I havent had that rattle or death knock
    ETC(SS) likes this.
  10. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,502
    1,597
    Bay Area
    Any check engine light? How many miles? I wonder if it could be from the water pump.
    ETC(SS) likes this.
  11. PriusCamper
    11,982
    4,872
    That would make sense if it was Gen2... It's such an odd sound. Sounds almost Pneumatic. And if it was water pump related in a ge3 I think there would be error codes pointing towards the problem.
    NutzAboutBolts likes this.
  12. NutzAboutBolts
    1,502
    1,597
    Bay Area
    yeah I kinda wonder since the wp spins with a magnet…. Only thing I can think of that’s on the passenger side of the vehicle…
    ETC(SS) likes this.
