Oil Change Interval
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Mar 13, 2025.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Car Care Nut says every 5000 miles or six months whichever comes first
    Is that a good policy?
    I use mobile one synthetic 2010 prius
  2. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    The car manufacturer wrote a couple of pages in the manual for changing the oil. But he did not indicate the oil manufacturer.
    Because driving styles are different, and oil manufacturers are different.
    What does the oil become after 1000 miles, 2000 miles... after 5000 miles?
    Look and think.
  3. Mendel Leisk
    41,334
    For 3rd gen, unlike the States, Toyota Canada stuck to 8k kilometres (roughly 5k miles) or 6 months, whichever comes first. Similar to Gen 2.
    With our 2010, due to low-and-declining usage it was always the 6 months governing. Anyway:
    I stuck with that for about the first 12 years, doing changes mid April and October, ‘til after one spring change I see it had been barely 1000 kilometres since the last change.
    That’s when I changed, to 8k kilometres or yearly, whichever comes first.
  4. Tombukt2
    12,904
    2,318
    Something automatically goes off in my brain for some reason I don't know why between 5:00 and 8,000 mi in any of the four or five vehicles that I own I don't know how that works but I also monitor oil even in the cars that I don't personally drive when they come in at night evening whatever every few days whatever I look at the oil on the stick smell it and all that kind of stuff and as soon as it looks like it's getting where it needs to be out it comes and all of that.
  5. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    A real mechanic tests the oil with his teeth. :)
  6. ASRDogman
    ASRDogman Senior Member
    7,545
    3,895
    If you want your engine to last longer, 5000 miles is the smart interval.
    In the maintainence book look under extreme conditions....
  7. bisco
    51,846
    Every precaution needs to be taken with the gen 3 engine, hopefully preserving the head gasket.
    In a rare instance, I agree with the nut
  8. rjparker
    10,090
    6,260
    5k miles makes sense for any engine. Our 22 Rav4 engine has had 5k changes since new with an additional low mile break-in change.
    It's no coincidence that gen3 Prii in 2010 where the first with 10k intervals recommended by the factory. Gen2s were 5k miles. Toyota also encouraged the habit change by giving the first two free at 10k intervals. Some gen3 engines needed rebuilds in the first 50k miles.
    Oil changes are far cheaper than a factory extra cost when new extended warranty which won't fix oil burning or the resulting egr cooler clogs unless it's burning a quart every thousand miles.
    However no oil or additive (I am looking at you Valvoline R&P and Berryman B12) will fix an existing oil burner, hg problem or existing damage leading to a future hg.
    #8 rjparker, Mar 13, 2025
  9. Paul Gregory
    Paul Gregory Senior Member
    2,126
    555
    Alberta
    2024 Prius Prime
    XSE
    I stretched my oil changes in my Gen 3 Prius, mainly because the engine only runs part of the time, and it's a full synthetic.
    In fact, I've done that with all my vehicles for over 20 years. Never saw any engine wear, even up to 300,000 kms.
    PA Prius likes this.
  10. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Doesn't apply to the OP, but on Toyota's latest cars, the specified oil viscosity is ridiculously low at 0W-8!!!
    I can see a smallish 1.8L four cylinder engine running a low viscosity 0W-20, but not a 2.5L four cylinder running on 0W-8.
    So, yet another debate is introduced on top of the OCI question, which is what oil viscosity will you be using?
    SM-G781V ?
  11. bisco
    51,846
    I’ve never seen any engine wear, but I’ve never opened one up
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    This one is for my archive :ROFLMAO:
    bisco and MAX2 like this.
  13. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    That’s a unicorn Prius! My Drives are 95% highway and ICE is always on the highway.
  14. Taxi/Limo
    524
    107
    What about the every six months even if you don't reach the 5000 mile mark?
  15. Taxi/Limo
    524
    107
  16. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    There is no universal answer.
    Based on the principle of reasonableness, the amount of distance traveled, the season of the year, etc.
  17. Mendel Leisk
    41,334
    Post #3 is my solution.
    Honda has a Maintenance Minder system, much more advanced than the Toyota USA’s odometer counter: it counts down percent to the next scheduled service (which typically include oil change or oil/filter change), and may have more items (shown with a code). There’s also a footnote with caveat, saying regardless of the MM percent, change oil (or oil/filter, they alternate), at least yearly.
    #17 Mendel Leisk, Mar 14, 2025
  18. rjparker
    10,090
    6,260
    Toyota says 5k miles or 6 months for
    Extensive idling and/or low speed driving
    for a long distance such as police, taxi or
    door-to-door delivery use:
    Replace engine oil and oil filter
    There is little doubt this kind of use causes excessive thermal cycling of the engine.
  19. ASRDogman
    7,545
    3,895
    Oil's brake down over time. If you don't put many miles on it, you follow the time intervals.
    I never had this issue, except for my van which almost never gets driven. I had 3 years before I
    changed it.
    If you drive the car every week, even if it's short distances you would safe to follow the mileage intervals.
  20. bbrages
    bbrages Member
    164
    47
    St. Louis
    I just use the maintenance light, which comes on at 5000 miles on my 2010. Kind of seems like a lot of oil changing for as much highway driving as we do, but I'm seeing minimal oil consumption at 247k - would like to keep it that way. :)
    ASRDogman likes this.
