What is this button ??? Prius 2024 LE
Discussion in 'Gen 5 Prius Main Forum' started by John Hayman, Mar 5, 2025.
  1. John Hayman
    John Hayman New Member
    Massachusetts
    Norma Butts likes this.
  2. Tideland Prius
    16,459
    Looks like the wiper deicer button. You should see heating elements at the base of your windshield (looks similar to those found on the rear window) where the wipers sit. This helps heat up the wiper blades to melt the ice to free your wipers.
    John Hayman and RandyPete like this.
  3. Paul Gregory
    Paul Gregory Senior Member
    1,679
    418
    Alberta
    2024 Prius Prime
    XSE
    I've been using that thing every day, all winter.
    John Hayman likes this.
  4. Winston Smith
    Winston Smith Active Member
    271
    192
    OH
    2024 Prius
    LE AWD-e
    That's the Charlie Brown shirt button. Leave any shirt in the trunk, press that button, and it will print the Charlie Brown shirt stripe on it.
  5. Paul Gregory
    1,679
    418
    Alberta
    2024 Prius Prime
    XSE
  6. Paul Gregory
    1,679
    418
    Alberta
    2024 Prius Prime
    XSE
  7. priusasa
    priusasa Junior Member
    47
    2023 Prius
    Definitaly wrong symbol for that feature.
  8. Paul Gregory
    1,679
    418
    Alberta
    2024 Prius Prime
    XSE
    It worked to tell me exactly what it was for.
  9. Trollbait
    12,380
    I can't think of anything better. You don't want something for the wiper de-icer to be confused with the front defroster nor with any other wiper related icon.
    The curved panel portion is the accepted image for the windshield among the defroster symbols.
    The wavy lines are for warm air used(cars had air vents for the rear job originally), so cover the defogging/defrosting action. The wiper de-icer is at the front, but only heating a small portion of the glass. It uses resistant heat, not warm air. The symbol for an electrical resistor is this.
    Cars with rear wipers can have the defroster wire do that zig zag by the wiper for freeing it.
    Tideland Prius likes this.
  10. Paul Gregory
    1,679
    418
    Alberta
    2024 Prius Prime
    XSE
    To depict it as rising warm air would be deceptive.
  11. Paul Gregory
    1,679
    418
    Alberta
    2024 Prius Prime
    XSE
    The space for the 3rd button is for the inverter.
  12. Tideland Prius
    16,459
    Literally on Page 363 of the owner's manual
    Prodigyplace likes this.
  13. Tideland Prius
    16,459
    What inverter? The AC outlet switch? I thought it's the heated steering wheel.
  14. Prodigyplace
    12,424
    11,686
    Central Virginia
    What do people think the manuals are for?
    PDFs are more convenient for searching though and readily available from the Toyota owners portal/
    The forum is not meant as a replacement for RTFM.
  15. Paul Gregory
    1,679
    418
    Alberta
    2024 Prius Prime
    XSE
    1500W inverter, I use it to charge my e-bike.
  16. Prodigyplace
    12,424
    11,686
    Central Virginia
    The Prime comes with an inverter?
    My son's 2023 RAV4 Prime has one too. During extended power outages we have used it to recharge out battery inverter used to power a refrigerator and, occasionally, a freezer.
  17. Tideland Prius
    16,459
    Yeah ok that.
    That's on the other bank of buttons below the one above.
  18. Hammersmith
    Hammersmith Senior Member
    2,075
    2,064
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Top Row:
    Empty - Auto High Beams* - Wiper De-Icer - Heated Steering Wheel
    Bottom Row:
    Fuel Door Release - Power Rear Hatch** - Inverter Switch***
    *G, H trims
    **H trim
    ***Prime/PHV
    (as always, manuals are your friend; especially the pictorial index in the front)
    Tideland Prius and Prodigyplace like this.
  19. priusasa
    47
    2023 Prius
    I just draw someything like this in 1 minuıte :D like it will explain wiper will be heated
  20. Paul Gregory
    1,679
    418
    Alberta
    2024 Prius Prime
    XSE
    Looks like it's heating the top of the windshield with warm air.
