2011 Prius Start rattling for a second or two
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chris777, Mar 10, 2025.
  1. Chris777
    Chris777 Junior Member
    Los Angeles
    My 2011 Toyota Prius has been doing this on mostly every start up and mainly cold starts. I changed the spark plugs and coils but that did nothing. Still have the issue. Any ideas or thoughts on what it can be?Thank you. I have no engine codes as well that are coming from this. #prius #hybrid #sparkplugs #chrisfix #headgasket #coils#toyota #toyotaprius #2011prius.
  2. Chris777
    Los Angeles
  3. Brian1954
    Brian1954 Senior Member
    1,575
    609
    South Central PA, USA
    It is probably a bad head gasket.
    How many miles on the car?
  4. ETC(SS)
    6,842
    Stop driving the car!
    Search for "Prius Death Rattle." in this forum or in the YouTubes.
    What you want to do is avoid having to replace a head gasket....or worse, your engine if your car is 'hydrolocking.'
    They CALL it the 'death rattle' for a pretty good reason.
    Symptoms:
    Low coolant level.
    "milk shake" or water droplets on your oil dip stick.
  5. Mendel Leisk
    40,245
    What’s the miles?
