2016 Prius 1) Water Pump codes, 2) HV battery (new) not charging up
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by avidtravellerhkg, Mar 5, 2025.
Tags:
  1. avidtravellerhkg
    avidtravellerhkg New Member
    Vancouver, B.C.
    I have a 2016 Prius with 193000km. I live at the bottom of a 'long' hill. At about 90000km+ long ago, the water pump and coolant was replaced as indicated by a warning light. As the vehicle aged, the battery deteriorated over time; thus well before the bottom of the long hill, the battery becomes fully charged sooner than when the vehicle was newer and the engine starts revving earlier as the battery aged. The battery level has also been acting strangely over the last year giving swinging levels of charge readings.
    In December, a warning light lighted up again at about 190000km. The mechanic noted by the codes changed the water pump, a certain valve, and coolant. It was reset. All was fine until a month later, a warning lighted up again. The coolant for the engine and the inverter stuff are noted to be circulating, but the code for the water pump and a certain valve remain. There is no leakage of any coolants with use noted now, as different from the problem of other people here on the forum.
    And since January, the car hybrid battery has stopped charging up, giving me at most 3 levels of use briefly. A new hybrid battery two days ago was put in: without any change now giving me a constant 2 levels of charge forever whether driving, idling at the lights, etc. There are no other codes, noted by different mechanic's reader.
    I am driving around without the engine overheating as checked by the mechanic, without any warning light on the dashboard. But codes for water pump and that certain valve remain. And the hybrid battery stays at 2 levels of charge wherever or however I drive. Now with the new hybrid battery, the car is not revving so much as with the old battery at the bottom of the hill, but it is not charging up either.
    Any suggestions?
  2. avidtravellerhkg
    Vancouver, B.C.
    Double checked with the mechanic, it is the P268111 code now.
    And with a very stable and constant 2 bar hybrid battery level whichever way I drive it, not any lower nor any higher.
  3. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    Give the car some time to adjust to the new hybrid battery.
    The computers in the car don't always make instant adjustments ti new parts, and if the installation was not done with the recommended procedures, that could be one reason it's not behaving like it was when new.
    What are the two levels the dash shows for the hybrid battery, bottom and top?
    And are you at the bottom of the hill or the top? or did I misread your post?
  4. Brian1954
    Brian1954 Senior Member
    2,137
    828
    South Central PA, USA
    List the actual codes that you have. Then you may get some help.
  5. Mendel Leisk
    41,302
    Source for that battery? Say new from Toyota, new or refurbished, sourced by your mechanic, or?
    any more details on your mechanic, an independent?
    how long is the hill? You’re regularly needing to ascend and descend it? Do you use B gear on descent?
    #5 Mendel Leisk, Mar 5, 2025
  6. avidtravellerhkg
    Vancouver, B.C.
    The new battery is now always a very confident 2 bar levels from bottom, vs the sometimes not so confident 2 bars dropping to 1 bar in the old battery. So confident that at times at traffic lights, it deems itself has enough power to shut off the engine til it thinks it doesn't.
    Confirmed, it is the P268111 code only now.
    The battery is new from genuine Toyota parts: the correct type (NiMHMM-X. R/TMC 2404) from Primearth EV Energy Co., Ltd. sourced by the independent mechanic with experience in Priuses of the different generations.
    I live at the bottom of a long hill, ie to get home I have to descend a hill for about 5km for 5mins. I don't use B to get home as if I am at three bars at the top of the hill, the battery fills up to full just about it gets to the bottom of the hill when the car was new. Pulling into the driveway, as the battery is somewhat full it seems to want to use the engine as braking as if in B mode since the battery is full. If I were to use B mode getting home, it would also fill up the battery equally and use the engine as braking the whole way making the journey very noisy. To achieve the three bars at the top of the hill, I usually ease off the accelerator to gently go the last part of the hill to use the battery somewhat before descending home.
    I am beginning to worry it is a particular computer module that we don't know of that's causing the P268111 code and or causing the new hybrid battery not charging up normally. The fuses are all fine. The coolant levels are normal without loss. The new water pump seems to be working. The car does not overheat with daily driving usage. And there is no warning light on the dash.
    Thank you for all your questions.
  7. avidtravellerhkg
    Vancouver, B.C.
    The current troubles began in December when I was stuck in a traffic jam, when all of a sudden the car decides to not want to charge up the hybrid battery and at that very moment giving the warning light on the dash.
  8. avidtravellerhkg
    Vancouver, B.C.
    So what is the best approach for P268111 and if the hybrid battery is still not charging up as normal?
  9. Brian1954
    2,137
    828
    Take it to your local Toyota dealership for diagnostics. Then go from there.
    I am guessing that there are other trouble codes that have not been read yet.
  10. avidtravellerhkg
    Vancouver, B.C.
    Found the culprit: it is a faulty coolant bypass valve with a sensor, which is located behind the hybrid system in the engine bay.
    Now all is back to normal as new. The new battery is charging up and behaving very normal as it should be. And a huge difference as compared to the erratic old battery - no more dropping to one bar, and fuel economy is probably back to as when the car was new far surpassing the numbers before the recent coolant system problems. Quieter engine too as probably the gasoline engine doesn't have to work as hard with the new and strong battery.
    #10 avidtravellerhkg, Mar 10, 2025
    Brian1954 and fotomoto like this.
