engine rumble/vibration on startup, 155K
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shooter8, Feb 20, 2025.
  1. Mendel Leisk
    40,475
    For just head gasket replacement engine doesn't need to be removed, nor refrigerant drained. Machining the head likely not needed either. Preferably shouldn't be. Specs for flatness of all the mating surfaces in the last link in my signature. if you're on a phone turn it landscape to see signatures.
  2. ASRDogman
    ASRDogman Senior Member
    7,123
    3,721
    Is it a NEW engine, remanufactured, or used? Replacing the short block if the head is okay?
    Coolant, not oil would be leaking into the cylinders.
    Depending on how long you've been driving it, and how hot it got, resurfacing the head is a "maybe"
    at this point. If the valves are leaking, no reason to reseat them. But should replace the valve
    guide seals.
    If the head needs all that work, it would probably be more cost effective, and time, to install a
    remanufactured engine from the Hybrid Pit would be the best route. With that many miles on the
    engine, you're likely burning oil. So maybe that remanufactured engine would be best way to go.
    It will cost less, and will be quicker to get the car back to you.
    The ONLY thing to "disconnect" on the hybrid system is the safety plug behind the rear seat.
    A VERY simple 1-2 minute effort.
    NO reason to "replace" the ac coolant. You just remove the compressor from the engine, you won't
    have to remove the refrigerant lines.
    Yes, the gasket CAN be replaced without removing the engine. Myself and other have done it.
    My head was not warped, but one valve had an extremely small leak. It took almost 5 minutes for the
    wd40 to seap through. So I reseated all the valve.
    You should have him remove the head and check if it's warped. You do that with a special straight edge.
    If it is no warped, and the valve aren't leaking, the least expensive way is to just replace the head gasket.
    Of course, no coolant, and probably a good idea to change the oil and filter, after running it to operating
    temp to check for any leaks. And any crap that gets into the oil passages will get caught in the filter.
  3. Shooter8
    Shooter8 Junior Member
    central Arizona
    2013 Prius v wagon
    Thanks for your responses. The shop quoted nearly 18 hours at $140.00 per plus parts and machine shop. The engine is original with 155K miles. The shop showed me a very bad photo of the borescope. I have seen better on Youtube.
  4. ASRDogman
    7,123
    3,721
    18 hours!!!???
    For that much money, get a remanufactured engine...
  5. rjparker
    9,515
    5,823
    This is a diy site primarily populated by guys who are willing to do it themselves for the lowest money regardless of no guarantees of reliability. Some of the loudest voices are "academic" only with no direct hg or egr or oil burning or brake booster fails symptoms ever heard or felt
    Toyota and most pro mechanics agree on this. Your hg is confirmed.
    They are going by the book; exactly how the dealer would do it; EXCEPT Toyota dealerships won't do a hg job on these engines due to their need to provide you with a good warranty and reliability. Most pro shops are the same these days; the old gen3 engines with low tension rings, pistons and hg failures need rebuilds. Toyota does recommend rebuilds using revised pistons and rings and did so for free when these engines were young.
    A 12-13 year old gen3 needs to be replaced with a pro built rebuild for long term reliability. Hybridpit in the LA metro would be my next phone call. You could drive back or have them ship for an Arizona shop swap. It may cost as much as your pro's engine out hg job but you will end up with a like new engine that will last another 150k miles.
    We have had guys change their hg three times in a few months. Each time engine in but various timing and oil leak problems caused rework.
    Shooter8 likes this.
  6. DirkAshburn
    DirkAshburn Member
    119
    48
    Virginia
    What tier gas have you used in the car? Cheapest you can buy or Tier 1?
  7. Shooter8
    central Arizona
    2013 Prius v wagon
    I don't know tiers of gas. We buy mostly Costco 87 Octane.
    Local independent shop gives 2-year, 24K warranty
    Yesterday, local Toy dealer quoted 17 hours, $3300 plus parts.
    New engine might be a possibility.
    DIYers seem happy to give advice.
    I will look into Hybridpit
  8. DirkAshburn
    DirkAshburn Member
    119
    48
    Virginia
    Costco is a top tier gas (added detergents). I'm just wondering if the quality of gas is why some EGRs clog and others don't.
  9. rjparker
    9,515
    5,823
    it's oil burning clogging egrs beyond an inconsequential light coating.
    MAX2 likes this.
  10. Mendel Leisk
    40,475
    They all clog, regardless of gas choice, oil consumption. Of course, apart from the 2015's (and some 2014's), they also all get to be oil burners, so it's hard to nail down.
  11. rjparker
    9,515
    5,823
    Some engines burn no observable oil in 5k miles. Those don't clog egrs. Low tension rings perform well for 100k miles or more in most cases.
